On Friday, July 27, 2012 2:02:51 PM UTC-7, 2G wrote:
Yesterday I had a near miss (100 ft) with another glider with a FLARM brick. I had my transponder on, but it didn't matter because the FLARM was in-op. He had noted previously that the FLARM seemed to shut down when the battery voltage dipped below 12.5 V. He confirmed that by switching to his backup battery which was at a higher voltage; the FLARM shut down again when the voltage of the backup also dropped below 12.5. I checked the manuals of the Power FLARM and the FLARM brick and could not find a specification for operating voltage, except the FLARM listed 12-28 VDC, but not an explicit minimum voltage. Question: what IS the minimum voltage? Opinion: if FLARM suffers from reliability issues such as these their usefulness will become virtually nonexistent. Thanks, Tom I just measured the current draw on the Brick Power Flarm to be 177 to 182 mAH. Using the small rectangular display. This info was not given in the manual. I believe it is because of the various power outputs the brick can supply this number will vary directly on installation variables. Battery voltage in my case was 12.8 VDC. Tom 44 |
On Monday, July 30, 2012 2:55:01 PM UTC-7, Discus 44 wrote:
On Friday, July 27, 2012 2:02:51 PM UTC-7, 2G wrote: Yesterday I had a near miss (100 ft) with another glider with a FLARM brick. I had my transponder on, but it didn't matter because the FLARM was in-op. He had noted previously that the FLARM seemed to shut down when the battery voltage dipped below 12.5 V. He confirmed that by switching to his backup battery which was at a higher voltage; the FLARM shut down again when the voltage of the backup also dropped below 12.5. I checked the manuals of the Power FLARM and the FLARM brick and could not find a specification for operating voltage, except the FLARM listed 12-28 VDC, but not an explicit minimum voltage. Question: what IS the minimum voltage? Opinion: if FLARM suffers from reliability issues such as these their usefulness will become virtually nonexistent. Thanks, Tom I just measured the current draw on the Brick Power Flarm to be 177 to 182 mAH. Using the small rectangular display. This info was not given in the manual. I believe it is because of the various power outputs the brick can supply this number will vary directly on installation variables. Battery voltage in my case was 12.8 VDC. Tom 44 Tom, What do you estimate the total current draw is for both display and power flarm (transmitting, etc.)? Thanks, Old Dog |
On Monday, July 30, 2012 11:36:23 PM UTC-4, (unknown) wrote:
On Monday, July 30, 2012 2:55:01 PM UTC-7, Discus 44 wrote: On Friday, July 27, 2012 2:02:51 PM UTC-7, 2G wrote: Yesterday I had a near miss (100 ft) with another glider with a FLARM brick. I had my transponder on, but it didn't matter because the FLARM was in-op. He had noted previously that the FLARM seemed to shut down when the battery voltage dipped below 12.5 V. He confirmed that by switching to his backup battery which was at a higher voltage; the FLARM shut down again when the voltage of the backup also dropped below 12.5. I checked the manuals of the Power FLARM and the FLARM brick and could not find a specification for operating voltage, except the FLARM listed 12-28 VDC, but not an explicit minimum voltage. Question: what IS the minimum voltage? Opinion: if FLARM suffers from reliability issues such as these their usefulness will become virtually nonexistent. Thanks, Tom I just measured the current draw on the Brick Power Flarm to be 177 to 182 mAH. Using the small rectangular display. This info was not given in the manual. I believe it is because of the various power outputs the brick can supply this number will vary directly on installation variables. Battery voltage in my case was 12.8 VDC. Tom 44 Tom, What do you estimate the total current draw is for both display and power flarm (transmitting, etc.)? Thanks, Old Dog FWIW, my PF Brick + Rectangular external display measure 150MA. -Jim |
On Jul 30, 8:36*pm, wrote:
On Monday, July 30, 2012 2:55:01 PM UTC-7, Discus 44 wrote: On Friday, July 27, 2012 2:02:51 PM UTC-7, 2G wrote: Yesterday I had a near miss (100 ft) with another glider with a FLARM brick. I had my transponder on, but it didn't matter because the FLARM was in-op. He had noted previously that the FLARM seemed to shut down when the battery voltage dipped below 12.5 V. He confirmed that by switching to his backup battery which was at a higher voltage; the FLARM shut down again when the voltage of the backup also dropped below 12.5. I checked the manuals of the Power FLARM and the FLARM brick and could not find a specification for operating voltage, except the FLARM listed 12-28 VDC, but not an explicit minimum voltage. Question: what IS the minimum voltage? Opinion: if FLARM suffers from reliability issues such as these their usefulness will become virtually nonexistent. Thanks, Tom I just measured the current draw on the Brick Power Flarm to be 177 to 182 mAH. *Using the small rectangular display. *This info was not given in the manual. *I believe it is because of the various power outputs the brick can supply this number will vary directly on installation variables. Battery voltage in my case was 12.8 VDC. Tom 44 Tom, What do you estimate the total current draw is for both display and power flarm (transmitting, etc.)? Thanks, Old Dog Dave: The numbers I listed are inclusive of the brick and small rectangular display. I believe the variable numbers were the draw during the transmission cycle. Where this number can vary greatly is if you are to power your PDA from the "bricks" 9 pin D-Sub connector witht the 5VDC rated at 700mAH. Depends on your PDA power consumption. Ar you asking me about the aircraft total system power consumption? I did not measure that just the Flarm system. Tom |
| US Power FLARM Antennas | Andy[_1_] | Soaring | 13 | June 21st 12 08:34 AM |
| Power FLARM deliveries? | Andy[_1_] | Soaring | 1 | June 5th 12 02:33 PM |
| Portable Power Flarm for sale | [email protected] | Soaring | 1 | June 2nd 12 02:14 AM |
| Power FLARM question | Kimmo Hytoenen | Soaring | 26 | March 23rd 12 05:28 AM |
| Power FLARM portable reports? | Andy[_1_] | Soaring | 2 | December 9th 11 04:58 PM |
