MGSA's G102 is in need of new brake system--or rebuild for old one. I
have emailed Linder for for info, part numbers, etc,no response so far. I am told it is a BMW motorcycle brake, from Magura. I am located in the Atlanta, Georgia, USA, and have sources for BMW motorcycle parts. The master cylinder is back behind the seat pan, and not easy to get to--anybody know any tricks to make it easier? I would really like the BMW or Magura part numbers, or the the Bike model, if anyone knows them. Otherwise, I'll have to disassemble and measure. Being able to remove and replace same day would be nice. Thanks in advance Hartley Falbaum "KF" USA |
On May 23, 8:07*am, Hartley Falbaum wrote:
MGSA's G102 is in need of new brake system--or rebuild for old one. I have emailed Linder for for info, part numbers, etc,no response so far. I am told it is a BMW motorcycle brake, from Magura. I am located in the Atlanta, Georgia, USA, and have sources for BMW motorcycle parts. The master cylinder is back behind the seat pan, and not easy to get to--anybody know any tricks to make it easier? I would really like the BMW or Magura part numbers, or the the Bike model, if anyone knows them. Otherwise, I'll have to disassemble and measure. Being able to remove and replace same day would be nice. Thanks in advance Hartley Falbaum "KF" USA I have rebuilt the brake system on a G103A and it is likely the same. You are correct that the master cylinder is a Magura unit as used on a BMW motorcycle. You can order a rebuild kit or even a new master cylinder from a local BMW Motorad dealer. As I recall, it was a common unit used for several years in the late '70's and early '80's. I ordered the kit after measuring the bore size - that was the best way to make sure you get the right one and the dealer will identify it by that size. The rebuild involves dis-assembly, cleaning, honing of cylinder, and re-assembly using new seals. Now, you only need this kit if your master cylinder is not working or leaking. Try bleeding the brakes first. And interesting note about the G103A was that the caliper was a Cessna unit! The best way to bleed it is from the caliper up, not from the master cylinder down. Once tuned up, you will find that the system is amazingly effective. I like having brakes and I'm always amazed that most gliders I've flown have none either by poor design or poor maintenance. |
G102 retractable gear | John Murphy | Soaring | 2 | June 17th 09 05:30 AM |
G102 spigot AD??? What's the status... | Gary Emerson | Soaring | 31 | August 22nd 08 10:39 PM |
G102 Wing Inspection Panel | Tim[_1_] | Soaring | 2 | August 13th 08 02:40 AM |
Grob G102 Setup | BDS | Soaring | 11 | August 30th 05 03:42 PM |
Wheel Brake on G102 | Ken Pruchnick | Soaring | 4 | March 2nd 05 07:01 AM |
