Walt, interesting mount for the display. Looks like the standard
Butterfly backplate and Ram ball, but with a custom mount from the Ram ball to the siderail. Can share some information about your display mount installation? Bob On Wed, 20 Jun 2012 10:25:31 -0700 (PDT), WaltWX wrote: Follow up on PF Brick install: Photos of Discus 2A PowerFlarm antenna install on panel cover. ADS-B is forward antenna; FLARM is rear most one. The hook forward on panel cover is where I locate my SPOT tracker. GPS antennas are under cover between two PF top antennas (Volkslogger and PF GPS). ADS-B and FLARM antennas are taped to a piece of "L" shaped plexiglass (2x2x3 inches) all velcroed to panel top. Got the plexiglas from Staples Office and "hacked" it from the original purpose of displaying 81/2x11inch announcements. No compass to worry about. Interestingly enough, Discus 2A ops manual didn't require one nor did the FAA when I got my experimental certificate. RAM mounted Butterfly is also visible. https://dl.dropbox.com/u/463771/MyGl...a_SideView.JPG https://dl.dropbox.com/u/463771/MyGl...aButterfly.JPG Walt Rogers, WX |
On Jun 20, 6:19*pm, Bob Gibbons wrote:
Walt, interesting mount for the display. Looks like the standard Butterfly backplate and Ram ball, but with a custom mount from the Ram ball to the siderail. Can share some information about your display mount installation? Bob On Wed, 20 Jun 2012 10:25:31 -0700 (PDT), WaltWX wrote: Follow up on PF Brick install: Photos of Discus 2A PowerFlarm antenna install on panel cover. ADS-B is forward antenna; FLARM is rear most one. The hook forward on panel cover is where I locate my SPOT tracker. GPS antennas are under cover between two PF top antennas (Volkslogger and PF GPS). ADS-B and FLARM antennas are taped to a piece of *"L" shaped plexiglass (2x2x3 inches) all velcroed to panel top. Got the plexiglas from Staples Office and "hacked" it from the original purpose of displaying 81/2x11inch announcements. No compass to worry about. Interestingly enough, Discus 2A ops manual didn't require one nor did the FAA when I got my experimental certificate. RAM mounted Butterfly is also visible. https://dl.dropbox.com/u/463771/MyGl...d/PFlarm_Discu... https://dl.dropbox.com/u/463771/MyGl...d/PFlarm_Discu... Walt Rogers, WX Pardon the dumb question.............but does Power Flarm have a logger function at all right now? if so, is the mini SD the way to access the file? I bought the stand-alone unit and it is installed in my glider right now...........I have a cable on order to replace the Garmin puck that I am using to feed GPS to my Ipaq310.......the interface will be via a Goddard PS-5a, hope to just remove and replace the puck with the PF and make a change to LK8000 baud rate. Brad |
On Wed, 20 Jun 2012 18:26:07 -0700 (PDT), Brad
wrote: The IGC logger function is currently listed as a future upgrade (via software upload) for both brick and portable. For the portable, yes, the miniSD will be the access point. Bob .... text deleted. Pardon the dumb question.............but does Power Flarm have a logger function at all right now? if so, is the mini SD the way to access the file? I bought the stand-alone unit and it is installed in my glider right now...........I have a cable on order to replace the Garmin puck that I am using to feed GPS to my Ipaq310.......the interface will be via a Goddard PS-5a, hope to just remove and replace the puck with the PF and make a change to LK8000 baud rate. Brad |
Hi,
I believe Walt make his own RAM mount for the FLARM remote display. I sell a very nice one from Butterfly he http://www.cumulus-soaring.com/butte...-Disp-Rect-RAM Best Regards, Paul Remde Cumulus Soaring, Inc. _____________________________________ "Bob Gibbons" wrote in message ... Walt, interesting mount for the display. Looks like the standard Butterfly backplate and Ram ball, but with a custom mount from the Ram ball to the siderail. Can share some information about your display mount installation? Bob On Wed, 20 Jun 2012 10:25:31 -0700 (PDT), WaltWX wrote: Follow up on PF Brick install: Photos of Discus 2A PowerFlarm antenna install on panel cover. ADS-B is forward antenna; FLARM is rear most one. The hook forward on panel cover is where I locate my SPOT tracker. GPS antennas are under cover between two PF top antennas (Volkslogger and PF GPS). ADS-B and FLARM antennas are taped to a piece of "L" shaped plexiglass (2x2x3 inches) all velcroed to panel top. Got the plexiglas from Staples Office and "hacked" it from the original purpose of displaying 81/2x11inch announcements. No compass to worry about. Interestingly enough, Discus 2A ops manual didn't require one nor did the FAA when I got my experimental certificate. RAM mounted Butterfly is also visible. https://dl.dropbox.com/u/463771/MyGl...a_SideView.JPG https://dl.dropbox.com/u/463771/MyGl...aButterfly.JPG Walt Rogers, WX |
I would also expect PowerFLARM to support standard FLARM style downloading
of the IGC file via its serial port to PDAs/computers etc. Widely supported in existing 3rd party applications (SeeYou, ConnectMe, XCSoar, etc.) and in FlarmTool. Darryl Bob Gibbons wrote: On Wed, 20 Jun 2012 18:26:07 -0700 (PDT), Brad wrote: The IGC logger function is currently listed as a future upgrade (via software upload) for both brick and portable. For the portable, yes, the miniSD will be the access point. Bob ... text deleted. Pardon the dumb question.............but does Power Flarm have a logger function at all right now? if so, is the mini SD the way to access the file? I bought the stand-alone unit and it is installed in my glider right now...........I have a cable on order to replace the Garmin puck that I am using to feed GPS to my Ipaq310.......the interface will be via a Goddard PS-5a, hope to just remove and replace the puck with the PF and make a change to LK8000 baud rate. Brad |
Here a picture of the attach point for the RAM mount (9/16inch ball).
https://dl.dropbox.com/u/463771/MyGl..._PNA_Mount.JPG |
Volkslogger downloads with high-speed serial port & OLC submission | Bill Daniels | Soaring | 4 | April 18th 06 06:11 AM |
USB-to-serial converters that work (especially with ILEC SN10) ? | [email protected] | Soaring | 35 | May 27th 05 09:58 AM |
FS - ILEC SN10 and Volkslogger | Dave Springford | Soaring | 0 | March 7th 05 12:43 AM |
5 volt DC power converters | John Ferguson | Soaring | 6 | February 28th 04 07:15 AM |
