JSF and close air support
Old March 15th 04, 11:46 AM
Paul F Austin
"John R Weiss" wrote in message
"Tarver Engineering" wrote...
As the rest of the thread up to this point indicates, there is a
desire to
redirect a GPS guided munition post launch. The means to reprogram
the munition would require some data link.
Irrelevent.
GPS with FOG does all that already.
Fibre Optic Gyro.
AMSTE (Affordable Moving Surface Target Engagement) uses a post-release
data
link to compensate for the long time of flight of the ballistic weapon
used
(JDAM).
We already discussed that and Weiss just wanted to argue.
Actually I wanted to debunk your inaccurate claims regarding a
"require[d]" data
link and some "GPS with FOG" system that "does all that already."
While data link is one method to accomplish the mission, there are other
methods
in development, and have been for many years.
From Paul's description of the current state of AMSTE, it does not appear
to yet
be ready for deployment in a CAS scenario. Maybe it will get there; maybe
not.
Maybe we will have to spend the $$ for a true autonomous terminal seeker
for
those situations where risk to the troops is too high for
non-terminally-guided
weapons and/or data link is not an option.
The various flavors of Mav already give us a linkless approach to precision
kill of moving targets but despite being in production forever, the cost is
too high (and requires good visibility).
AMSTE uses RADAR as the primary sensor and the link allows weapons release
above the cloud deck. That may be one of the drivers for the overall
architecture (which knowledge I've derived entirely from reading AvWeek and
IDR).
Whether CAS strikes will be allowed without visual confirmation of FLOT and
target is a doctrinal issue but a lot will depend on the development
trajectory of Blue Force Tracking (BFT) as well as of the AMSTE technology
set..
None of this stuff is Ready For Prime Time yet. AMSTE in particular is in an
Advanced Developement stage. Northrop-Grumman just demonstrated successful
geolocation and strike of a moving target using a single airborne RADAR
sensor. All prior tests had used two airborne sensors to get the spatial
resolution needed.
It seems to me that a major advantage of a data linked approach to CAS
strikes, whether RADAR as a primary sensor or not is the ability to update
aimpoints while the weapon is in flight. That's not a new thing, being the
way AGM-130 works. Data links are becoming ubiquitous around the battlefield
these days. In the case of a command link to a weapon in flight, the link is
geometrically resistant to jamming in addition to the more conventional AJ
techniques.
  #32
Old March 15th 04, 09:49 PM
B2431
methods
Can you be any more vague? Try limiting your posts to just one or two
verifyable facts and fill the rest with the fog of
uncertainty.
Venik
www.aeronautics.ru
Take your own advise. Is the B-2 the Serbs shot down still being studied in
Yugoslavia?
Dan, U. S. Air Force, retired
  #33
Old March 16th 04, 03:25 AM
John R Weiss
"Paul F Austin" wrote...
Add to that the various laser-guided munitions already available, either with
direct target designation from the ground or indirect target ID (traditional
9-line brief, "100 meters south of the smoke", etc...), and there are avariety
of "linkless" options to terminal guidance. Each has its advantages and
limitations. I suspect there will be an analogous mix in the future as well.
IDR).
set..
That (visual confirmation) will likely be a primary issue for the foreseeable
future. During early development, the USMC was VERY skeptical of JSOW (then
AIWS) as a CAS weapon, even with uplinked target coordinates, because of lack of
confidence in its CEP (especially with a CBU loadout), the long weapon time of
flight, and inability to abort the weapon once launched. Since CAS is by
definition conducted very close to friendly forces, it will take a major
doctrinal change to embrace non-visual target ID and weapon designation.
techniques.
It will be interesting when the data link controller is in the hands of the FAC
on the ground!
  #34
Old March 16th 04, 11:17 AM
Venik
It's already at Whiteman getting a new crome coat.
Venik
www.aeronautics.ru
"B2431" wrote in message ...
methods
uncertainty.
Venik
www.aeronautics.ru
Yugoslavia?
