Roel Baardman wrote:
So, unless you can form a 2D image of the particles' velocity and have the ic process that image, I don't see how you would do it. I should, of course, have referred to an image of the particles, not of the particles' velocity. The particles moving inside a thermal are what I think you should process. Little bugs lifting with the thermal, or even birds for a start. Perhaps the curly movement of the cloud above the thermal in the end? If you can have some electronics spot that falcon circling a few miles ahead in that killer thermal, this can already give you an advantage I guess. The ic bases its estimate of velocity on how fast points are moving across its field of view. The field of view is dependent on any aircraft movement, optical distortion in the canopy, shadows. Removing the optical analogue of "ground clutter" would also be necessary. The resolution required to spot birds (let alone "particles or bugs") at an interesting range would be impressive. Never say never, but I'd be interested to see the false positive rate! |
rate! I was merely approaching this from an academic viewpoint, and I agree with the points you raise. |
![]() Whatever the tech ultimately used to achieve this, what will it do to the sport? I know some people thought flight computers would ruin the sport, then GPS, then moving maps, but thus far it is still far from ruined. But visible thermals sounds like the biggest step yet towards reducing the challenge. What do others think? I wrote a short Soaring Magazine article a while ago, thinking about what thermal detectors might mean, http://faculty.chicagobooth.edu/john..._detectors.mht or link from http://faculty.chicagobooth.edu/john...dex.htm#corner Short version: Even a wingspan range would make a huge difference. Flying airplanes without engines will never be easy. Thermal detectors could dramatically improve the sporting experience, as they could mean the end of gaggling, leeching, team flying, etc. And think about how nice it would be at the end of the day to know for sure that there aren't any thermals left so you'd better stop trying and land. John Cochrane |
On a few occasions, I have observed soaring birds fly quickly towards a point where they found a thermal - sometimes a distance of about a kilometer. The speed and direction of them indicated to me that they were flying to an objective and not just hunting randomly. If so, this means that they can detect thermals remotely using their senses. If we can figure out how they are doing this, there is a chance we can build instruments to replicate their method.
Having studied the possibility of using electrostatic methods (thermals advect space charge from the ground and dust devils are actively charged by particle collision), this is very short range and not likely the mechanism birds are using. I would guess it has to be visual. Mike |
On Wednesday, October 24, 2012 9:36:48 AM UTC-6, Mike the Strike wrote:
On a few occasions, I have observed soaring birds fly quickly towards a point where they found a thermal - sometimes a distance of about a kilometer.. The speed and direction of them indicated to me that they were flying to an objective and not just hunting randomly. If so, this means that they can detect thermals remotely using their senses. If we can figure out how they are doing this, there is a chance we can build instruments to replicate their method. Having studied the possibility of using electrostatic methods (thermals advect space charge from the ground and dust devils are actively charged by particle collision), this is very short range and not likely the mechanism birds are using. I would guess it has to be visual. Mike I suspect it is visual for birds. The have far better vision than we and can probably see small objects like seeds rising with the thermal. They may also possess special visual processing centers in their brains evolved to detect thermals. I suspect the "one shot" DARPA program works the same way by detecting embedded objects like dust and seeds moving across the field of view then using powerful algorithms to process the data. Range the objects as they move across the field and the direction and speed of the wind can be determined. What's interesting to me is the comment that the device will work out to the maximum effective range of currently fielded sniper rifles. .50 caliber rifle ER's can exceed 3000 meters. There is also a comment elsewhere indicating the DOD wants to issue this to every soldier so it can't be too expensive. |
Forty years ago I put some effort into electrostatic
L/R detection of thermals. The big probelm is the vertical component of the general gradient which is at least an order of magnitude bigger than the horizontal part. This meant that using tip mounted sensors, the vertical distance between the tips times the vertical gradient would have to be compensated for; these days with micro computers and roll rate sensors,this might not be so difficult. My approach was to mount probes fore and aft and try to fly a constant pitch angle. (speed) There were fields I could detect but never resulting in finding a thermal by turning slowly L and R. A real sucess was detecting a field across an airmass boundary ( a weak pseudo front, shown by haze) and confirmed by several passes each direction. There was weak lift but the haze variation gave this away and I only detected the field as I flew through it. The 25m plus spans of some gliders could allow a better signal. I await further initiatives with interest. John Firth, old but no longer bold pilot. On a few occasions, I have observed soaring birds fly quickly towards a p= oint where they found a thermal - sometimes a distance of about a kilometer= .. The speed and direction of them indicated to me that they were flying to= an objective and not just hunting randomly. If so, this means that they c= an detect thermals remotely using their senses. If we can figure out how t= hey are doing this, there is a chance we can build instruments to replicate= their method. =20 =20 =20 Having studied the possibility of using electrostatic methods (thermals a= dvect space charge from the ground and dust devils are actively charged by = particle collision), this is very short range and not likely the mechanism = birds are using. I would guess it has to be visual. =20 =20 =20 Mike I suspect it is visual for birds. The have far better vision than we and c= an probably see small objects like seeds rising with the thermal. They may= also possess special visual processing centers in their brains evolved to = detect thermals. I suspect the "one shot" DARPA program works the same way by detecting embe= dded objects like dust and seeds moving across the field of view then using= powerful algorithms to process the data. Range the objects as they move a= cross the field and the direction and speed of the wind can be determined. What's interesting to me is the comment that the device will work out to th= e maximum effective range of currently fielded sniper rifles. .50 caliber = rifle ER's can exceed 3000 meters. There is also a comment elsewhere indic= ating the DOD wants to issue this to every soldier so it can't be too expen= sive. |
On Wednesday, October 24, 2012 12:15:03 PM UTC-6, John Firth wrote:
Forty years ago I put some effort into electrostatic L/R detection of thermals. The big probelm is the vertical component of the general gradient which is at least an order of magnitude bigger than the horizontal part. This meant that using tip mounted sensors, the vertical distance between the tips times the vertical gradient would have to be compensated for; these days with micro computers and roll rate sensors,this might not be so difficult. My approach was to mount probes fore and aft and try to fly a constant pitch angle. (speed) There were fields I could detect but never resulting in finding a thermal by turning slowly L and R. A real sucess was detecting a field across an airmass boundary ( a weak pseudo front, shown by haze) and confirmed by several passes each direction. There was weak lift but the haze variation gave this away and I only detected the field as I flew through it. The 25m plus spans of some gliders could allow a better signal. I await further initiatives with interest. John Firth, old but no longer bold pilot. On a few occasions, I have observed soaring birds fly quickly towards a p= oint where they found a thermal - sometimes a distance of about a kilometer= .. The speed and direction of them indicated to me that they were flying to= an objective and not just hunting randomly. If so, this means that they c= an detect thermals remotely using their senses. If we can figure out how t= hey are doing this, there is a chance we can build instruments to replicate= their method. =20 =20 =20 Having studied the possibility of using electrostatic methods (thermals a= dvect space charge from the ground and dust devils are actively charged by = particle collision), this is very short range and not likely the mechanism = birds are using. I would guess it has to be visual. =20 =20 =20 Mike I suspect it is visual for birds. The have far better vision than we and c= an probably see small objects like seeds rising with the thermal. They may= also possess special visual processing centers in their brains evolved to = detect thermals. I suspect the "one shot" DARPA program works the same way by detecting embe= dded objects like dust and seeds moving across the field of view then using= powerful algorithms to process the data. Range the objects as they move a= cross the field and the direction and speed of the wind can be determined. What's interesting to me is the comment that the device will work out to th= e maximum effective range of currently fielded sniper rifles. .50 caliber = rifle ER's can exceed 3000 meters. There is also a comment elsewhere indic= ating the DOD wants to issue this to every soldier so it can't be too expen= sive. In about that same time frame I worked on a set of paper charts showing data collected with an airplane traversing Mojave Desert thermals in mid-afternoon. The sensors included field mills for electrostatic charge and aerosol detectors in addition to the usual - temp, humidity etc.. The only consistent indicator of a 'thermal' was rising air. I think any successful remote thermal detector will have to "see" air motion directly. |
Bill D wrote
What's interesting to me is the comment that the device will work out to the maximum effective range of currently fielded sniper rifles. .50 caliber rifle ER's can exceed 3000 meters. There is also a comment elsewhere indicating the DOD wants to issue this to every soldier so it can't be too expensive. Bill, please read Liam's comment above (4th message in thread). This does not work for us. It requires firing a laser against a solid target. I have been studying this problem since 1984 and agree with all of John Cochrane's points above. It will be good for soaring for the reasons he cites and more. Just like GPS and all the other electronic aids it will be rapidly accepted. Technically, some passive or active (LASER or microwave) probing of the clear atmosphere to detect the relative motion (subtracting your vario) via backscatter from dust, bugs and pollen, along with image processing algorithims, will probably be in the final solution. I have compiled a database of relative papers on the technologies involved he http://www.ct-hanggliding.org/thermal.htm but it's getting a little old now as new things develop. Looking forward to seeing someone finally make this happen. |
On Oct 24, 9:01*am, Bill D wrote:
On Wednesday, October 24, 2012 9:36:48 AM UTC-6, Mike the Strike wrote: On a few occasions, I have observed soaring birds fly quickly towards a point where they found a thermal - sometimes a distance of about a kilometer. *The speed and direction of them indicated to me that they were flying to an objective and not just hunting randomly. *If so, this means that they can detect thermals remotely using their senses. *If we can figure out how they are doing this, there is a chance we can build instruments to replicate their method. Having studied the possibility of using electrostatic methods (thermals advect space charge from the ground and dust devils are actively charged by particle collision), this is very short range and not likely the mechanism birds are using. *I would guess it has to be visual. Mike I suspect it is visual for birds. *The have far better vision than we and can probably see small objects like seeds rising with the thermal. *They may also possess special visual processing centers in their brains evolved to detect thermals. I suspect the "one shot" DARPA program works the same way by detecting embedded objects like dust and seeds moving across the field of view then using powerful algorithms to process the data. *Range the objects as they move across the field and the direction and speed of the wind can be determined. What's interesting to me is the comment that the device will work out to the maximum effective range of currently fielded sniper rifles. *.50 caliber rifle ER's can exceed 3000 meters. *There is also a comment elsewhere indicating the DOD wants to issue this to every soldier so it can't be too expensive. The patented Isreali system referenced in the article does not use dust and seeds blown in the wind, it looks at the scinitllation of the laser illuminated target due to the atmospheric turbulence blowing across the line of sight. Sort of like the shimmering of a mirage. It gives a path averaged crosswind speed from the observer to the target. |
Possible remote thermal finder? | bildan | Soaring | 12 | January 23rd 11 05:35 PM |
Thermal Forcasting -Thermal index | gldrgidr | Soaring | 6 | November 27th 10 10:26 PM |
Idea for product - LMS method of traffic detection | joe smith | Products | 0 | March 6th 07 01:34 PM |
Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 2nd 05 11:14 PM |
Air traffic detection question | FISHnFLY | Aviation Marketplace | 19 | April 2nd 04 01:08 PM |
