Wing-support for Duo one-person assembly
Old August 30th 12, 02:48 PM posted to rec.aviation.soaring
Dave Nadler
Default Wing-support for Duo one-person assembly
Hi All - I'm looking for recommendations for a
wing-dolly for solo assembly of the Duo Discus.
The one we have has broken for the umpteenth time.
I am very spoiled with the Lange unit that I
always use for self-assembly of my Antares 20E.
It is quick, easy, sturdy, and includes a gas-
strut to allow one-hand height adjustment (gas
spring matches weight of wing, with a lock that
is unlatched and re-latched with one's toe).
Unlike many rigging aids:
* It does not fall over while I pull the wing
out of the trailer.
* It rolls easily over uneven ground.
* It takes one hand to adjust the height, and I
do not have to crawl under the wing to adjust
the height.
* It does not lean dangerously.
* It does not damage the wing.
* It has no loose parts (two pieces in trailer)
* It requires no power
* It does not require extensive training to operate
I'm hoping to find something similarly easy
for our Duo. Any recommendations ?
Especially FIRST HAND experience from REGULAR use ?
Note that the Duo wing is HEAVY and HIGH OFF
THE GROUND. Very different from a 15m wing...
Thanks in advance,
Best Regards, Dave "YO electric"
Old August 30th 12, 04:26 PM posted to rec.aviation.soaring
Mike the Strike
out of the trailer.
the height.
Thanks in advance,
Dave:
Not sure that you'll be able to meet all those requirements, but I suggest you talk to Steve Koerner who manufactures the WingRigger here in Arizona. There are probably more of these in use in the USA than any others, so he must be doing something right!
Mike
Old August 30th 12, 05:10 PM posted to rec.aviation.soaring
RN
John Earlywine
I have similar issues with the DG-1000.
Mark Mocho where are you? Are you listening?
Old August 30th 12, 06:49 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Dave,
Are the wings comparable in weight? Make a Duo Cuff for your Antares rigger.
Just a thought
Steve
Old August 31st 12, 10:19 PM
Helge Zembold Helge Zembold is offline
Banned
First recorded activity by AviationBanter: Sep 2011
Hi Dave,
we have been using the wing dolly by IMI-Gliding (www.imi-gliding.com) for some time. Some mates from my club are using theirs also for a Janus and an Arcus M. They have modified it with bigger wheels for better stability. It also works with a gas spring which you fix with a screw.
We have also tested Cobra's wing dolly but found it to be to unstable.
However, we are always two when rigging the duo, it just takes too long alone.
Bye, Helge
Old September 2nd 12, 06:26 AM posted to rec.aviation.soaring
Morgan[_2_]
Hi Dave,
I have played around with the Wingrigger for single place ships with my Duo.. Steve makes an XC (extended chord) model for bigger ships. The single place model fit the Duo quite well, but needed a longer clamp, only about 5" more though. The XC model would be what I'd buy. Sturdy and well designed. Plenty of spring strength for the Duo wing and height as well.
I haven't bought one yet, but given the weight I am considering it. If only to help my wingtip person with the weight. Given the height at the tip, it's always awkward to transition from the low to high position.
Morgan
Old September 2nd 12, 08:27 AM posted to rec.aviation.soaring
I have the IMI-Gliding one man rigger for my Ventus cM, and it works fine. I frequently use the same device for the outboard wings of an ASH25 (no modifications) with no problems. The wings of the ASH are 85 kg and lighter than those of a Duo, but then my rigger aid is the one for single seaters. Nice stuff.
Old September 2nd 12, 06:31 PM posted to rec.aviation.soaring
JS
Did anyone buy Udo's tooling and leftover parts? Seems he wanted very little for the lot. YO it was in "your neck of the woods" too.
Old September 2nd 12, 07:44 PM posted to rec.aviation.soaring
When you lift the tip of the main wing panel to pull it out of the trailer, how many pounds are you lifting?
And what is the total piece weight of the DD inboard wing panel?
Old September 2nd 12, 09:58 PM posted to rec.aviation.soaring
Hi Dave!
I use the IMI single-seater for my Antares, In teh club we use the IMI double-seater version for the Arcus. I prefer the IMI over the Lange.
Have Fun
Hans
Am Donnerstag, 30. August 2012 15:48:49 UTC+2 schrieb Dave Nadler:
out of the trailer.
the height.
Thanks in advance,
Wing assembly dollies Udo Soaring 1 December 2nd 10 02:51 AM
USED One person assembly rig Tim Mara Soaring 0 May 1st 10 03:13 PM
assembly wing dolly Anoucement Udo Rumpf[_2_] Soaring 2 January 13th 09 06:53 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
USAFE commander: 86th Airlift Wing will divide for combat, support operations Otis Willie Military Aviation 0 November 27th 03 11:31 PM
