Paso Warbirds Pt. III - 07
Old October 3rd 12, 11:53 AM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
Default Paso Warbirds Pt. III - 07
Regards,
Savageduck
Click image for larger version
Old October 4th 12, 01:07 AM posted to alt.binaries.pictures.aviation
Indrek[_5_]
"Savageduck" wrote in message
news:2012100302533491745-savageduck1@REMOVESPAMmecom...
Regards,
Savageduck
Thanks for posting these amazing shots.
If you don't mind my asking, what camera and lens and what post processing
did you use?
Cheers,
Indrek Aavisto
Criticism is easy; achievement is difficult W.S. Churchill
Old October 4th 12, 02:55 AM posted to alt.binaries.pictures.aviation
Indrek[_5_]
news:2012100317414116807-savageduck1@REMOVESPAMmecom...
Regards,
Savageduck
processing did you use?
Cheers,
Indrek Aavisto
The exif for all of those shots is intact, and I wasn't using anything too
exotic, a Nikon D300S and the Nikkor AF-S 70-300mm 4.5-5.6 G VR. I shot
AF-C continuos, with focus point tracking. I shot around 1,100 frames and
had to work through them for keepers. I am still working. ;-)
All of the shots I have cropped, made RAW adjustments in Lightroom 4, and
finished in CS5. I used NIK Define 2.0 for noise reduction, and then made
a few contrast/levels curve tweaks, added the "frame", and saved back to
lightroom.
-- Regards,
Savageduck
Thanks for the details. I'm surprised that you only rated these pictures at
two stars. I would have said at least 4.
I have the VRII version of the 70-300 lens, but can't seem to achieve your
levels of sharpness and detail with the lens on my D7000
Cheers,
Indrek Aavisto
Old October 4th 12, 03:46 AM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
Regards,
Savageduck
Cheers,
Indrek Aavisto
too exotic, a Nikon D300S and the Nikkor AF-S 70-300mm 4.5-5.6 G VR. I
shot AF-C continuos, with focus point tracking. I shot around 1,100
frames and had to work through them for keepers. I am still working. ;-)
and finished in CS5. I used NIK Define 2.0 for noise reduction, and
then made a few contrast/levels curve tweaks, added the "frame", and
saved back to lightroom.
-- Regards,
Savageduck
pictures at two stars. I would have said at least 4.
My rating in LR4 is meaningless, other than to separate the wheat from
the chaff, so I can filter the mass to workable numbers. I have rejects
flagged as rejects, I have those I am intending to work on rated with a
"star", usually from one to three, that is usually a selection made on
the fly. If there is one truly exceptional shot, which must attend to
immediately I will rate it at 4-5 "stars".
Then I second guess myself and go back to those left untouched to check
on them again, and inevitably I will find one with more potential than
others selected, and some more rejects.
So the "star" rating has nothing to do with a judgement on the final
result, just to stop me from going crazy, and have a workable number to
work on.
your levels of sharpness and detail with the lens on my D7000
You have the same lens as I do. The current 70-300mm has the VRII
process, but is VR on the lens. I also had the prior 70-300mm D which
was non-VR. The D7000 is well matched with that lens and with the
appropriate technique, settings and practice you should get similar
results. Also, for such dynamic targets don't reject AF-C, and 3D
Tracking. Trying to make things work with a single focus point at the
speeds involved is tough. So use some of the tools built into the
camera.
I was shooting 8-20 frames per pass knowing that not all were going to
be keepers. I have found that technique is the important thing. It is
also important to find a sweet spot within the pass route. Trying to
make captures at the extremes at either end can be a gamble, and I find
that is where the highest percentage of my rejects are to be found.
One of these days I will a rent longer, faster lens for one of these
events. As I am retired, I certainly can't afford to buy, or justify
buying exotic glass, but renting for a week or two, that is something
to consider.
Regards,
Savageduck
Old October 4th 12, 04:47 AM posted to alt.binaries.pictures.aviation
Indrek[_5_]
news:2012100318464275249-savageduck1@REMOVESPAMmecom...
Regards,
Savageduck
Cheers,
Indrek Aavisto
and finished in CS5. I used NIK Define 2.0 for noise reduction, and then
made a few contrast/levels curve tweaks, added the "frame", and saved
back to lightroom.
-- Regards,
Savageduck
My rating in LR4 is meaningless, other than to separate the wheat from the
"star", usually from one to three, that is usually a selection made on the
Then I second guess myself and go back to those left untouched to check on
them again, and inevitably I will find one with more potential than others
work on.
You have the same lens as I do. The current 70-300mm has the VRII process,
but is VR on the lens. I also had the prior 70-300mm D which was non-VR.
The D7000 is well matched with that lens and with the appropriate
technique, settings and practice you should get similar results. Also, for
such dynamic targets don't reject AF-C, and 3D Tracking. Trying to make
things work with a single focus point at the speeds involved is tough. So
use some of the tools built into the camera.
I was shooting 8-20 frames per pass knowing that not all were going to be
keepers. I have found that technique is the important thing. It is also
important to find a sweet spot within the pass route. Trying to make
captures at the extremes at either end can be a gamble, and I find that is
buying exotic glass, but renting for a week or two, that is something to
consider.
Regards,
Savageduck
Thanks for the tips.
For aircraft and birds I usually use AFC and manual aperture and shutter
speed with auto ISO. Maybe I should experiment with 3D tracking, something I
have not tried before..
The buffer fills on my camera pretty quickly, and the most I can get is
about 6 frames per burst, shooting RAW.
Clearly I'll have to practice more to improve my technique.
Cheers,
Indrek Aavisto
Old October 4th 12, 05:33 AM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
Regards,
Savageduck
Cheers,
Indrek Aavisto
-- Regards,
Savageduck
work on.
camera.
to consider.
Regards,
Savageduck
shutter speed with auto ISO. Maybe I should experiment with 3D
tracking, something I have not tried before..
Conditions not withstanding, I shot this batch at ISO 400, the light
was good so I stopped down to f/8 aperture priority resulting in
shutter speeds ranging from 1/400-1/800 second, good enough to retain
some prop blur.
For race cars where there is variable light on the track (in and out of
shade) I might use auto ISO and restrict the range to ISO 400-1600 and
remain at "A" mode. It is tough to deal with moving targets and
changing light in manual. There are some exceptions where I will use
shutter priority. The shot of the Tyrrell P34 below was taken with the
Nikkor 18-200mm VRII on the D300S.
(sorry for the OP low flying vehicle folks :-( )
With my D300S I have the MB-D10 battery-pack/grip which brings the
frame rate up to 9fps, and I shoot RAW only.
Cheers,
Indrek Aavisto
Regards,
Savageduck
Old October 4th 12, 06:51 AM posted to alt.binaries.pictures.aviation
Jeff Cochrane - VK4XA
news:2012100320333843658-savageduck1@REMOVESPAMmecom...
Regards,
Savageduck
Cheers,
Indrek Aavisto
-- Regards,
Savageduck
work on.
camera.
to consider.
Regards,
Savageduck
some prop blur.
Cheers,
Indrek Aavisto
Regards,
Savageduck
Yowsers,
A great shot of one of my favourite GP cars.
Thanks!
East Innisfail
QLD, Australia
Old October 4th 12, 07:13 AM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
On 2012-10-03 21:51:15 -0700, "Jeff Cochrane - VK4XA"
m said:
Le Snip
Yowsers,
Thanks!
Glad you liked it. I don't think this is the place for too many
automotive shots they are a bit OT for a.b.p.a. (eventhough
aerodynamics plays a part).So if they interest you here are a few of my
shots from Laguna Seca, California.
https://www.dropbox.com/sh/lx56l61b7...0Seca%20Extras
Regards,
Savageduck
Paso Warbirds Pt. III - 02 Savageduck[_3_] Aviation Photos 1 October 3rd 12 06:27 PM
Paso Warbirds Pt. III - 06 Savageduck[_3_] Aviation Photos 0 October 3rd 12 10:46 AM
Paso Warbirds Pt. III - 05 Savageduck[_3_] Aviation Photos 0 October 3rd 12 10:46 AM
Paso Warbirds Pt. III - 04 Savageduck[_3_] Aviation Photos 0 October 3rd 12 10:46 AM
Paso Warbirds Pt. III - 03 Savageduck[_3_] Aviation Photos 0 October 3rd 12 10:46 AM
