#21
Mxsmanic wrote:
writes: The point MX misses is that there is no such thing as a Nav device certified for VFR flight other than the Mark I eyeball and a chart; everything else is backup for VFR flight. I haven't missed it, but many pilots do, since they start relying on other navigation methods as their primary methods regularly--especially GPS. And you know this how? And even if true, this is a problem how; by the non-existant huge numbers of pilots getting lost or violating airspace other than TFR violations, which is a separate issue? Another point you seem to have missed is that GPS displays a map and in VFR flight you compare what you see on the map to what you see through the window. |
#24
Mxsmanic wrote:
writes: The temptation can be strong to strangle some ass hole that really ****es one off but most people are able to resist the temptation to commit a crime. They may still talk about it constantly like schoolchildren, however. It can cloud or eliminate their ability to hold a rational discussion. Yeah, so what, even if true, which you have not established, and is irrelevant whether you do or not? Holding a rational discussion wasn't the issue being discussed, the issue was resisting the temptation to violate a regulation/law. |
#25
#26
#27
Mxsmanic wrote:
writes: And you know this how? Because I actually do know how GPS works. Irrelevant to the question asked. And even if true, this is a problem how; by the non-existant huge numbers of pilots getting lost or violating airspace other than TFR violations, which is a separate issue? Pilots rely on GPS for a lot more than just TFRs (actually, TFRs require more than just GPS). They tend to rely upon GPS completely, even to the point of never looking out the window. They don't realize their mistake until they hit a mountain. First, few GPS used for VFR will display TFRs no matter what you have; soon but not yet for the most part. But more importantly, where is your data that shows VFR pilots are hitting mountains or anything else because they are staring at the GPS? This points out another vulnerability: incorrect map data combined with a GPS, which is even less reliable than GPS itself. Potential vulnerabilities of GPS are irrelevant to the issue at hand. Another point you seem to have missed is that GPS displays a map and in VFR flight you compare what you see on the map to what you see through the window. GPS has no notion of maps. The GPS unit may display a map, but the map comes from a database that is independent of the GPS receiver and may or may not be accurate. It's important to allow for that, too. This is a bunch of babble that boils down to a GPS displays a map. Where the map came from is irrelvant. In VFR flight you compare what you see on the map to what you see through the window. |
#28
Am 25.07.2012 08:02, schrieb Mxsmanic:
John Clear writes: I wouldn't call an Mx an old timer. He was only around for the last bit of the life of this group. If you mean me, I've been posting to this group for a decade. .... and you did all the best to help destroy the climate in this group. so: get lost! #m -- "What would I do with 72 virgins? That's not a reward, that's a punishment. Give me two seasoned whores any day." (Billy Connolly) |
#29
Mxsmanic wrote: John Clear writes: I wouldn't call an Mx an old timer. He was only around for the last bit of the life of this group. If you mean me, I've been posting to this group for a decade. This group hasn't had much life in the past decade, so my point stands. I've been around since before the rec.aviation split in the early 90s, and I consider myself a newbie in these parts, compared to the real old timers from the net.aviation days. John -- John Clear - http://www.clear-prop.org/ |
#30
Martin Hotze writes:
... and you did all the best to help destroy the climate in this group. I'm afraid not. It was the kiddies that drove people out of the group, and I'm not a kid. |
La Ferté Oldtimers 2012 - 3 - 16/17 - 20120527_lffq_yak11_dfjii_4234.JPG (1/1) - 381 kb | D. St-Sanvain | Aviation Photos | 0 | June 12th 12 05:39 AM |
La Ferté Oldtimers 2012 - 3 - 08/17 - 20120526_lffq_yak11_faznn_1213.JPG (1/1) - 218 kb | D. St-Sanvain | Aviation Photos | 0 | June 12th 12 05:38 AM |
La Ferté Oldtimers 2012 - 3 - 07/17 - 20120526_lffq_t6m0_fazzm_1132.JPG (1/1) - 314 kb | D. St-Sanvain | Aviation Photos | 0 | June 12th 12 05:38 AM |
La Ferté Oldtimers 2012 - 3 - 06/17 - 20120526_lffq_t6g_fazbq_1123.JPG (1/1) - 395 kb | D. St-Sanvain | Aviation Photos | 0 | June 12th 12 05:38 AM |
La Ferté Oldtimers 2012 - 1 - 01/17 - 201205_lffq_1.JPG (1/1) - 236 kb | D. St-Sanvain | Aviation Photos | 2 | June 10th 12 01:12 PM |
