Newbie S-NAV question
Old April 9th 12, 11:12 PM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Quote:
Originally Posted by M North View Post
Try pressing GO+LEFT while turning it on.
What will that do
Old April 10th 12, 03:43 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Newbie S-NAV question
On Apr 9, 5:11*pm, dbrunone
Good thought, but the 28300 comes up on the "set altimeter" screen when
you first turn it on. Plus, I programmed the local airport into the
GPS-NAV already. It would take more than 28,300ft for final glide form
NY to Tennessee anyway ;-).
dbrunone
Yep, it needs to go visit Gary. Just for grins, you might try
removing the cover, and then carefully slip the boards apart and back
together on their connections. Sometimes, they get a little corrosion
on them and with the really low currents and voltages, this can cause
problems. A little "mechaincal abrasion" sometimes can do the trick.
Steve
Old April 10th 12, 10:36 AM posted to rec.aviation.soaring
Andrew Henderson
Had this happen to my SNav about 2-3 years ago and when I was ready to go
X/c so I was screwed.
Another pilot who had previously had the same problem leaned in to the back
of the panel, put his hand in near the back of the Snav and give it a thump
with the side of his hand. All went back to normal and never had the
problem since.
Hope this helps.
Andy
Old April 14th 12, 01:26 AM
Member
I tried this, and it actually worked! Thanks! Hopefully it won't happen again
problem since.
Hope this helps.
Andy
Old April 14th 12, 01:17 PM posted to rec.aviation.soaring
Andrew Henderson
You’re welcome. Pleased it worked for you. :-)
Nothing like a good old thump to get things going!!
You might want to think about buying a new internal battery too as they
only last about 5 years. You do get plenty of warning when it's getting low
though so no panic.
Regards
Andy
again
go
back
thump
problem since.
Hope this helps.
Andy
dbrunone
Newbie VOR question Bruce W.1 Piloting 15 April 7th 05 05:15 PM
newbie question 2 Billy Who? Piloting 9 December 23rd 04 05:58 AM
A question only a newbie would ask Peter Duniho Piloting 68 August 18th 04 11:54 PM
FS2002 - newbie question Peter Allison Simulators 2 July 15th 04 05:52 PM
Newbie question Bill Gribble Soaring 6 November 6th 03 07:57 PM
