Preheating schemes?
Old November 11th 03, 09:44 AM
Michael Horowitz
Default Preheating schemes?
I'd be interested in any schemes you may have developed for
pre-heating your engine.
One idea I heard was to use flex ducting to direct car exhaust into
the cowling; that does present CO concerns, but on could leave the a/c
doors open. - Mike
Old November 11th 03, 12:51 PM
Edward Schrom
I'm not anywhere near needing a preheater for my Sonerai project, but I have
thought about it. When the day (or decade!)comes, I might try using a
propane bottle, the kind you can buy in the hardware store for a couple of
bucks. It would be below the cowling, far enough away to ensure that the
flame doesn't get too close. Then there would be a duct of lightweight
insulating material to guide the warm air through a door in the bottom of
the cowling into the engine compartment. The torch nozzle might have to be
customized to get the best heat transfer to the rising column of air.
The advantages of this would be a) it's cheap, b) it doesn't require
electricity, and c) it's portable, so I could take it with me on
overnighters in cold weather.
As I said, I'm nowhere near testing this idea. Try it at your own risk.
Ed
"Michael Horowitz" wrote in message
doors open. - Mike
Old November 11th 03, 12:54 PM
Model Flyer
a/c
doors open. - Mike
Bad idea, there would be lots and lots of condensation from the
exhaust. Everything would be wet, including the inside of your
starter and magneto. I'm sure you could even get water buildup inside
the carb if your engine had one:-)
Cheers,
Jonathan Lowe
whatever at antispam dot net
No email address given because of spam.
Antispam trap in place
Old November 11th 03, 01:06 PM
Michael Horowitz wrote:
: I'd be interested in any schemes you may have developed for
: pre-heating your engine.
: One idea I heard was to use flex ducting to direct car exhaust into
: the cowling; that does present CO concerns, but on could leave the a/c
: doors open. - Mike
This doesn't sound like a very good idea to me. A car's exhaust
has a tremendous amount of water in it, and not very much heat idling on a
cold day. You'll put lots of condensation on whatever you're trying to
preheat.
If you can deal with long-term (a couple of hours), try to put an
electric heater on it. If you want quicker (20 minutes or less), get a
kerosene-fired flame-thrower and duct that up.
These recommendations are worth exactly what you paid for them..
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old November 11th 03, 01:18 PM
Larry Smith
doors open. - Mike
Gackkkkkk!, Michael. Build an aluminum plenum around an inexpensive
ceramic electric heater --- you know, the little cube-shaped things about 8
inches wide and 8 inches high and 8 inches deep. These little heaters have
a spark-less blower and are not hot enough to flash gasoline fumes. Round
out the business end of the plenum to fit dryer hose and run the hose into
your cowl. Blanket your cowl to hold in the heat. Go with it until your
oil temp cracks 100 degrees Fahrenheit.
Old November 11th 03, 05:05 PM
R. Hubbell
On Tue, 11 Nov 2003 04:44:14 -0500
doors open. - Mike
Fly it out to the California coast? No pre-heating needed here!
R. Hubbell
Old November 11th 03, 07:08 PM
Big John
Michael
Lots of suggestions. Here are more.
1. If I had to RON in cold country, paid for a hanger.
2. If parked outside, pulled engine through a dozen or so times. Then
gave the intake a shot or two of ether and cranked. When ether fired
engine would start running and you could then warm up normally prior
to take off.
Still have one or two of the little cans of ether on my msc. shelf in
shop. Can be bought at any auto parts store.
Small and light weight so can be thrown in baggage compartment and
forgotten until needed.
Big John
On Tue, 11 Nov 2003 04:44:14 -0500, Michael Horowitz
doors open. - Mike
Old November 11th 03, 09:12 PM
JFLEISC
Ed
October 2001 'Kitplanes' article. Tells you how to do just that for under $50.
Old November 11th 03, 11:07 PM
Michael Horowitz
BJ - Here is an article you may find interesting concerning cold
starts:
http://www.reiffpreheat.com/Article-Busch.htm
- Mike
Big John wrote:
Michael
to take off.
Big John
doors open. - Mike
