Aerobatics in semi acrobatic certified sailplanes
Old October 3rd 12, 03:17 PM
jams jams is offline
Junior Member
First recorded activity by AviationBanter: Oct 2012
Default Aerobatics in semi acrobatic certified sailplanes
Hi all,
I have recently become interested in gliding and have been exploring the aspects associated with the sport.
I'm going to use the term 'standard glider' to represent any non-acro 15m glider, (ASW 19/20, Speed Astir, LS range, DG range, PIK20D etc) not standard class.
I recently started looking at aerobatics and sailplanes certified for this. Started looking at datasheets for aircraft and most 'standard gliders' are semi aerobatic only, in addition to this some give g ratings. The most common I have found is +5.3 / -2.65. Seems to be almost a standard.
When I started looking at what maneuvers 'semi acrobatic' gliders could perform, the standard list seems to be loops, spins, chandelle, spiral dive.
I then came across some more advanced maneuvers like cuban 8, barrel rolls, inverted flight etc. I thought that these type of maneuvers would exceed the -g rating of -2.65, so wouldn't be feasible. Then I came across this you tube footage of a PIK20D doing some, what I think to be, serious aerobatics.
http://www.youtube.com/watch?v=tSB-JAFqrhU
Pretty sure there is some significant -g going on in some of these moves, however the PIK20D (according to the BGA datasheet) is only rated to -2.5g.
So what I'm asking is:
Is this still basic stuff, (just looks impressive too me!)?
What sort of -g would be experienced in these maneuvers, would it exceed -2.65?
Would other 'standard gliders' be able to do stuff like this (assuming they had the same g rating as the PIK)?
I did think for a minute that this was a brave chap wondering what it would take to snap the wings off, but on translating the German it says its part of his bronze acro training. So it must be signed off by some CFI somewhere?!
What do you think?
One interesting thing I came across was the g ratings for the
LAK-12...+6 -4...thats quite high up the g rating ladder, and pretty impressive for an 20.5m Open class machine!
Cheers
James
Old October 3rd 12, 08:24 PM
Squeaky Squeaky is offline
Member
First recorded activity by AviationBanter: May 2011
Pilatus B4 PC11, PC11A, PC11AF
Pilatus B4-PC11- Semi aerobatic,(+6.4, - 4.3). Cleared for outside loops, split S, Immelman, wing overs, chandelle, Lazy 8, Steep Spiral, Spins, Inverted -1G.
Pilatus B4-PC11-A - Fully aerobatic (+ 7.00, -4.79 g). Cleared for inverted flying, rolling manoeuvres inside and outside loops. Structurally as B4-PC11 but with toe straps, 5-point harness and increase down elevator travel.
Pilatus B4-PC11-AF - Fully aerobatic. Cleared as “A” model and for flick manoeuvres. As B4-PC11-A model but with rear fuselage strengthening to cater for flick manoeuvres. Strengthening may be factory fitted internally or external, fitted as a modification.
Span 15 meters, L/D 30-33ish
Example available (W&W):
Pilatus B4 PC-11
04-29-12 updated 07-18-12
s/n 237. Mfg 1976, TT 1650 hrs. Retractable gear.The glider was completely refinished in 2006: the finish is impeccable. BALL and Cambridge varios, iCOM radio, Winter ASI. Oxygen system.Easy to rig. Working, closed all-metal trailer. Always hangared - owned since 1986 by Pittsburgh Soaring Club. Last annual and maintenance/repairs performed by Gehrlein. Located at Bandel (22D) near Pittsburgh, PA.
https://plus.google.com/photos/10641...15575996995185
$17,300.00
Old October 3rd 12, 09:04 PM posted to rec.aviation.soaring
Peter Thomas[_2_]
This says the PIK 20 D is fully aerobatic if you fit toe straps and
a g meter
http://easa.europa.eu/certification/....024/EASA%20SA
S%20PIK-20D%2020110428.pdf
although the video shows rolls and inverted flight. the pushovers
are probably fairly low speed (watch the asi)
At 14:17 03 October 2012, jams wrote:
Hi all,
exploring the
non-acro
PIK20D etc) not
standard class.
for
'standard
Seems to be
almost a standard.
gliders could
spiral
dive.
cuban 8, barrel
maneuvers would
came
think to be,
serious aerobatics.
these
is only rated
to -2.5g.
would it exceed
-2.65?
(assuming
what it
German it says
some
CFI somewhere?!
What do you think?
pretty
Cheers
James
jams
Old October 3rd 12, 10:29 PM posted to rec.aviation.soaring
kirk.stant
On Wednesday, October 3, 2012 9:17:51 AM UTC-5, jams wrote:
Hi all, I have recently become interested in gliding and have been exploring the aspects associated with the sport. I'm going to use the term 'standard glider' to represent any non-acro 15m glider, (ASW 19/20, Speed Astir, LS range, DG range, PIK20D etc) not standard class. I recently started looking at aerobatics and sailplanes certified for this. Started looking at datasheets for aircraft and most 'standard gliders' are semi aerobatic only, in addition to this some give g ratings. The most common I have found is +5.3 / -2.65. Seems to be almost a standard. When I started looking at what maneuvers 'semi acrobatic' gliders could perform, the standard list seems to be loops, spins, chandelle, spiral dive. I then came across some more advanced maneuvers like cuban 8, barrel rolls, inverted flight etc. I thought that these type of maneuvers would exceed the -g rating of -2.65, so wouldn't be feasible. Then I came across this you tube footage of a PIK20D doing some, what I think to be, serious aerobatics. http://www.youtube.com/watch?v=tSB-JAFqrhU Pretty sure there is some significant -g going on in some of these moves, however the PIK20D (according to the BGA datasheet) is only rated to -2.5g. So what I'm asking is: Is this still basic stuff, (just looks impressive too me!)? What sort of -g would be experienced in these maneuvers, would it exceed -2.65? Would other 'standard gliders' be able to do stuff like this (assuming they had the same g rating as the PIK)? I did think for a minute that this was a brave chap wondering what it would take to snap the wings off, but on translating the German it says its part of his bronze acro training. So it must be signed off by some CFI somewhere?! What do you think? One interesting thing I came across was the g ratings for the LAK-12...+6 -4...thats quite high up the g rating ladder, and pretty impressive for an 20.5m Open class machine! Cheers James -- jams
You obviously have never tried to push out to -2.5Gs! Seriously, unless you are into competition aerobatics, -1.0Gs would be a lot. All the basic maneuvers can be done without exceeding +3gs or so and without any negative Gs at all - it's not until you get into slow rolls that you get into any negative G, and unless you are doing outside loops, not much.
Glider acro (unless in a Swift/Fox, etc) is a relaxed, gentle form of the art. It's not about pulling a lot of G, it's about energy management, and not exceeding VNE.
But - DO NOT TRY ACRO IN A GLIDER (OR ANY AIRCRAFT) WITHOUT PROPER TRAINING, AN APPROVED GLIDER, PARACHUTES, AND AIRSPACE!
Seriously, gliders are so slick that something as simple as a barrel roll will end up exceeding VNE if not done correctly. And exceeding VNE is not good...
Kirk
66
Occasional glider acro pilot (ASK-21, G-103Acro, Swift S-1, Blanik L-13AC, Pilatus B4, LS4, LS6)
Old October 3rd 12, 11:36 PM posted to rec.aviation.soaring
Andrzej Kobus
Hi all, I have recently become interested in gliding and have been exploring the aspects associated with the sport. I'm going to use the term 'standard glider' to represent any non-acro 15m glider, (ASW 19/20, Speed Astir, LS range, DG range, PIK20D etc) not standard class. I recently started looking at aerobatics and sailplanes certified for this. Started looking at datasheets for aircraft and most 'standard gliders' are semi aerobatic only, in addition to this some give g ratings. The most common I have found is +5.3 / -2.65. Seems to be almost a standard. When I started looking at what maneuvers 'semi acrobatic' gliders could perform, the standard list seems to be loops, spins, chandelle, spiral dive. I then came across some more advanced maneuvers like cuban 8, barrel rolls, inverted flight etc. I thought that these type of maneuvers would exceed the -g rating of -2.65, so wouldn't be feasible. Then I came across this you tube footage of a PIK20D doing some, what I think to be, serious aerobatics.http://www.youtube.com/watch?v=tSB-JAFqrhUPretty sure there is some significant -g going on in some of these moves, however the PIK20D (according to the BGA datasheet) is only rated to -2.5g. So what I'm asking is: Is this still basic stuff, (just looks impressive too me!)? What sort of -g would be experienced in these maneuvers, would it exceed -2.65? Would other 'standard gliders' be able to do stuff like this (assuming they had the same g rating as the PIK)? I did think for a minute that this was a brave chap wondering what it would take to snap the wings off, but on translating the German it says its part of his bronze acro training. So it must be signed off by some CFI somewhere?! What do you think? One interesting thing I came across was the g ratings for the LAK-12...+6 -4...thats quite high up the g rating ladder, and pretty impressive for an 20.5m Open class machine! Cheers James -- jams
You obviously have never tried to push out to -2.5Gs! *Seriously, unless you are into competition aerobatics, -1.0Gs would be a lot. *All the basic maneuvers can be done without exceeding +3gs or so and without any negative Gs at all - it's not until you get into slow rolls that you get into any negative G, and unless you are doing outside loops, not much.
Glider acro (unless in a Swift/Fox, etc) is a relaxed, gentle form of the art. *It's not about pulling a lot of G, it's about energy management, and not exceeding VNE.
Kirk
66
Look at SZD-59 (+7/-5) more than you need when you screw up.
http://szd.com.pl/en/products/szd-59-acro
Old October 4th 12, 01:02 PM
Junior Member
Thanks for all the input.
I have found out a fair bit more info on aerobatics since I posted this question. I think a better way of asking the question would have been: What aerobatic manoeuvres can a 'semi-aerobatic' sailplane perform!?
I have amassed quite a bit of info on the subject now, some interesting technical stuff that suggests that you cannot overstress a well designed sailplane at Va no matter what you do. I will have a read up on it all and post something here with my findings.
Kirk,
Your sentence: 'Glider acro (unless in a Swift/Fox, etc) is a relaxed, gentle form of the art. It's not about pulling a lot of G, it's about energy management, and not exceeding VNE.' Sums up exactly what I'm interested in. I dont want a pure acro aircraft, because I dont want to do anything to mad but would like to be able to explore more than just loops and chandelle during flights.
Also having found what G forces are generated in the figures i'm interested in (in the PIK aerobatics supplement), and your comment about not much neg G occurring, suggests that most sailplanes could handle what the PIK was doing in the video anyway.
Regards
James
Old October 4th 12, 07:09 PM posted to rec.aviation.soaring
Papa3[_2_]
Kirk,
Regards
James
Successfully executed positive G maneuvers are not a problem for many standard category gliders. But, there's a good reason why most of them are not approved or not recommended for acro. Failed maneuvers can quickly go badly wrong and put you into a situation where you can rapidly exceed the speed and load limitations. Rolling over the top in an overly aggressive stall turn or dishing out on an aileron roll would be two examples. When I was routinely doing a lot of acro in an L-13AC, it was the "oopsies" that really tested the limits, and this was in a glider that is much less slick than the high-performance ships in your examples.
Old October 5th 12, 09:58 AM posted to rec.aviation.soaring
Cedric Sponge
No it doesn't.
a g meter
Hi all,
exploring the
non-acro
PIK20D etc) not
standard class.
for
'standard
Seems to be
almost a standard.
gliders could
spiral
dive.
cuban 8, barrel
maneuvers would
came
think to be,
serious aerobatics.
these
is only rated
to -2.5g.
would it exceed
-2.65?
(assuming
what it
German it says
some
CFI somewhere?!
What do you think?
pretty
Cheers
James
jams
Cedric Sponge
No it doesn't.
a g meter
Hi all,
exploring the
non-acro
PIK20D etc) not
standard class.
for
'standard
Seems to be
almost a standard.
gliders could
spiral
dive.
cuban 8, barrel
maneuvers would
came
think to be,
serious aerobatics.
these
is only rated
to -2.5g.
would it exceed
-2.65?
(assuming
what it
German it says
some
CFI somewhere?!
What do you think?
pretty
Cheers
James
jams
Old October 5th 12, 10:38 AM posted to rec.aviation.soaring
Roel Baardman
As the owner of a Pilatus B4AF, and with some experience on B4/21/Fox, I feel I can at least give some hints.
I started with some figures on Utility class gliders. These often have max G ratings of +5.3 and -2.65 in my experience, although this is at Va speed. At Vne they often are limited to +4 and -2,
which is to take flying through strong thermals into account as far as I know.
The G-limits on gliders and allowed figures are two different things. Especially the high-performance gliders pick up speed fast.
I found that a truely Aerobatic-class glider (which often have +7 and -5 rating) is also suitable to learn figures on. In other words: if you screw up badly you will still not easily damage the
glider.
Think about kicking the rudder too late in a stall-turn and then ending up in an unintended tail-slide.
Also, the high-performance gliders often have a very laid-back body position for the pilot. In the DG-303 Acro handbook the pilot is warned about this, since G-awareness is lower in a reclined
position. And thus the risk of accidentally overstressing the aircraft.
In my B4 I fly rolls, inverted flight, spins, rolling turns (rolling and turning combined), tailslides, stall-turns and cubans (both forward and reverse).
I often have roughly +5 and -2 on the G-meter after a practice run. The +5 is during stall-turn pulls (to get a nice line) and the -2 is achieved during the pushing in rolling turns.
I would say for the first inverted flight and rolling (see the German Prufungsprogramm) you wouldn't go beyond +5 and -1.5 (achieved when pushing out your speed in a Split-S maneuver).
Long story short: I would recommend you learn to fly aerobatics on a Aerobatic-class two-seater. Then, if you become addicted, get yourself a B4/SZD-59/ASK-21.
Acrobatic simulators Jake Simulators 0 July 28th 07 10:58 PM
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
Acrobatic Homebuilt? [email protected] Home Built 2 May 16th 05 07:01 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
Va and negative g's & fun non-acrobatic maneuvers Koopas Ly Piloting 44 December 5th 03 02:03 AM
