#11
On Apr 9, 5:11*pm, dbrunone
wrote: Good thought, but the 28300 comes up on the "set altimeter" screen when you first turn it on. Plus, I programmed the local airport into the GPS-NAV already. It would take more than 28,300ft for final glide form NY to Tennessee anyway ;-). -- dbrunone Yep, it needs to go visit Gary. Just for grins, you might try removing the cover, and then carefully slip the boards apart and back together on their connections. Sometimes, they get a little corrosion on them and with the really low currents and voltages, this can cause problems. A little "mechaincal abrasion" sometimes can do the trick. Steve |
Had this happen to my SNav about 2-3 years ago and when I was ready to go
X/c so I was screwed. Another pilot who had previously had the same problem leaned in to the back of the panel, put his hand in near the back of the Snav and give it a thump with the side of his hand. All went back to normal and never had the problem since. Hope this helps. Andy |
I tried this, and it actually worked! Thanks! Hopefully it won't happen again
Quote:
You’re welcome. Pleased it worked for you. :-)
Nothing like a good old thump to get things going!! You might want to think about buying a new internal battery too as they only last about 5 years. You do get plenty of warning when it's getting low though so no panic. Regards Andy At 00:26 14 April 2012, dbrunone wrote: I tried this, and it actually worked! Thanks! Hopefully it won't happen again Andrew Henderson;813016 Wrote: Had this happen to my SNav about 2-3 years ago and when I was ready to go X/c so I was screwed. Another pilot who had previously had the same problem leaned in to the back of the panel, put his hand in near the back of the Snav and give it a thump with the side of his hand. All went back to normal and never had the problem since. Hope this helps. Andy -- dbrunone |
Newbie VOR question | Bruce W.1 | Piloting | 15 | April 7th 05 05:15 PM |
newbie question 2 | Billy Who? | Piloting | 9 | December 23rd 04 05:58 AM |
A question only a newbie would ask | Peter Duniho | Piloting | 68 | August 18th 04 11:54 PM |
FS2002 - newbie question | Peter Allison | Simulators | 2 | July 15th 04 05:52 PM |
Newbie question | Bill Gribble | Soaring | 6 | November 6th 03 07:57 PM |
