remote oil filter for expermental
Old November 10th 03, 08:09 PM
Billc851
Default remote oil filter for expermental
I tried to make a block off plate for my O-290 engine to connect a remote
oil filter- it worked except the oil pressure went from 90psi to 120psi-
I am using champion ac filter ch-48108 & 1/2 lines-
Everything is plummed right- (engine oil out to filter-in, etc)
Whats different about the lycoming engine?
Old November 11th 03, 12:49 AM
Jerry Wass
!doctype html public "-//w3c//dtd html 4.0 transitional//en"
html
Watch out for those die cast remote filter brackrets--I had one with fittings
screwed in it and it sat on the floor and age-cracked!!---so I machined
one out of 1" plate.
pBillc851 wrote:
blockquote TYPE=CITEI tried to make a block off plate for my O-290 engine
to connect a remote
broil filter- it worked except the oil pressure went from 90psi to 120psi-
pI am using champion ac filter ch-48108 & 1/2 lines-
pEverything is plummed right- (engine oil out to filter-in, etc)
pWhats different about the lycoming engine?/blockquote
/html
Old November 11th 03, 06:26 AM
Drew Dalgleish
On Mon, 10 Nov 2003 15:09:14 -0500, "Billc851"
On my 0-290 I just plumbed the filter in-line with the oil cooler and
left the screens in place. I'm using a die cast filter bracket that I
bought at a VW speed shop with an automotive filter.
Drew
Frantz oil filters Ray Toews Home Built 5 October 31st 03 04:31 AM
Just Ordered: An Ignition Switch and Oil Filter from ACS Larry Smith Home Built 30 October 22nd 03 07:41 AM
