Intro to Soaring - Powerpoint Presentation
Old February 8th 12, 04:03 PM posted to rec.aviation.soaring
Steve
Default Intro to Soaring - Powerpoint Presentation
Hi all,
I'm planning to show my glider at a local high school and also have
the opportunity to give a 30 minute talk on "What is Soaring".
Does anyone have access to a PowerPoint presentation/file that could
be emailed to me? I'll have access to their audio/visual system and
it would be a great addition to the day. Thanks in advance.
Steve Vihlen
SV
Old February 8th 12, 04:33 PM posted to rec.aviation.soaring
Dan Marotta
I don't have what you're asking for, but, if you're planning to allow
students to sit in the cockpit or get close to the assembled glider, please
give them a good briefing about handling such a delicate and expensive piece
of equipment.
I once let a neighborhood kid sit im my glider while I was working on it in
the street in front of my house. He must have seen a video of Patty
Wagstaff throwing her Extra around the sky, because he immediately began
slamming the stick back and forth from one stop to the other.
"Steve" wrote in message
Hi all,
Steve Vihlen
SV
Old February 8th 12, 04:45 PM posted to rec.aviation.soaring
lanebush
of equipment.
the street in front of my house. *He must have seen a video of Patty
Hi all,
Steve Vihlen
SV
I do that while thermaling. Are you not suppose to slam the stick
back and forth from stop to stop?
XF
Old February 8th 12, 05:47 PM posted to rec.aviation.soaring
Frank Whiteley
On Feb 8, 9:03*am, Steve wrote:
Hi all,
Steve Vihlen
SV
http://www.ssa.org/sport/whatissoaring.asp
You could roll your own using the above as a start.
Be sure to mention the Cadet (print some applications) Youth Flight
Scholarship and the Kolstad College Scholarship.
BTW, Rachel Conklin (2011 Kolstad) received a standing ovation at the
SSA Awards Banquet in Reno. First time long time SSA members could
recall that happening. All Ralph Kolstad did was emotionally read her
application letter.
Frank Whiteley
Old February 8th 12, 08:02 PM posted to rec.aviation.soaring
Mike[_28_]
I just found it. Its only 14 slides but that should be enough for a
thirty minute presentation, especially if you throw some videos in. It
looks like Eric Greenwell is the original author.
Mike
Old February 9th 12, 03:12 AM posted to rec.aviation.soaring
Tony V
in the street in front of my house......
A friend took his DG300 to the local mall for display. An 8 year old
went over to the down wingtip and walked the wing up to the fuselage.
Tony "6N"
Old February 9th 12, 04:38 AM posted to rec.aviation.soaring
Bill D
Tony "6N"
There's a message there - don't put a wingtip down, use two wing
stands to keep the wings level if you're going to show a glider in
public crowds. It looks better that way anyway. Take along someone
for crowd control if you can.
Old February 9th 12, 05:05 AM posted to rec.aviation.soaring
Frank Whiteley
Tony "6N"
public crowds. *It looks better that way anyway. *Take along someone
Plus, put tail boom on a stand to keep the horizontal well out of
reach and to pose the glider. One wing high, the other low strikes a
nice pose. I drilled a one inch hole in several round paving slabs,
then cut some pvc lengths and glued t-joints on top. These make good
stanchions. A bright yellow poly rope runs from stanchion to
stanchion to rope off the area and allow one point of entry/exit to
the glider area. Bring extra help.
Frank
Old February 10th 12, 02:39 AM posted to rec.aviation.soaring
fredblair
Mike
Is it available for download?
Fred
Soaring Powerpoint Mike125 Soaring 2 June 16th 09 08:46 PM
PowerPoint viewer Bruce R Aviation Photos 10 March 6th 07 04:12 AM
PowerPoint show Aviation.pps [01/11] AndrewB2020 Aviation Photos 0 February 14th 07 03:27 AM
PowerPoint show Aviation.pps [11/11] Al Camp Aviation Photos 0 February 13th 07 02:32 AM
Need Powerpoint soaring presentation for Kiwanis group (USA) Eric Greenwell Soaring 8 August 16th 03 06:58 PM
