PowerFLARM antenna mounts
Old July 7th 12, 08:34 AM posted to rec.aviation.soaring
bumper[_4_]
Default PowerFLARM antenna mounts
On Friday, July 6, 2012 7:45:45 PM UTC-7, noel.wade wrote:
compare it to the yaw string!
I happen to like your yaw string! (grin)
bumper
Old July 7th 12, 02:27 PM posted to rec.aviation.soaring
Andy[_1_]
On Jul 5, 9:10*am, bumper wrote:
As to making the antenna out of very thin wire; from my Nave ET days, a thin antenna element has a more narrow bandwidth. Since flarm uses a frequency hopping protocol (I think from 885 to 915 Mhz), thin may not work very well.
lower freq 902.20000000 upper freq 927.80000000
Source - FCC application for PFP (no application, or other
certification data, published for PFB).
Old July 9th 12, 06:31 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
We are all faced with fitting these things to legacy gliders of varying geometry and materials. The carbon fibre fuselage seems to pose most problems.
I hope glider designers in future make installation of transponders, Flarm and PowerFlarm etc. easier, without dead spots or vision impairment.
Chris N
Old July 9th 12, 07:31 AM posted to rec.aviation.soaring
FLARM
We have published an Application note for the FLARM antenna installation:
http://powerflarm.us/manuals-softwar...release-notes/
Deep link:
http://powerflarm.us/wp-content/uplo...e_ANTENNAS.pdf
Still a bit raw, but we will update it with more pictures and examples.
Old July 9th 12, 02:24 PM posted to rec.aviation.soaring
Deep link:
Looking at page 6, there is a much less offensive 1/4 wave antenna shown that Flarm folks say works well.
Any of you expert guys have an idea where we get on of these?
Thanks
UH
Old July 9th 12, 02:26 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Deep link:
Excellent,
How do I get one of the 1/4 wave whip antenna's shown on p6 of the Application Note? Who it the manufacturer and what is the part number?
QT
Old July 9th 12, 03:10 PM posted to rec.aviation.soaring
There must be some company that builds a nice FLARM compatible 1/2 wave
length base fed antenna similar to the one in the following link.
http://www.spectrumaudio.com/shure-u...FSZntgodnQJgIQ
W7ADK
http://www.soaridaho.com/
"John Godfrey (QT)" wrote in message
Deep link:
Excellent,
QT
  #28
Old July 9th 12, 03:57 PM posted to rec.aviation.soaring
FLARM
Mobile Mark PSTG0-925SE
http://www.tessco.com/products/displ...13&eventPage=1
It is a 'special order' item, but as of this morning they have some in stock.
Note that the length and picture on the Tessco site are incorrect.
Actual length is 2 7/8 inch. Datasheet is he
http://powerflarm.us/wp-content/uplo...STG0-925SE.pdf
Don't bug the manufacturer (Mobile Mark) about these; they have a minimum order quantity of 250pcs...
Disclaimer:
This is not a product that FLARM has tested, supplies or officially endorses.
It will require the installation of a suitable ground plane and coaxial cables to work properly. Please do not ask us for individual support on this type of installation.
That being said; if installed well, this can be very slick...
  #29
Old July 10th 12, 05:54 AM posted to rec.aviation.soaring
Richard[_9_]
> Deep link:
Thanks
UH
Craggy Aero will have something similar in about a week
Richard
www.craggyaero.com
  #30
Old July 10th 12, 06:34 AM posted to rec.aviation.soaring
Matt Herron Jr.
W7ADK
> Deep link:
Excellent,
QT
I won't be buying powerFlarm until the antenna installation is as unobtrusive as my Transponder. Di-pole sticking up above the glare shield doesn't cut it. Figure out another way. You have plenty of headroom to boost the power and use a less efficient 1/2 or 1/4 wave antenna. PowerFlarm needs to step up and fix this problem.
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFlarm antenna install Sam Zimmerman Soaring 10 November 11th 10 09:54 PM
Suction cup mounts Ed Winchester[_2_] Soaring 2 September 18th 09 03:58 AM
PDA mounts Mhudson126 Soaring 10 May 19th 04 07:24 PM
Commercial - New PDA mounts from RAM Paul Remde Soaring 0 September 11th 03 06:27 AM
