FAI (IGC) rules for US Club Class Nationals - Petition
Old November 27th 12, 11:13 PM posted to rec.aviation.soaring
Default FAI (IGC) rules for US Club Class Nationals - Petition
I encourage you to review the rules. IGC is LESS complex,simpler and easier to understand. IGC rules are 15,091 words long compared to 25,804 (US rules).
http://www.fai.org/igc-documents
Go to Sporting Code Section 3 Annex A
1. No 1-34s, etc. so we don't have to worry about low performance gliders when task setting.
YES
2. No LS-6s, Venti and ASW-20Bs&Cs.
No LS-6 or Venti. ASW-20B&Cs HAVE BEEN allowed. They are specifically excluded in Argentina at the next WGC.
3. No speed or altitude limits prior to the start.
Altitude limits are up to CD discretion, similar to US Rules.
4. Much more emphasis on ATs.
YES. There are ONLY Racing Tasks (AT) and Assigned Area Tasks. 50/50 seems to be the philosophy.
5. Score everything according to FAI rules.
YES. See scoring calculations on page 31 & 32 of FAI SC3a rules.
Sean Franke
  #32
Old November 27th 12, 11:48 PM posted to rec.aviation.soaring
So, with altitude limits you get VNE dives to the line. Sometimes out
of the clouds. Fun stuff. Advocates have a point, if you want to go
do this stuff at the worlds, practicing at home will help a lot.
8.7 LIST OF APPROVED PENALTIES, page 34
Cloud flying: 100pts first offense, day disqual - second offense, Disqualification - max penalty.
The tactical implications of the FAI scoring formula are subtle and
deep. There are several analyses of the required strategies floating
around the US team. If we go there, be prepared to play a very
different tactical game.
The question for US pilots: do the 99% of you
who are not going to the worlds really want to invest a lot to
learning to play these games? You're going to be landing out a lot
more often btw.
John Cochrane
Keep in mind we are not proposing changing existing US Classes. We are hoping to create a new racing class and positive experience NOT available in the US. It is ONE class. Give US pilots a choice. Seeing how the petition is developing, it's clear a strong voice is growing.
I think the picture painted above about IGC rules is a bit DRAMATIC. I certainly didn't experience that in Prievidza 2010 WGC. I think safety and successful tasking varies according to contest management. That is no different in the US.
Advocates have a point: if you want to learn to play this game it
takes years of practice. The question for US pilots: do the 99% of you
Interesting comment. Besides a refreshing alternative do you think this new class could serve as training for US Team pilots?
Sean Franke
  #33
Old November 27th 12, 11:54 PM posted to rec.aviation.soaring
Richard Walters
Let's not forget what I consider the most unfair IGC CC rule of
all- no actual weight based handicapping. So if I fly a Discus b at
825 pounds and BB flies a Discus a at 700 pounds, we fly with
the same handicap. I would have a one pound PSF wing loading
advantage, which would be helpful anywhere but the maybe the
UK.
Big, heavy guys take note. I weigh 100 kg. BB considerably
less.
Richard Walters
complex,simpler and
compared to 25,804
(US rules).
performance
YES
specifically
Tasks. 50/50
rules.
Sean Franke
  #34
Old November 28th 12, 12:13 AM posted to rec.aviation.soaring
UK.
less.
Richard Walters
The reference weight for Discus a & b is 367 kg. Every 10 kg incurs a handicap increase of 0,005. Yes, there can be a wing loading difference but it's accounted for in the handicap.
Copied from current handicap list:
"The handicap is based on the performance at the New IGC Reference Mass.
If a glider is flown at a mass not exceeding this reference mass it can be considered as operated within legal mass limits.
Where a glider is flown at a higher mass by necessity, the pilot will have to provide documentation to prove that his glider is
still operated within legal mass limits and the handicap will be increased by 0,005 for each 10 kg or part thereof that the glider
exceeds the reference mass. However the wing loading may in no case exceed 38 kg/m2. In addition the handicap may in no
case exceed 1,09."
Sean Franke
  #35
Old November 28th 12, 12:31 AM posted to rec.aviation.soaring
Ron Gleason
On Tuesday, 20 November 2012 07:42:32 UTC-7, wrote:
The U.S. is moving towards recognizing the Club Class in 2013. A poll has been created to validate interest in establishing FAI (IGC) rules / tasking philosophy in this new class. If approved the U.S. Club Class would be the ONLY U.S. racing class under FAI (IGC) racing rules.
Please sign the petition IF YOU are interested in supporting or flying US Club Class under FAI (IGC) rules / tasking philosophy.
In the optional personal comment section please enter (if applicable):
1. Your position on the US seeding list.
2. If you have access to or own a Club Class glider, what type.
3. If you are familiar with IGC rules and prefer those rules over US rules.
4. If you would financially or otherwise support development of the US Club Class under FAI (IGC) rules.
5. If you don't currently fly US contests but would start flying US Club Class under FAI (IGC) rules.
6. If you currently fly US contests (Standard, Open, 15m, 18m or Sports) and are interested in flying US Club Class under FAI (IGC) rules.
7. Any other comments welcome!
Link to petition: http://www.thepetitionsite.com/262/8...out-exception/
Sean Franke
US Club Class Team Member
Sean, how are you proposing to score these contests? Are you going to use SeeYou?
Ron Gleason
  #36
Old November 28th 12, 12:38 AM posted to rec.aviation.soaring
Sean Franke
Ron Gleason
SeeYou is popular and works well. I propose using SeeYou unless a better solution is brought up.
Sean Franke
  #37
Old November 28th 12, 12:45 AM posted to rec.aviation.soaring
Sean F (F2)
Great conversation developing here!
  #38
Old November 28th 12, 12:52 AM posted to rec.aviation.soaring
Richard Walters
UK.
less.
Richard Walters
complex,simpler and
compared to 25,804
(US rules).
performance
YES
specifically
Tasks. 50/50
rules.
Sean Franke
  #39
Old November 28th 12, 12:53 AM posted to rec.aviation.soaring
Richard Walters
UK.
less.
Richard Walters
complex,simpler and
compared to 25,804
(US rules).
performance
YES
specifically
Tasks. 50/50
rules.
Sean Franke
  #40
Old November 28th 12, 12:54 AM posted to rec.aviation.soaring
Richard Walters
UK.
less.
Richard Walters
complex,simpler and
compared to 25,804
(US rules).
performance
YES
specifically
Tasks. 50/50
rules.
Sean Franke
Club Class Nationals 5 ugly Soaring 37 September 24th 10 03:27 AM
US 15 Meters Nationals and Region V South Club Class [email protected] Soaring 0 March 12th 09 03:59 PM
Establishing Club Class/Too Many Nationals/Not Enough Competitors Tim[_2_] Soaring 14 October 2nd 08 03:34 PM
AUS Club Class Nationals Overall Results Mal Soaring 0 January 27th 06 09:55 AM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
