Butterfly iGlide App now available in the US
Old August 21st 12, 03:29 PM posted to rec.aviation.soaring
Default Connect iPhone to CAI302
What do I need to connect iPhone to CAI302, and where can I buy these cables in the US. I see on the Butterfly website two cables one for LX and one for CAI, are these the only cables required in each situation. Do they convert iPhone's USB to serial and supply power back to iPhone?
Old August 21st 12, 05:00 PM posted to rec.aviation.soaring
Marc - Butterfly Avionics
Jason,
this is unfortunately not as easy. The cables we supply in Europe only work with our european WiFi solution that wirelessly interfaces third party NMEA-equipment to iOS devices. In the US the module is not allowed due to regulatory reasons.
We are working on a worldwide bluetooth solution which is planned to be sold by early 2013.
Best wishes
Marc
Old August 21st 12, 06:25 PM posted to rec.aviation.soaring
jfitch
On Tuesday, August 21, 2012 9:00:11 AM UTC-7, Marc - Butterfly Avionics wrote:
Jason,
Best wishes
Marc
There are NMEA to Bluetooth bridges currently available in the USA, built for the boat market. Could not these be used?
Old August 21st 12, 06:42 PM posted to rec.aviation.soaring
Max Kellermann
AFAIK, Bluetooth is locked down on Apple products, and only available
to certain partners (not including Butterfly). Therefore, Butterfly
had to avoid Bluetooth and use WiFi instead. The problem is of
political nature, not technical.
These political problems are the reason why I decided not to port that
other software to the iPhone.
Old August 21st 12, 09:11 PM posted to rec.aviation.soaring
Default Butterfly iGlide App now available in the US
On Thursday, August 9, 2012 8:08:11 AM UTC-4, Marc - Butterfly Avionics wrote:
Hello everybody,
iGlide, our iOS gliding navigation application is now in made available today in the USA and Canada. We have just released it and await Apple to activate it any minute. You can download it directly on the Apple AppStore.
iGlide has been incredibly successful in Europe. Our Team worked hard to get it ready for the US market, the main work was integrating necessary data and market specific functionality such as different units etc.
iGlide comes in three editions. As a start you can try the "lite edition" (priced $29,99) that features basic functionality. Additional features of higher editions can be directly purchased inside iGlide later on.
Some information can be found on our Youtube channel, many more videos to come: http://www.youtube.com/user/ButterflyAvionics
The iGlide manual and additional information is available he http://www.butterfly.aero
Thanks for your feedback and best regards
Marc
Marc
Will we have map for Canada?
Thanks
Gilles
C
Old August 22nd 12, 06:12 AM posted to rec.aviation.soaring
thats true. We are currently undergoing a certification process at apple to unlock bluetooth capability in iGlide. Apple is very cooperative, however this will take until end of the year.
Old August 22nd 12, 06:13 AM posted to rec.aviation.soaring
Hello everybody,
Marc
Marc
Thanks
Gilles
C
Gilles,
we are working on maps for canada, they will be released in the following weeks.
Marc
Old December 11th 12, 05:22 AM posted to rec.aviation.soaring
Marc, can I order a Butterfly interface module from the EUR butterfly store - then use that adapter with my copy of iGlide (bought in the US app store) to iGlide run on my IPhone connected to my 302 or volkslogger
Old December 11th 12, 03:08 PM posted to rec.aviation.soaring
Kevin Christner
Will this render full screen on an iPad or just in the small iPhone window.
Thanks
2C
Old December 11th 12, 04:08 PM posted to rec.aviation.soaring
Sean F (F2)
I began using iGlide in the fall on my iPhone 5. It is a very impressive interface. If I can integrate it with my V7 Vario NMEA output, it might be my choice next season. Right now, XC soar ticks all the boxes and works on a platform with far more choices. Also the cost $250 of the full features iGlide is very high.
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly vario info [email protected] Soaring 1 August 7th 12 10:08 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
This Just In- Butterfly [email protected] Soaring 6 February 17th 12 09:00 PM
