CAI302 Push/Pull Arrows Missing
Old November 23rd 12, 08:17 PM posted to rec.aviation.soaring
Jeff Casto
Default CAI302 Push/Pull Arrows Missing
My CAI302 was intermittently turning off in flight, so my sailplane partner
took it apart and found some loose connections. This fixed the problem, but
now the push/pull arrows are missing from the display. The audio works
fine. I'm sure this is a setting, but I can't find it. Can anyone help?
Thanks,
Jeff
Old November 23rd 12, 10:01 PM posted to rec.aviation.soaring
Darryl Ramm
Thanks,
Jeff
If the C302 is really working all except the LCD push/pull arrows then I would return it to Cambridge, but I'd carefully exclude more other things first...
Are you seeing a circular arrow? Then you are in climb mode...
How is the C302 switched from cruise to climb mode? If an external reed switch (on the flap handle mechanism) or toggle switch (typically on the joystick) then is the wiring or switch faulty holding the C302 in climb mode (short the pins to be in climb mode, leave those pins open and the C302 should automatically go to cruise mode when not circling)? Read the manual on this to be sure you understand how this works.
Do you have a polar entered? Correct for your glider?
Is it missing the airspeed input? Look on the screen #10 are all the inputs there? Do they make sense when flying?
If you are in the USA I can't imagine wanting to *disassemble* a C302, just return them to the factory for repair and/or recalibration.
Darryl
Old November 23rd 12, 10:18 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
Insufficient info in the original post to give a useful answer, but enough
to say it's no longer an IGC flight recorder - the security is trashed if
you open the case until it is electronically resealed.
partn=
er
=20
b=
ut
=20
=20
=20
=20
=20
Thanks,
=20
=20
=20
Jeff
wo=
fir=
st...
swi=
joyst=
(sh=
should=
thi=
Do you have a polar entered? Correct for your glider?=20
inputs=
just=
Darryl
Old November 23rd 12, 10:34 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
partner
problem, but
works
help?
Thanks,
If Darryl's suggestions don't help, I'd suggest the connections between
the LCD and the circuitry did not get properly put back together.
email me
Old November 23rd 12, 10:52 PM posted to rec.aviation.soaring
Jeff Casto
Thanks for all the helpful replies. I'll check the items listed. WRT
security, it was out of cal. We plan to send it for cal in January. Is the
security reset then, or do we need to send it to Cambridge for that?
Thanks, again.
Jeff
partner
problem, but
works
help?
Thanks,
email me
Old November 24th 12, 02:11 PM posted to rec.aviation.soaring
Paul Remde
Hi Jeff,
I'm a Cambridge dealer and authorized agent for them. I can reset the
security on the 302 with help from Cambridge. I can also recalibrate it.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
____________________________________
"Jeff Casto" wrote in message
. com...
Thanks, again.
Jeff
partner
problem, but
works
help?
Thanks,
email me
CAI302 bent control knob Walter Weir Soaring 7 December 21st 10 02:52 PM
Push-Pull propeller combinations. Eunometic Naval Aviation 19 September 4th 10 07:25 PM
CAI302 altitude in NMEA.. PCool Soaring 6 October 23rd 09 07:25 PM
Red Arrows RIAT 07 - File 1 of 1 - Red Arrows RIAT07_web.jpg (1/1) RobG Aviation Photos 0 June 15th 08 12:59 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 05:57 PM
