ClearNav Announces OLC Solution for Cambridge 10/20/25 Flight Recorders
Old September 18th 12, 07:01 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default ClearNav Announces OLC Solution for Cambridge 10/20/25 Flight Recorders
ClearNav Instruments is pleased to announce a software solution for
validation and scoring of OLC flights recorded on Cambridge GPSNav
model 10, 20 and 25 flight recorders. Instructions and necessary
files are located on the ClearNav Instruments site here
http://www.clearnav.net/main/cn-CAI-OLC.html
You will find a downloadable utility and a dll that should work on
(almost) any windows PC you are likely to be using, which will convert
your CAI files to OLC valid IGC files. Users please note that this is
an OLC specific solution and should not be used for badge and record
flights.
Special thanks to Guy Byars, Paul Seifried and David Hoppe.
-Evan Ludeman for ClearNav Instruments
Old September 18th 12, 07:58 PM posted to rec.aviation.soaring
flights.
Evan,
I know this is probably a stretch, but has anyone talked to the OLC regarding submitting logs that did not make the cutoff date? Maybe a temporary time window for folks to get there logs submitted. I'll bet there's lots of pilots with log files that are invalid because this solution was just now become available.
Any Thoughts?
Dave
Old September 18th 12, 11:54 PM posted to rec.aviation.soaring
Paul Remde
Well done! Awesome! Thank you!
Paul Remde
_____________
"Evan Ludeman" wrote in message
flights.
Old September 19th 12, 12:18 AM posted to rec.aviation.soaring
Morgan[_2_]
3 Cheers for making this happen. It's quite a service to the OLC pilots of the world using older Cambridge devices. Nice to know my CAI files are valid backups if needed, like this last weekend.
Paul Remde
_____________
flights.
Old September 24th 12, 04:09 AM posted to rec.aviation.soaring
CLewis95
Works great! .. (2) Greens on OLC from my Model 20
Old September 24th 12, 06:03 AM posted to rec.aviation.soaring
[email protected][_2_]
Thank you, Evan. Today's flight made it to 17,000' msl, and the OLC called it green. Thanks to your conversion file, no more blue balls.
OLC Solution for Cambridge GPS-Nav Evan Ludeman[_4_] Soaring 5 September 18th 12 09:21 PM
US Team Announces Winner of ClearNav Raffle John Godfrey (QT)[_2_] Soaring 2 September 27th 10 09:21 PM
Why so expensive (flight recorders) Jim Beckman Soaring 64 March 4th 08 03:18 PM
Revised IGC-approval documents for Cambridge and EW recorders Ian Strachan Soaring 3 April 13th 05 01:04 PM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 06:28 PM
