Atlanta FSDO and operational limitations for experimental(exhibition/air racing) sailplanes
Old August 6th 12, 09:17 PM posted to rec.aviation.soaring
Default Atlanta FSDO and operational limitations for experimental(exhibition/air racing) sailplanes
Does anyone have experience with buying a used sailplane and getting a new special airworthiness certificate and operational limitations letter from the Atlanta FSDO? If so i would appreciate a chance to talk with you and/or get a copy of the operational limitations you were issued. You can call me (706 348-1617) or email ).
Many thanks,
Key
Old August 10th 12, 11:50 AM posted to rec.aviation.soaring
kammeyer
Perhaps this is obvious, but they should be issuing them based on this:
http://www.faa.gov/regulations_polic...umentID/324850
It's really a paint-by-numbers system, and while they do have discretion, they should generally just issue the exact language and sections specified in that document.
-Dave
Many thanks,
Key
(USA) FSDO inspections of Experimental gliders Tuno Soaring 12 January 8th 10 06:05 AM
Association for Experimental Sailplanes? Jim Meade Soaring 2 March 6th 08 06:35 PM
Heres to the old guys, racing, but not sailplanes. pbc76049 Soaring 0 October 13th 06 09:13 PM
Registering a Warbird with the FAA (Experimental Operating Limitations) [email protected] Owning 21 October 11th 05 01:52 AM
Experimental exhibition limitations question Comcast Soaring 7 October 1st 05 06:45 AM
