LS1c-d performance
Old June 10th 12, 06:39 PM posted to rec.aviation.soaring
csonka istvan
Default LS1c-d performance
The IGC HC of LS1c-d is 3 points lower than the LS1f (0.98-1.01). Why
is this differnece? The wings are the same, as I know. Does somebody
has any experiences with LS1c-d performance, compared to LS1f, Std.
Cirrus or ASW15? (Assuming more or less the same wingload).
Old June 11th 12, 01:44 PM posted to rec.aviation.soaring
Idaflieg data, as availble in the Thomas book on glider design, supports the difference. This was the subject of review by the US handicap subcommittee a couple of years ago. US handicap difference is 2.4% which reflects maybe a liyyle difference in the analysis. The difference in "opinions" is worth 6 pt/day.
FWIW
UH
Old June 11th 12, 03:12 PM posted to rec.aviation.soaring
csonka istvan
Thanks, yes, this is the "theory", but I would be nice to get real-
life experiences.
Old June 11th 12, 04:30 PM posted to rec.aviation.soaring
Tim Mara
LS1, LS1A-, LS1D are totally different gliders from LS1F, different
fueslage, different tail, cockpit even different wing construction, these
can hardly be even considered to be all the same
tim
pt/day.
FWIW
UH
Old June 11th 12, 07:08 PM posted to rec.aviation.soaring
csonka istvan
tim
Thanks Tim,
I know, that the fuselage is different, but I believe that the wings
are the same. But the question is the real performance comparism
between Ls1c-d and Ls1f, ASW15, Std. Cirrus.
Old June 11th 12, 10:06 PM posted to rec.aviation.soaring
Tim Mara
IMHO the LS1f should be consideribly better performer than ASW15 or Cirrus
and certainly handles far better than either of these and is more refined
than earlier LS1 as well, Ealry LS1 would be more similar to these in both
performance and construction to Cirrus and ASW15, ASW15B would be again a
better glider than earlier ASW15, larger cockpit than earlier ASW15 also.
tim
"csonka istvan" wrote in message
tim
Thanks Tim,
LS3A performance Rob Dunning Soaring 7 July 7th 07 03:38 PM
ASW 19b performance Jim Crowhurst Soaring 1 July 8th 05 01:31 PM
J-3 Performance MLenoch Piloting 9 November 17th 04 07:21 AM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Performance Propellers 60 x 66 Sammy Products 0 December 19th 03 01:57 AM
