Tow hook max wt marking
Old June 29th 12, 03:43 AM posted to rec.aviation.soaring
Karen
Default Tow hook max wt marking
Simple question, but why are tow hooks marked, "1200 lbs Max weight",
like the Schweitzer type release, towing big heavy 21M ships, ships
with water, Grobs and others over 1300 lb gross weights? Actual
pulling weight? Is there an FAR? Thanks.
Old June 29th 12, 01:20 PM posted to rec.aviation.soaring
Tony[_5_]
1200 lbs on the towhook refers to the maximum rope strength, not the maximum glider weight.
Old June 29th 12, 05:25 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
like the Schweitzer type release, towing big heavy 21M ships, *ships
And if you trace it back far enough, it probably stems from an old
NACA study on glider towing loads from the 1930s where they said "We
don't think there is ever a case where you could apply more than 1200
lbs load to a glider tow hook." And thus, we in the US are saddled
with a tow hook limitation from the days of 800 lb max weight two seat
gliders from the 1930s.
Old June 29th 12, 08:13 PM posted to rec.aviation.soaring
Karen
1200 lbs on the towhook refers to the maximum rope strength, not the smaximu glider weight.
lbs load to a glider tow hook." *And thus, we in the US are saddled
Thank you. So there is no FAR, just various 337's and field approvals?
Old June 29th 12, 08:43 PM posted to rec.aviation.soaring
Tony[_5_]
from what i've seen the max load allowed on the towhook is usually specified in the documentation for the installation. so yes, no FAR.
Old June 30th 12, 03:58 AM posted to rec.aviation.soaring
T[_2_]
from what i've seen the max load allowed on the towhook is usually specified in the documentation for the installation. *so yes, no FAR.
The FARs only specify the weak link requirements.
Old July 2nd 12, 05:55 PM posted to rec.aviation.soaring
Giganews[_3_]
A tow hook installation done in accordance with AC 43.13-2B section 807 will
include a PLACARD stating the maximum tow line strength (1200 lbs for
Schewitzer). The installation paperwork for my Tost hook says 750 daN (1686
lbs). FAR 91.9 says no person may operate a civil aircraft without
complying with the operating limitations specified in the approved Airplane
or Rotorcraft Flight Manual, markings, and PLACARDS, or as otherwize
prescribed by the certificating authority of the country of registry.
So there is an FAR.
The POH for many glliders includes a maximum rope breaking strength, which
must be adhered to according to FAR 91.9.
4RL
weight",
ships
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
Marking sheetmetal Michael Horowitz Home Built 41 September 23rd 06 05:25 PM
CG Hook for SGS 2-33 Rusty Soaring 0 November 23rd 05 12:15 PM
Wire marking Scott Vetter Restoration 1 December 1st 04 03:23 AM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 06:20 AM
