TOST Release Failure - Two Uncommanded Release's
Old October 12th 12, 11:19 PM posted to rec.aviation.soaring
GM
Default TOST Release Failure - Two Uncommanded Release's
Peter Scholz ASW24 JE Well, this TOST hookup was replaced about 100 tows ago. Looks like there was dirt that got into the sleeve that housed the release cable. Where do you order a new one of these? Time for a new one.
Try the aviation dept. of your local bicyle or motorcycle store. You can buy the Bowden cable set with all required end fittings there off a bulk reel.
'GM'
Old October 13th 12, 10:23 AM posted to rec.aviation.soaring
Eric Munk
Had two cases like this. One was a broken over-center spring in the release
(on one side only, only visible after dismantling the release). The other
an extremely heavy pilot making the seatpan sag and push against the
release lever. My bet is you have a spring problem.
At 06:38 12 October 2012, Peter Scholz wrote:
Am 12.10.2012 07:29, Bob Kuykendall wrote:
As others note, that is the classic symptom of the overcenter spring
being broken on one side. The spring in question is a two-sided
torsion spring with anchors on both sides of the overcenter arm. The
result of this failure is that the hook will seem to operate normally,
but it will self-release under very low loads.
It could also be the other failures suggested in this thread, but my
money is on the spring being broken on one side.
Thanks, Bob K.
This is the reason why the TOST release has a nominal TBO of 2,000 tows
(i.e. 10,000 cycles to the spring). Send it in to be services and be
happy for another 2.000 tows...
Peter Scholz
ASW24 JE
Tost release failure Bill D Soaring 24 August 20th 13 10:49 AM
Anyone have a Tost release? noel.wade Soaring 5 June 10th 10 04:36 AM
FS Tost E85 Release scooter Soaring 0 March 7th 06 02:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 01:11 AM
Tost release on L-19? Roy Bourgeois Soaring 2 November 29th 04 10:24 PM
