Powerflarm results @Seniors
Old March 23rd 12, 02:30 PM posted to rec.aviation.soaring
Default Powerflarm results @Seniors
On Friday, March 23, 2012 8:53:21 AM UTC-5, T8 wrote:
Crickets....
No other contest user reports?
T8
My impression of the rental powerflarms units was very much the same as TA reported.
First let me go on record as saying that I want very much for the powerflarm concept to work. I plan to install a "brick" in my glider - when available and when they work.
I had three near misses in thermals. The powerflarm alarm would sound and a second or two later the near miss would occur. The range was unacceptably poor...
Other issues I had with the portable units we The display was very hard to read in the cockpit with my sunglasses on. The warning "beeps" could have been louder so as to be heard above the radio and audio vario. The display of transponder equiped aircraft with no directional information did me very little good.
I look forward to trying powerflarm again, after they have had a chance to make it work better.
Don (DK)
Old March 23rd 12, 03:17 PM posted to rec.aviation.soaring
bumper[_4_]
Don (DK)
Don,
Were you using the "optional" small panel antenna? This is the flat
black, about 1" X 4" receive antenna that should be mounted vertically
and a couple of feet away from the PowerFlarm. This is intended to
increase the PF effective range and is included with the portable.
thanks,
bumper
Old March 23rd 12, 04:06 PM posted to rec.aviation.soaring
Don (DK)
Don,
thanks,
bumper
No. I was using the antennas mounted to the rear of the portable unit. It is not easy to find a spot a couple of feet away from the panel which will not have some kind of carbon fiber blockage of the antenna.
Don
Old March 23rd 12, 05:29 PM posted to rec.aviation.soaring
Was this due to poor range; i.e., PowerFlarm did not receive the signal
from the other glider until it got too close to give a quicker warning?
I would guess that if you are thermalling with another glider that might
become a threat, that would be well within receiving range, and the
short warning time was due to poor threat determination, rather than
poor signal detection.
email me)
My three "near misses" were thermal entering problems. Twice the other guy - once my fault. I am aware that the other guys might be keeping score in a different way.....
From what I saw, the portable PowerFlarm range was clearly less than 1/4 mile - perhaps more like 1/8 mile. One or two seconds warning is not enough.
Don
Old March 23rd 12, 05:51 PM posted to rec.aviation.soaring
Kimmo Hytoenen
alarm would sound
range was
the signal
warning?
that might
and the
rather than
".us" to
email me)
the other guy
keeping score in a
different way.....
less than 1/4
is not
enough.
Don
Don,
Did the FLARM unit you tested have a logger, and do you have
the logger file? If you have, I propose you run the range
analysis
http://www.flarm.com/support/analyze/index_en.html
-kh
Old March 23rd 12, 06:27 PM posted to rec.aviation.soaring
Don Kroesch (DK)
Don,
analysis http://www.flarm.com/support/analyze/index_en.html
-kh
Kimmo
The Powerflarm that I was using was part of the US rental program. It shipped back right after the contest. I saw nothing in the manual about a logger.
Don
Old March 23rd 12, 06:30 PM posted to rec.aviation.soaring
RN
RN used a rental FLARM at the Seniors.
My experience was similar to DK and TA. I used the attached antennas
and mounted the unit on the top of the glare shield in the back seat
of the DG1000.
The effective range to see other FLARM gliders was something in the
neighborhood of 100 yards. Far too late to be useful.
We were told (correctly or incorrectly?) that the logger function had
not yet been activated on the rental units. No attempt was made to log
a flight based on this information.
I also strongly favor the "FLARM" concept of traffic alerting, and
appreciated the opportunity to try one using the rental program. My
plan was to buy a "brick" as soon as they become available, but from
what I have seen, my plans are definitely on hold.
It is somewhat frustrating that there seems to be no feedback on the
concerns being expressed other than from other pilots.
John
Old March 23rd 12, 06:36 PM posted to rec.aviation.soaring
Luke[_4_]
On 03/23/2012 2:27 PM, Don Kroesch (DK) wrote:
Don,
-kh
Kimmo
Don
Unfortunately the Flight Data Recorders are not enabled in PowerFlarm as
of yet. There is an option to download a diagnostic file to an SD card
but this is not in IGC format, it is only a small file that contains
sample data that is not human readable - it is only useful to the folks
at PowerFlarm.
Luke
Old March 23rd 12, 09:23 PM posted to rec.aviation.soaring
Derek Mackie
Don,
analysishttp://www.flarm.com/support/analyze/index_en.html
-kh
Kimmo
Interesting - the example on the link Kimmo sent shows that ~2 km is
the minimum range that should be achieved up to 200 km/h and shows
"normal" ranges out to ~6 km or so. In Uvalde I only ever saw one or
two other contacts at all and it was at much less than 1/2 km. My
unit went back to the factory for all the updates/repairs and so far,
in limited testing, that has improved to ~3/4 km. I will be bringing
it to Perry with hopes to see better. I'm sure they're working hard
on this, but the silence from the factory and North American sales is
deafening. I sincerely hope that my "Portable" isn't actually a
"brick" (i.e in the sense of being suitable for a doorstop or
paperweight...).
Derek
FS - Powerflarm Portable Westbender Soaring 0 January 9th 12 09:21 PM
PowerFLARM at Uvalde Paul Remde Soaring 19 August 1st 11 05:52 AM
Results and reports from Seniors" Walt Connelly Soaring 4 April 4th 11 01:03 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
