Newbie S-NAV question
Old April 8th 12, 12:09 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Default Newbie S-NAV question
So I bought a glider with an S-NAV&GPS-NAV not long ago, and I don't really know how to use either. However, when I start up the S-NAV, the unit thinks I am at 28300ft, when actual elevation is 434ft. Obviously, it won't let me adjust the altimeter enough to get the right elevation. On the startup "altimeter" screen, I set the pressure setting to the same as my regular altimeter (29.92 or whatever), but the altitude readout is still way off. Anyone run into this? Is it broken, or am I missing a setting somewhere?
Old April 8th 12, 05:31 AM posted to rec.aviation.soaring
Jordan Pollock
On Apr 7, 6:09*pm, dbrunone
dbrunone
I just dial the Snav altimiter down to the field elevation. Assuming
your Snav is receiving data from a GPS source, that will ensure your
glide slope/ alt differential is accurate. I suppose your altimeter
and or Snav could need calibrated, unlike every powered aircraft, very
few sailplanes ever get a pitot/static inspection. I could be wrong
though, I'm pretty new to the same system.
Jordan
ASW20 "E"
Old April 8th 12, 06:36 AM posted to rec.aviation.soaring
Craig Lowrie
It may be looking for millibar setting (not inches).... or just asjust it
until the feet setting is zero and ignore the pressure setting itself...
Could be wrong, but just an idea..
At 04:31 08 April 2012, Jordan Pollock wrote:
On Apr 7, 6:09=A0pm, dbrunone
dbrunone
Jordan
ASW20 "E"
Old April 8th 12, 02:52 PM posted to rec.aviation.soaring
Jordan Pollock
dbrunone
I just dial the Snav altimiter down to the field elevation. *Assuming
glide slope/ alt differential is accurate. *I suppose your altimeter
few sailplanes ever get a pitot/static inspection. *I could be wrong
Jordan
ASW20 "E"
I misread part of your post. Might check with Gary at ClearNav
instruments, might need a calibration on the S-Nav, or he could
provide some goo insight otherwise. He's helped me out numerous times
in working out the bugs.
Jordan
Old April 8th 12, 03:44 PM posted to rec.aviation.soaring
Craig R.
Is it possible you have a task inputted and the 28,300 is the altitude you need to gain to complete the task?
Craig
Old April 8th 12, 04:46 PM posted to rec.aviation.soaring
Paul Remde
Hi,
My guess is that the S-NAV needs repair. Gary Kammerer at ClearNav can
probably fix it for you. You can reach him through their web site at
www.clearnav.net.
You can download the S-NAV and GPS-NAV manuals at www.cambridge-aero.com.
You should also check out the free training/demo tools for L-NAV and GPS-NAV
on my web site. The L-NAV demo covers most of the functionality of the
S-NAV - but not the tasks - which would be done in the GPS-NAV.
http://www.cumulus-soaring.com/cai_downloads.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
__________________________________________________ __
"dbrunone" wrote in message
dbrunone
Old April 9th 12, 02:55 AM posted to rec.aviation.soaring
RS
On Apr 8, 11:46*am, "Paul Remde" wrote:
Hi,
My guess is that the S-NAV needs repair. *Gary Kammerer at ClearNav can
probably fix it for you. *You can reach him through their web site atwww.clearnav.net.
You can download the S-NAV and GPS-NAV manuals atwww.cambridge-aero.com.
on my web site. *The L-NAV demo covers most of the functionality of the
S-NAV - but not the tasks - which would be done in the GPS-NAV.http://www..cumulus-soaring.com/cai_downloads.htm
Best Regards,
Paul Remde
dbrunone
Another option, leave it as is and brag to your friends on a day with
only 6000ft cloud bases and no wind you managed to climb 28,300ft.
Check out Craig's R'.s theory. I'm not familiar with the the SNAV
myself, but the possibility that 28,300ft is the altitude needed to
glide to a preselected task seems plausable. Where is your glider
from; if the previous owner still had it set to a location in that
region, is 28,300ft needed to reach that location from where it
currently is???
Old April 9th 12, 04:03 AM posted to rec.aviation.soaring
M North
Try pressing GO+LEFT while turning it on.
Old April 9th 12, 08:38 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
dbrunone
If this is the altitude shown on the initial power up when you see
battery voltage, barometric pressure, and altitude, then it needs to
go visit Gary at ClearNav. Oh, and you may need to put on your oxygen
mask, if you really are that high! ;-)
Steve
Old April 9th 12, 11:11 PM
Member
Quote:
Hi,
Best Regards,
Paul Remde
dbrunone
currently is???
Good thought, but the 28300 comes up on the "set altimeter" screen when you first turn it on. Plus, I programmed the local airport into the GPS-NAV already. It would take more than 28,300ft for final glide form NY to Tennessee anyway ;-).
Newbie VOR question Bruce W.1 Piloting 15 April 7th 05 05:15 PM
newbie question 2 Billy Who? Piloting 9 December 23rd 04 05:58 AM
A question only a newbie would ask Peter Duniho Piloting 68 August 18th 04 11:54 PM
FS2002 - newbie question Peter Allison Simulators 2 July 15th 04 05:52 PM
Newbie question Bill Gribble Soaring 6 November 6th 03 07:57 PM
