Battery Power
Old September 25th 12, 02:16 PM posted to rec.aviation.soaring
JohnDeRosa
Default Battery Power
I just helped a fellow pilot test his batteries because he was having in-flight issues with a low battery after just 2 hours. It turned out that his brand new 12Vdc 14Ah battery was defective.
We tested using a 1.2A load (http://aviation.derosaweb.net/#batterytest). His other batteries lasted 5-6 hours at that high load level. We measured his real load by adding one device at a time to the grid. The "all on" load at 1A (constant transmit, audio vario beeping, etc). The somewhat surprising big power hog turned out to be the charging of the battery in his PDA.
Old September 25th 12, 06:35 PM posted to rec.aviation.soaring
On Sunday, September 23, 2012 6:15:04 PM UTC-4, Mike McCarron wrote:
Help!
I have carefully measured my current draw in my glider at .8 amp. l would
like to know if there is any reasonable explanation for why a 9 amp hour
battery goes from 13 volts open circuit fully charged to 11.6 volts in 4
hours.
MC
Mike,
Get a K2-Energy Lithium-Iron-Phosphate battery (http://store.peakbattery.com/12lfpba.html). They are expensive, but *much* lighter than the corresponding SLA type, and *much* better performance.
TA
Old September 27th 12, 06:04 PM posted to rec.aviation.soaring
bumper[_4_]
Do a search on Shorai lithium. Less expensive than K2, especially on larger batteries. Available on Amazon too. No experience with them.
We live in interesting times, battery wise (and otherwise).
bumper
Old September 27th 12, 06:22 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
They are probably fine batteries for their intended purpose - starting
"powersports" vehicles, like snowmobiles, seados, etc. - but not for
powering equipment. Their amp hour rating is deceptive, because the amp
hour capacity mentioned is really about half the actual amp hour
capacity of the battery.
What they are selling you is a battery with same CCA rating (cold
cranking amps) as an SLA battery that has the amp hour rating Shorai
uses for it's "Powersports" battery. That's why it's cheaper - it's got
have the Lithium in it.
I'm not suggesting they are intentionally intending to deceive us, just
pointing out they use the amp hour rating in a manner confusing to
people who think it refers to capacity, and not "equivalent starting
performance".
email me)
Power FLARM power Andy[_1_] Soaring 9 June 6th 12 12:38 AM
battery power regulator Tony V Soaring 17 August 10th 11 05:39 AM
Oshkosh Camping - Battery Power Tom McQuinn Owning 3 June 11th 07 12:19 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
battery charger to get through Piper power port? Kyler Laird Owning 16 March 20th 05 12:08 AM
