PowerFLARM leeching comments
Old October 31st 12, 05:30 AM posted to rec.aviation.soaring
Ramy
Default PowerFLARM leeching comments
On Tuesday, October 30, 2012 1:12:54 PM UTC-7, Sean F (F2) wrote:
Bravo Falken. +1 again and again! I wish we had more folks like you over here. Bravo!
I second that.
The problem with some folks is that they are clueless about the risks and as such are in a higher risk. They believe that the reason they did not have any midair yet is due to their good scanning technique, while in fact it is 99% luck due to the big sky theory.
For a good reading on the subject of see and avoid check
http://www.aviationweek.com/aw/gener...s/bca0107c.xml (this link is few years old and currently not working, hopefully temporary)
Also a list of youtube videos showing how much we can trust our eyes:
http://www.youtube.com/watch?v=vJG698U2Mvo
-note: let it buffer all the way first, without letting it run, then
watch it full screen and really count!
http://videogames.yahoo.com/events/b...ion-25/1416088
-blind spot, eek...
http://videogames.yahoo.com/events/b...sion-5/1400321
-relative shades
http://videogames.yahoo.com/events/b...ion-14/1408013
-implied green
http://videogames.yahoo.com/events/b...sion-3/1400187
-false center
http://videogames.yahoo.com/events/b...ion-15/1408125
-false spiral
http://videogames.yahoo.com/events/b...ion-22/1414565
-implied square
http://videogames.yahoo.com/events/b...ion-19/1412692
-parallel lines
http://videogames.yahoo.com/events/b...sion-6/1400351
-parallels
http://videogames.yahoo.com/events/b...ion-18/1412564
-wiggling ovals
  #82
Old October 31st 12, 05:37 AM posted to rec.aviation.soaring
Ramy
On Tuesday, October 30, 2012 2:25:20 PM UTC-7, Don Johnstone wrote:
At 17:13 30 October 2012, folken wrote:
On Tuesday, October 30, 2012 5:00:04 PM UTC+1, Don Johnstone wrote:
I do not disagree with you, FLARM does help, with the emphasis on help,
it
does not replace or indeed lessen the necessity for a good lookout. My
argument was contering the statement that, "The difference between
midairs
and all other cause of accidents is that it is the only type which you
can
do almost nothing to prevent it, except using flarm." which I think you
will agree is a load of total ********. FLARM can assit the aware
pilot,
it
is NOT the answer to preventing mid air collisions.
Statically it is. Midairs, once the number 1 accident cause, are now
almost
nonexistent in Switzerland, since the introduction of Flarm.
You can also assume that no pilot wants a midair collision and maintains
good look out. But there are limitations to the human senses, as stated
by
Gerhard.
We have to stop threating the glider pilot as a luminous all seeing
perfect
elite being. (paron the pun.) We make mistakes. Hundreds each flight. In
fact its a human quality to err.
Yes it helps, it does not provide the answer as the statement to which I
objected intimated it might. The only solution is better lookout and
bettter situational awareness however THAT can be achieved, not replacing
them with technology.
In answer to the assertion that mid-air collisions in Switzerland have been
eradicated, mid air collisions are very very rare and relying on statistics
with such a small sample is futile. As I recall the only mid air I can
recall in Switzerland over recent year was between two FLARM equipped
gliders, go figure.
Here is where technology helps. It maintains its constant SA and fills in
our human attention gaps.
- Folken
I hope no one takes Don comments seriously. It is evident he doesn't know what he is talking about with gems like: midairs are very very rare, see and avoid is the only solution to midairs, flarm was designed for wave etc. Please spare us.
Ramy
Ramy
  #83
Old October 31st 12, 10:57 AM posted to rec.aviation.soaring
Don,
Switzerland is a small country. I have an incomplete list here
with midairs between 2006 and 2007 in Central Europe. The list implies
a lower bound of:
14 mid-airs
24 fatalities.
I'm not aware of a centralised European accident database, so statistics
is a bit tricky indeed, but it can theoretically be done by wading through
a few 1000s of reports from various national authorities.
gliders, go figure.
http://www.bfu.admin.ch/common/pdf/2012.pdf
Mid-air between an ASH 25 and a Stemme near Samedan, April 2007:
1.3 Information concerning the aircraft
Motorglider HB-2XXX was fitted with a traffic and collision warning
system FLARM F4 which was not operational because its UHF antenna was
not mounted.
[ the ASH had an operational FLARM ].
The only mid-air events I'm personally aware of where both involved aircraft
had an operational FLARM on board was Finland 2011 and Uvalde 2012.
FLARM helps, but it doesn't provide 100% protection.
Best
--Gerhard
  #84
Old October 31st 12, 01:46 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
At 10:57 31 October 2012, wrote:
Don,
been
statistics
a lower bound of:
14 mid-airs
24 fatalities.
through
gliders, go figure.
not mounted.
aircraft
Best
--Gerhard
FLARM is like the flashing blue light and sirens on a police car, it does
not in itself provide any protection at all. Both the above rely on the
human beings being able to interpret what they see, a flashing light and or
a sound, and take the necessary action. There are those who believe that
there is a technology solution which makes looking out less of a priority.
I particularly like the statement that people do not see the other aircraft
before it hits them, of course they don't, if they saw it the collision
would not take place. Of course FLARM can help, IF it is used as intended
and the human bit understands what he is bing told. It still relies on good
old fashioned lookout.
It is not unknown for two aircraft hitting each other when under radar
control, it is not the technology that is the problem. Accidents happen
because we are human, and sometimes fail to do what we should.
My comment about FLARM aircraft being involved in collisions was not a
critism of FLARM, more a comment that despite FLARM it can still, and will
happen.
  #85
Old October 31st 12, 04:35 PM posted to rec.aviation.soaring
folken
there is a technology solution which makes looking out less of a priority..
Nobody, right in their head actually believes that. Nobody that has been instructed in FLARM usage does believe that.
Which is exactly the situation where FLARM comes in and tells you the pilot to pay attention and prevent the collision. So these stories will be a thing of the past.
If you fly in an aircraft where you do not understand what each instrument on your panel does, and are unfamiliar with the procedures that this entitles (for example pulling out right with a imminent head on collision) You do _not_ belong into this aircraft. These are the very basics.
Flarm does not replace the pilot or good airmanship. It augments the pilot's senses.
happen.
Since flarm doesn't pilot the aircraft for you: of course it can. But a critical situation is
1. far less likely to arise.
2. The outcome of a critical situation far less likely to cause an accident..
Statistics from .ch: Note the dip from 2004 onwards.
http://www.segelflug.ch/d/6safety/pd...atistik_CH.pdf
And i checked the accidents reports from 2007 onwards: There hasn't been a midair since the introduction of FLARM in Switzerland. (Flarm equipped and _in working order_ aircraft.)
- Folken
  #86
Old October 31st 12, 04:53 PM posted to rec.aviation.soaring
Ramy
Don, the statement said " can not see the one which will hit them" not the one which hit them! You misunderstood again. What the statement means is that your eye can barely detect non moving target, and the non moving target is the one which will hit you. I suggest you do some research before posting more BS.
Ramy
  #87
Old October 31st 12, 07:14 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
If Flarm alerts you, it's probably because your "good old fashioned
lookout" has not alerted you. Flarm does depend on you finding the other
glider that caused the alert, but finding a threat after it's position
is given to you is not part of "good old fashioned lookout".
The pilot should continue to use his "[not really so] good old fashioned
lookout" after he has installed a Flarm unit, because there are still
aircraft that don't have Flarm or a transponder, and because Flarm isn't
perfect.
email me)
  #88
Old October 31st 12, 08:41 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
t=
target=
posti=
ng more BS.=20
Ramy
Yes Ramy I do understand that. FLARM was originally designed to alert
pilots flying in wave, where the relative movement of soaring gliders is
very small, and their direction of travel, (track) is often unrelated to
their heading (direction they are pointing) to an outside observer. FLARM
is very good at alerting us of that situation and quite often the rate of
closure is very small.
That is just one situation where FLARM is excellent however it does not
necessarily mean that it is good in other situations.
  #89
Old October 31st 12, 08:47 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
does
=20
=20
and
or
=20
a sound, and take the necessary action.=20
priority=
in=
=20
aircra=
ft
=20
=20
would not take place.=20
pilot=
thi=
ng of the past.
and the human bit understands what he is bing told.=20
instrument
entitl=
do=
It still relies on good=20
pilot'=
s senses.
=20
=20
=20
=20
=20
wil=
l
=20
happen.=20
cri=
tical situation is=20
1. far less likely to arise.=20
accident=
a
and
- Folken
and 99% of people who enter a retirment home die there, does not mean that
retirement homes are dangerous places, just that the statistics are
meaningless. In the case you put forward the sample is far too small to
draw a meaningful conclusion. There could be other factors at work, like
less flying taking place, more conspicuous markings, better understanding
by pilots of the problem ad nausea.
Better lookout and situational awareness is they key, anyone who thinks
otherwise should stay at home in a locked room, they are far too dangerous
to be allowed out.
  #90
Old October 31st 12, 10:40 PM posted to rec.aviation.soaring
to be allowed out.
Ad nauseam is the right characterization - this comes across as continual nit-picking and nay-saying in denial of available facts and logic - and in contradiction of some of your own prior statements regarding admitted effectiveness of Flarm as an aid to situational awareness specific to traffic conflicts.
I've flown with it, I know it works - in my retirement home people live longer than in Don's so I'm moving there.
9B
Logger on PowerFlarm? LOV2AV8 Soaring 7 July 27th 12 03:18 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): [email protected] Naval Aviation 0 December 19th 06 08:37 PM
