Missile skid turns?
Old March 15th 04, 03:53 PM
Jim Doyle
Default Missile skid turns?
Recently I've been reading about the UK BVRAAM project.
One question really:
Originally it had four mid-fuselage wings for manoeuvrability, now it has
none. This seems a little odd, since it makes sense that the more agile
missile will have a greater number of control surfaces.
Since then I've found that the new design shall use bank and turn at long
range, and in the immediate short term prior to the kill - skid turns. How
do you skid a missile at 2M+? Exhaust deflection? If anyone can explain, I'd
be very grateful!
Cheers,
Jim Doyle
Old March 15th 04, 06:31 PM
Orval Fairbairn
be very grateful!
Cheers,
Jim Doyle
The missile body at M2+ has enough aerodynamic forces acting on it that
it doesn't need wings. All you have to have is a method of attitude
control.
Old March 15th 04, 07:47 PM
Jim Doyle
"Orval Fairbairn" wrote in message
news ...
has
long
How
I'd
be very grateful!
Cheers,
Jim Doyle
control.
For the portion of the flight time that it is making distance on it's target
then I guess so. With a decent sized warhead, casing and other gubbins the
thing's going to have one hell of a lot of momentum cracking along, upon
reaching it's target it'll need to be agile to not be spoofed by evasive
action, so how'd you steer it without control surfaces?
Old March 15th 04, 07:57 PM
Keith Willshaw
"Jim Doyle" wrote in message
news
target
It has tail control surfaces , it just seems to lack the
mid fuselage wings seen on some other designs
http://www.mod.uk/dpa/projects/bvraam.htm
Keith
Old March 15th 04, 08:06 PM
John Carrier
I saw a test shot of the Agile proof of concept design (stillborn in the
late seventies) that appeared to do a square corner turn. Slow motion had
the wingless missile (used thrust vectoring) at about 120 degrees AOA as it
turned. Most impressive.
R / John
I'd
be very grateful!
Cheers,
Jim Doyle
Old March 15th 04, 08:41 PM
Jim Doyle
"Keith Willshaw" wrote in message
news
target
Keith
Cheers Keith. However I think these vanes are used for the bank and turn
corrections at long range, and not the short term agile 'skid' manoeuvres. I
haven't been able to find anything on the latter so'll just guess at it
being a layman's thrust vectoring!
Old March 15th 04, 09:49 PM
Jeb Hoge
"Jim Doyle" wrote in message ...
be very grateful!
Cheers,
Jim Doyle
And to add to this, do all missiles roll to fly with wings in a
horiz/vert (+) attitude or are there some types that fly at in an "X"
attitude? Darn things always are moving so fast that it's hard to
say, but since they obviously can come off the rail or ejectors in
either attitude, I'd assume that there's some sort of correction in
one of the two cases.
Old March 16th 04, 04:02 AM
Peter Stickney
(Jeb Hoge) writes:
be very grateful!
Cheers,
Jim Doyle
At a guess, I'd say that most post-1960 missiles try to orient
themselves into the 'X' position. in addition to allowing control
surfaces on all 4 wings (or canards or tail controls) to contribute to
the maneuver, you gain a factor of 1.4 in structural strength, since
the lift forces are spread among all 4 wings. As an example, the Nike
Herculese SAM originally started out with a '+' orinetation in flight,
and a 10 G strucural limit. Restringing the control laws to allow an
'X' orientation upped the G limit to 14, without structural
modifications.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old March 16th 04, 02:52 PM
Jeff Crowell
I
Hi, Jim.
I'm no missile expert, but I think what's at play here is this:
At long range, the missile makes gentle maneuvers to maintain as
much energy as possible, using body lift to generate angles. Very
little slew is all that's needed at such speeds, the change in air
flow over the body generates lift and thereby changes the flight
path (angles). It's a pretty efficient, low drag way to do business.
At close range, in the terminal phase, where agility (angle
generation) is more important than maintaining energy, the fins
actuate much more aggressively, slewing the missile body past
angles which would just generate body lift, to reorient the
airframe for a different flight path. At this point you are either
bleeding energy off during a coast intercept (like a Phoenix
missile does in long range profile), or depending on a long-burn
motor to keep up your smash.
To me, that would certainly equate to skid turns. Think of a
sprint race car drifting through a turn, versus steering through it.
Jeff
Why is a standard hold right turns? Roy Smith Instrument Flight Rules 51 August 28th 04 06:09 PM
The F-102 Delta Dagger (Was GWB as a Nat'l Guard Fighter Pilot threads.) David E. Powell Military Aviation 59 February 19th 04 03:18 AM
V-4 Missile Possibilities robert arndt Military Aviation 42 January 23rd 04 05:40 AM
Australia to participate in US missile defence program David Bromage Military Aviation 40 December 13th 03 01:52 PM
Surface to Air Missile threat PlanetJ Instrument Flight Rules 1 August 14th 03 02:13 PM
