#11
On 3/10/2012 2:52 PM, Dan Marotta wrote:
So... Is my CAI 302 insufficient to claim a 1,000 KM diploma? Do I need to find my old Replogle barograph, get it calibrated, and find some papers? If that be the case, I'll just post on OLC should I complete the flight. It is approved for all flights - always has been. Here's a list of approvals... http://www.fai.org/component/phocado...ight-recorders -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Mar 10, 2:52*pm, "Dan Marotta" wrote:
So... *Is my CAI 302 insufficient to claim a 1,000 KM diploma? *Do I need to find my old Replogle barograph, get it calibrated, and find some papers? *If that be the case, I'll just post on OLC should I complete the flight. As Eric indicated, the CAI 302 is an IGC approved "flight recorder" for all flight performances, no barograph needed. This thread is talking about "position recorders" which handled differently by the Sporting Code, as they are not approved flight recorders, and most do not record pressure altitude, just GPS altitude. They can be used for Silver and Gold badges only... Marc |
On Mar 10, 10:52*am, fredblair wrote:
My question had nothing to do with 'cheating'. *I am an Instructor and I will be responsible for teaching members how to properly use these new devices to obtain their badges. *My question was just a question of fact: if the GPS altitude shown in the IGC file is going to be accepted as the altitude of the flight, then why do we worry about pressure altitude? *I thought the whole idea of approving the 'position recorders' was to eliminate the need for the more expensive units that include a calibrated pressure sensor. A couple of posts after this, makes a statement that we will still need pressure altitude, since that is what is in Sporting Code 3. Isn't the new Sporting Code going to be re-written to eliminate the pressure altitude requirement. The Sporting Code currently in effect through September 30, 2012 still requires that pressure altitude evidence be provided along with GPS- derived position data for Silver and Gold badges. If a badge flight is to be flown using a local NAC approved "position recorder" which does not record pressure altitude, then a barograph must also be carried, and both the GPS flight data and the barograph trace must be submitted for any badge legs. As of October 1, 2012, IGC flight data from an approved position recorder containing GPS position data and GPS altitude will be all that is required for these badge legs, no more barograph. Again, due to concerns that during a normal summer soaring day a gain of height measured by pressure altitude requires climbing to a higher actual elevation, than the (more accurate) GPS altitude measurement, an extra margin was added in an effort to equalize things. So, as of October 1, a climb to 1100M (as measured by GPS) will suffice for claiming Silver altitude using a GPS-only position recorder, no need to worry about pressure altitude. 1000M (as measured by pressure altitude) will continue to be acceptable when using an approved flight recorder, a position recorder which records pressure altitude, or a position record and barograph. I know this is a bit confusing, but believe me, getting Silver and Gold badges will be easier and cheaper from October on... Marc |
Thanks, Guys. For reasons I don't need to discuss here, I was out of the
sport for nine years. A lot changed during that time and I'm still catching up... "Marc" wrote in message ... On Mar 10, 10:52 am, fredblair wrote: My question had nothing to do with 'cheating'. I am an Instructor and I will be responsible for teaching members how to properly use these new devices to obtain their badges. My question was just a question of fact: if the GPS altitude shown in the IGC file is going to be accepted as the altitude of the flight, then why do we worry about pressure altitude? I thought the whole idea of approving the 'position recorders' was to eliminate the need for the more expensive units that include a calibrated pressure sensor. A couple of posts after this, makes a statement that we will still need pressure altitude, since that is what is in Sporting Code 3. Isn't the new Sporting Code going to be re-written to eliminate the pressure altitude requirement. The Sporting Code currently in effect through September 30, 2012 still requires that pressure altitude evidence be provided along with GPS- derived position data for Silver and Gold badges. If a badge flight is to be flown using a local NAC approved "position recorder" which does not record pressure altitude, then a barograph must also be carried, and both the GPS flight data and the barograph trace must be submitted for any badge legs. As of October 1, 2012, IGC flight data from an approved position recorder containing GPS position data and GPS altitude will be all that is required for these badge legs, no more barograph. Again, due to concerns that during a normal summer soaring day a gain of height measured by pressure altitude requires climbing to a higher actual elevation, than the (more accurate) GPS altitude measurement, an extra margin was added in an effort to equalize things. So, as of October 1, a climb to 1100M (as measured by GPS) will suffice for claiming Silver altitude using a GPS-only position recorder, no need to worry about pressure altitude. 1000M (as measured by pressure altitude) will continue to be acceptable when using an approved flight recorder, a position recorder which records pressure altitude, or a position record and barograph. I know this is a bit confusing, but believe me, getting Silver and Gold badges will be easier and cheaper from October on... Marc |
I decided to see how much a FlyWithCE would cost in the UK, and the UK
supplier (according to the FlyWithCE website) doesn't list the new DR300 on their website. ![]() |
flyWithCE tip #2: flyWithCE Flight Recorder and OLC | urosp | Soaring | 0 | February 16th 11 05:28 PM |
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? | urosp | Soaring | 0 | February 11th 11 06:39 AM |
flyWithCE Flight Recorder | John Godfrey (QT)[_2_] | Soaring | 4 | November 13th 09 07:10 PM |
FlyWithCe recorder woes | Ferstlesque | Soaring | 3 | June 29th 09 06:23 AM |
New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 08:31 PM |
