FAI badge, should I adjust the FR to airport elevation?
Old May 9th 12, 02:59 AM posted to rec.aviation.soaring
akiley
Default FAI badge, should I adjust the FR to airport elevation?
I have a Colibri II (approved) flight recorder. This device allows
the user to adjust either the current altimeter setting, or adjust its
pressure altitude to match field elevation. Is this ok to do for
badge flights like silver/gold, or am I supposed to leave it set to
standard atmosphere?
....Aaron
Old May 9th 12, 03:22 AM posted to rec.aviation.soaring
Paul Remde
"akiley" wrote in message
....Aaron
___________________
Good Question. It really doesn't matter what you do with the settings. All
IGC Approved loggers always record the unadjusted pressure.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old May 9th 12, 11:14 AM posted to rec.aviation.soaring
Gary Patten
....Aaron
If in doubt allways get the OO to take a photo of the gliders Altimeter
showing its settings matching what you have set your recorder too, and
declare what you've done pre flight
Old May 9th 12, 01:55 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
....Aaron
Why would you want to adjust a flight recorder to QFE? The data you are
interested in is the difference in height between the start of the soaring
task and the completion. It really does not matter what setting you use
QFE, QNH or standard atmospheric pressure as the two heights you are
interested in are the height after the completion of the launch and the
maximum height you achieve but the norm is to use standard atmospheric
pressure. It is not as though you are going to use the Colibri as an
altimeter in flight.
Other loggers do allow you to set QFE or QNH but the file is still recorded
with the baseline at standard atmospheric pressure which does create
problems when checking for airspace violations when the limits of the
airspace are defined other than as a flight level.
Old May 9th 12, 02:40 PM posted to rec.aviation.soaring
John Scott[_3_]
When trying for Gold Altitude in the West it can be very important to know
where the flight recorder thinks you are at 17,999'. With field elevations
near 7,000', getting the required 3000 meters gain means flying very close
to Class A, but not into it. We've had several badge attempts fail because
of differences in readings between the logger and the altimeter. We now
recommend setting the logger to field elevation and not exceeding 17,999
(well, 17,750 actually) on the logger display.
At lower field elevations, not so important.
John
"Don Johnstone" wrote in message
. com...
....Aaron
recorded
Old May 10th 12, 09:34 AM posted to rec.aviation.soaring
Wojciech Scigala
Do whatever you like. This is for in-flight display purposes only. All
FRs record altitude referenced to QNE. Adjustments for local pressure
are made by analysis software.
WojtuÅ›
JN4-H erection drawing, side elevation Don Pyeatt Aviation Photos 0 October 2nd 09 12:30 AM
Question: Elevation --- RWY john89 Piloting 21 August 15th 09 08:34 PM
ASTER Global Digital Elevation Map AGL Soaring 1 June 30th 09 03:11 PM
KY-97A sidetone adjust Mike Noel Owning 1 April 16th 07 09:00 PM
How do I get MSL out of National Elevation Dataset? Kyler Laird General Aviation 0 January 12th 04 08:12 PM
