Chest parachute? (need more room in my Discus A !!)
Old May 3rd 12, 05:46 PM posted to rec.aviation.soaring
soartech[_2_]
Default Chest parachute? (need more room in my Discus A !!)
John Cochrane said
As I remember from my mis-spent youth in hang gliders, though, these
parachutes are *not designed for a free-falling pilot. A broken hang
glider doesn't fall that fast.
That was true in the past. Today's HG chutes are rated for free-fall
in case
you are separated from the glider.
Old May 3rd 12, 08:40 PM posted to rec.aviation.soaring
Papa3[_2_]
On Thursday, May 3, 2012 8:41:04 AM UTC-4, Derek Mackie wrote:
For the record, I tried quitting pizza and beer last night. I didn't
drink while I was eating and didn't eat while I was drinking. I
didn't notice any change, so consider the "experiment" a failure.
Don't try this at home...(I'm a professional.)
Derek
Getting kinda dull up there in Canada what with not a single team left in the NHL playoffs, eh? Resorting to tempting the Gods with such radical behavior...
P3
Old May 4th 12, 02:48 PM posted to rec.aviation.soaring
Derek Mackie
For the record, I tried quitting pizza and beer last night. *I didn't
drink while I was eating and didn't eat while I was drinking. *I
Derek
Getting kinda dull up there in Canada what with not a single team left in the NHL playoffs, eh? * Resorting to tempting the Gods with such radical behavior...
P3
You trying to make me cry? Words hurt, you know. :-(
Derek
Old May 7th 12, 06:04 AM posted to rec.aviation.soaring
Paul[_9_]
On May 2, 5:38*pm, Ian Reekie wrote:
At 07:01 02 May 2012, Paul wrote:
Hi all,
Does anyone know anyone who flies with a chest parachute? I'd like
extra room in my Discus A, and perhaps this might be one way? Thanks
alot in advance.
Regards,
Paul
Have you considered a remote parachute pack. *You wear the harness and the
chute pack is stored behind your head and deployed by a static line. *Used
in Europe.
http://www.streckenflug.at/shop/prod...65&products_id....
Thanks alot for that. Perfect! Now got to see if I've got the room to
stuff the chute?
Regards,
Paul
Old May 7th 12, 06:05 AM posted to rec.aviation.soaring
Paul[_9_]
On May 2, 9:30*pm, Rick Walters wrote:
On May 2, 12:01*am, Paul wrote:
Hi all,
alot in advance.
Regards,
Paul
Paul
I have flown with a headrest chute and placed it on my chest whilst
flying an ASH25. Definitely not optimum. Bulkiness and turbulence are
issues and map reading becomes hopeless. Ian has suggested the remote
( shoulder or headrest ) chute and that is the way to go. If you are
in the USA, be sure your rigger will repack such a chute, before you
buy one. The A model SH fuselage space above the wing spar may be a
tight fit so check dimensions.
Rick
OK, thanks alot Rick. Will steer away from the chest option.
Appreciated.
Regards,
Paul
Old May 7th 12, 06:10 AM posted to rec.aviation.soaring
Paul[_9_]
On May 3, 12:34*am, soartech wrote:
On May 2, 9:30*am, Rick Walters wrote: On May 2, 12:01*am, Paul wrote:
Hi all,
alot in advance.
Hang glider pilots all fly with chest or side mounted chutes that are
capable of supporting
the glider (~80 lbs.) and the pilot together. They cost about $700 and
weigh about 6 lbs.http://www.highenergysports.com/hg_eparachutes.htm
OK, thanks alot, appreciated. I'll check them out now.
Regards,
Paul
Old May 7th 12, 06:14 AM posted to rec.aviation.soaring
Paul[_9_]
On May 3, 4:54*am, Derek Mackie wrote:
On May 2, 1:41*pm, John Cochrane
*lbs.http://www.highenergysports.com/hg_eparachutes.htm
Ballistic parachute to bring the glider down too?
Trading the discus A for a B or CS might be an easier solution!
John Cochrane
Also from my mis-spent youth - the chest mounted parachutes that we
used to use (I still have one somewhere) was hand-deployed. *That is,
you peel it off your chest, look for a hole in the tangled rigging and
throw it as hard as you can. *There is no pilot chute or D-handle,
which makes them light and compact, but, YOIKS! *A lot of guys went to
ballistics.
It would seem to me that a headrest pack might be your most reasonable
solution, but I would want to practice getting out to see what body
motion you need in order to not snag anything if you need to leave.
If it was me, I'd try getting on a treadmill for a while, maybe give
up pizza and beer. *Then when that failed, I'd start looking for a
jumbo-sized glider. *:-)
Derek
Derek,
Thanks alot for that. I think a headrest chute might be the way to go.
I'm only 71 kg (156 pounds, 11 stone), but at 183 cm it would be nice
to have a little more room.
Regards,
Paul
Old May 7th 12, 06:15 AM posted to rec.aviation.soaring
Paul[_9_]
On May 3, 9:23*am, Bruce Barnard wrote:
Not familiar with SH, but in Schleichers many remove the seat backs.
Chutes are as hard as a rocks anyway so losing the seat back is not
much of a comfort loss, only a headrest loss. *Certainly much better
than quitting beer. *Hard to believe a good natured Canadian would
suggest you quit beer.
My Discus doesn't have a seat back. So this won't be an option. Thanks
for the suggestion anyway.
Regards,
Paul
Old May 7th 12, 06:19 AM posted to rec.aviation.soaring
Paul[_9_]
On May 3, 9:22*am, Steve Leonard wrote:
On May 2, 2:01*am, Paul wrote:
Hi all,
alot in advance.
Regards,
Paul
Well, can depend on where you want the extra room. *I have heard of
chutes being packed thinner at the top or bottom to make a slight
wedge form. *How heavy are you? *Lighter but maybe still larger pilots
can safely use a smaller canopy chute which will be a smaller pack.
Is the seatback still in? *Rudder pedals all the way forward? *Looked
at a different panel with higher shin cutouts? *Is there anything at
or near canopy rail height that could move to somewhere else?
If worst comes to worst, you can always get more room in your Schempp-
Hirth A by converting it to a Schempp-Hirth B.
I'm 71 kg and 183 cm tall. And my Discus doesn't have a seatback. And
rubber pedals can go forward a litle more, but would then be out of
reach. And have just made a new panel with bigger cutouts to make lots
more room for my shins. And have already moved the speaker mounting
point from beside my shoulders to up front more (so it points
backwards and not forwards). So the only thing left it to buy a
"remote" chute so I can put the pack on the deck behind my head, or
modify the seatpan a bit (ie: remove belly release, then re-mould the
seatpan to occupy the area that would otherwise be taken up by the
belly release). Thanks alot for all this, appreciated.
Regards,
Paul
I just have to get it off my chest. Clem Aviation Photos 85 July 27th 07 08:53 AM
??Build rolling tool chest? Michael Horowitz Owning 15 January 27th 05 04:56 AM
Discus 3 or Super Discus? Mirek Soaring 1 June 13th 04 09:28 AM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
