Battery plugs, etc.
Old November 27th 12, 11:02 PM posted to rec.aviation.soaring
Simon Taylor[_2_]
Default Battery plugs, etc.
Using the IGC (backwards) RJ45 numbering scheme:
IGC standard RJ45:
1,2 +12V
3
4
5 RS232 TX
6 RS232 RX
7,8 GND
LXNAV v7 RJ45 PDA port:
1,2 GND
3 RS232 TX
4 RS232 RX
5 TTL TX
6 TTL RX
7,8 +5V
Hopefully I've messed up transcribing those. If not, it's certainly an
interesting
design choice.
Old November 27th 12, 11:11 PM posted to rec.aviation.soaring
Darryl Ramm
On Tuesday, November 27, 2012 1:25:42 PM UTC-8, David Reitter wrote:
I have switched my club and also my own glider to Anderson PowerPoles for power.
No issues with male/female connectors (unlike XLR). One criticism would be that they do not have strain relief on the cable insulation. But that's not been a practical issue. The other would be that they do not screw together to secure the connection (some aviation-grade connectors do), but that also makes is easier to connect/disconnect. So, practically, not a problem.
Anderson make clips that go over the PowerPole connectors to secure them in place. Its usually more hassle than its worth, although I think I heard of one pilot disconnected the battery when reaching over their shoulder and pulling stuff off the shelf. Common sense I guess, you need to protect that connection in some way, have it where it can't get unplugged.
If you are using PowerPoles please get a proper ratcheting crimper for them.. Quite often I've seen bad crimp jobs on these, either the crimps are not properly made onto the wire or the improper crimper deforms the connector (either that or the user bending the deformed connector back so it fits into the socket) in a way that the mated pressure on the contact blades is less than it should be and the connection more likely to undo or be less reliable. Cheap non-ratcheting crimpers cannot supply sufficient force to swage the connector onto wiring--the wire strands and connector will effectively fuse together with the metals swaged under such high pressure. One comparison of good/bad crimps is here http://www.etco.com/crimp-photo-gallery. You should also hopefully be using a high quality Tefzel insulated aviation wire with silver plated strands to help prevent corrosion (properly crimping that type of silver plated stranded wire into a silver plated connector as in the case of the PowerPoles connectors works just great). Resist the temptation to solder and/or crimp then solder a crimp connector, just not a good idea.
The genuine Anderson PowerPole crimper is expensive but probably well worth if for a club, repair shop or group of owners. http://www.powerwerx.com/crimping-to...powerpole.html
Some folks might be confused between XLR (aka Cannon) connectors and DIN connectors. Not sure, neither would be my preference. DIN can be fragile and XLR are just large and klunky. And cheap versions of both connectors can have corrosion problems.
Darryl
Old November 27th 12, 11:12 PM posted to rec.aviation.soaring
Dave Nadler
Ignore all those puny wimpy solutions and get one of these:
http://www.nadler.com/backups/DSCF1205.JPG
See ya, Dave "YO electric"
Old November 28th 12, 12:21 AM posted to rec.aviation.soaring
Todd
Add me to the PowerPole fans.
My solution to the strain relief was to double sided tape the battery side circuit (PP connector + FUSE) to the battery top so that the mating glider circuit is fully supported/protected by the battery top.
Additionally, since I have 2 batteries side by side, i used a pair of PP "blanks" to connect the two glider power feeds together so that I have a single harness to plug in. Send me an email if you want a picture.
I also cut the connectors off my chargers and put PP connectors on them too.
Old November 28th 12, 11:56 AM posted to rec.aviation.soaring
Willy VINKEN
On Tue, 27 Nov 2012 11:46:05 -0500, Don wrote:
Our club uses 4 pin jones plugs for battery plugs, 2 pins positive and 2
pins negative for redundancy. But even this is not fool proof after
passage of time: sometimes they need to be "wiggled" to connect and
they are getting hard to find now too. What kinds of plugs are other
clubs or commercial ops using? I'm not a big fan of the nylon molex
connectors. Someone recommended using PowerPole connectors. Any
experience with these?
XLR connectors have never been designed for power supply. They are
professional audio connectors.
Anderson PowerPoles are perfect and versatile. Never had problems
with them, whether crimped or soldered.
Spring loaded silver plated contact conductance is excellent.
Much cheaper than good quality XLRs (Cannon, Neutrik, Amphenol…)
Much lighter. Less cumbersome.
I've seen battery short circuits caused by metal XLRs falling on them.
I've seen Libelle ailerons freezed by XLRs wedged up between the rods.
I know there is an (unofficial) standard way to do the pinning of XLRs
(at least in Europe), but there are 5 alternate possibilities to do it
wrong. I don't count the radios I've had to fix after faulty
polarizations (and lack of decent fuses).
Compared to the high grade quality of the mechanics, I don't
understand how they can sell 250K$ aircraft with non-professional
electronics.
Willy VINKEN D-KBAL - ON5WV
Old November 28th 12, 02:43 PM posted to rec.aviation.soaring
aerodyne
I second the vote for cinch - jones, available on line or wings and
wheels, 20+ years with no problems...superior for blind connections
under the panel, etc.
MM
Old November 28th 12, 02:46 PM posted to rec.aviation.soaring
Don[_4_]
Thanks for all the good input. Power Pole connectors look like the
clear winner and we will purchase/install for our club. We will get a
good crimper, too.
Old November 28th 12, 02:53 PM posted to rec.aviation.soaring
Dan Marotta
If your gliders are hangared or can be reached by wires, consider installing
bulkhead connectors inside and simply plug in the glider rather than
removing the batteries.
My glider came with Power Pole connectors for the main and tail batteries
but, adding a third battery, I was unable to find Power Poles locally. Now
I have a 4-pin bulkhead connector in the seat back bulkhead and, after
putting the ship to bed, I simply plug the chargers into the bulkhead via a
home made cable. Now everything is always charged when I go to fly.
"Don" wrote in message
passage of time: sometimes they need to be "wiggled" to connect and they
are getting hard to find now too. What kinds of plugs are other clubs or
commercial ops using? I'm not a big fan of the nylon molex connectors.
Someone recommended using PowerPole connectors. Any experience with
these?
Old November 28th 12, 03:48 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Two words: McMaster Carr.
Old November 28th 12, 03:56 PM posted to rec.aviation.soaring
Darryl Ramm
And http://www.powerwerx.com/anderson-powerpoles/
IO-540 prebuy - oil on some plugs [email protected] Owning 5 September 16th 06 03:26 AM
Shields for C-26 plugs Ed Byars Restoration 0 January 23rd 04 08:20 PM
GPS ext power plugs Dave Martindale Piloting 0 September 16th 03 09:26 PM
GPS ext power plugs Dave Martindale Products 0 September 16th 03 09:26 PM
18mm plugs w b evans Home Built 0 September 8th 03 10:43 PM
