PowerFlarms at Avenal Contest
Old May 24th 12, 07:07 PM posted to rec.aviation.soaring
Dave[_26_]
Default PowerFlarms at Avenal Contest
On Thursday, May 24, 2012 10:17:13 AM UTC-6, Bart wrote:
On May 23, 10:47*pm, bumper wrote:
There are a few reasons that one PF equipped aircraft might "alert" while the other conflicting aircraft doesn't.
In a perfect world it should be a two way street. However, the installation or placement of an antenna for transmitting is more critical than that for a recieve antenna. If glider #1's PF antenna is installed less optimally than glider #2's PF antenna, it may well be that #1 gets the alert while #2 does not. As #1's poor antenna install may receive marginally well, but wastes transmit power due to a high SWR or a null due to blocking structure.
Oh. PF uses one antenna to transmit and another to receive?
Bart
PF uses FLARM port A to transmit and receive. It uses FLARM port B to receive only. There is a third port for the transponder/ADS-B receive function. And the brick adds a fourth connector for remote GPS antenna.
Bart
Here's the excerpt from the manual:
"BRICK has two separate FLARM radio transceivers: FLARM A is used to receive and transmit and must always be connected to an antenna; FLARM B is only used to receive, an optional antenna may be used for better reception performance."
Its the same for both portable and brick versions. Although the portable only has the FLARM A connector with reverse polarity (via a staked on connector adapter".
With the 2 antenna setup in use there could easily be regions where you have receive coverage but not transmit coverage.
-Dave
Avenal Contest, Still Needs Tuggies sisu1a Soaring 0 February 27th 09 05:06 PM
Avenal, USA Contest Maps 2007 Downloads Mario Crosina Soaring 0 April 20th 07 07:45 PM
Avenal Contest [email protected] Soaring 0 April 12th 07 04:55 PM
Avenal Contest [email protected] Soaring 0 April 12th 07 04:20 PM
33rd Annual CCSC Contest, Avenal USA Mario Crosina Soaring 0 April 9th 07 03:59 PM
