See You 3.95 and U.S. Start/Finish rules
Old March 26th 12, 11:16 PM posted to rec.aviation.soaring
Default See You 3.95 and U.S. Start/Finish rules
I can't seem to get SeeYou 3.95 to produce the same distance calculation as WinScore for U.S. AAT/TAT contest tasks with "start anywhere - even out the top" 5-mile start cylinders, and 1-mile finish cylinders. I have searched through the Naviter and RAS posts, but haven't found anything useful (except a reference by 2NO to a 'patch' that fixed the problem in 3.62). The closest I can come is with 'Move Origin' checked and 'Reduce leg distance' unchecked, but this still calculates the 1st leg distance from the point on the start cylinder closest to the 1st turnpoint - not to the point where the glider actually exits the cylinder (either out the periphery or out the top). I also checked the change log on the Naviter site to see if a later version than 3.95 had an explicit reference to this problem, but couldn't find anything.
Anyone else have a solution to this?
TIA,
Frank (TA)
Old March 27th 12, 02:44 AM posted to rec.aviation.soaring
ZL
TIA,
Frank (TA)
There's a registry setting tweak to make SeeYou use the last fix in the
start cylinder as the beginning of the first leg. No quite SSA rules,
but close. The patch linked from the SeeYou forum seems to be broken.
From memory (and poking around the registry) the registry entry that
needs to be tweaked is
HKEY_CURRENT_USER/Software/Naviter/SeeYou/Settings/UseFixForStart
Set it to 1 to use SSA rules, set it to 0 to use FAI rules. I don't
remember the effects of the task option check boxes once you flip the
registry setting.
Of course, be careful messing around Windows' innards.
-Dave
Old March 27th 12, 04:25 PM posted to rec.aviation.soaring
Dave,
Thanks!
Frank
registry setting.
-Dave
Seniors USA 2009 Start and Finish notes..... # 711 reporting [email protected] Soaring 65 March 21st 09 04:47 PM
Rules for 1000k with start/finish at midpoint. Andrew Warbrick Soaring 2 August 10th 04 05:04 AM
New SRA Site - New 2003 Rules Minutes and 2004 Rules Summary Ken Kochanski Soaring 0 December 17th 03 03:38 AM
Start Anywhere Cylinder (SSA rules proposal) Mark Navarre Soaring 15 September 25th 03 01:13 PM
