Battery plugs, etc.
Old November 27th 12, 11:55 PM posted to rec.aviation.soaring
Bob Cook[_2_]
Default Battery plugs, etc.
Anderson power poles do show an alternative.. soldering... for the
connection pins if you don't have the special (expensive) crimping tool.
I have used both soldering and crimping with great results.
Just about everything I own has a power pole connection, glider battery,
motorcycles, electric scooter...battery chargers, GPS, r/c stuff, etc....so
everything is "universal"
Cookie
Old November 28th 12, 03:21 AM posted to rec.aviation.soaring
Tony V
I use the Andy-Crimp tool. Less than 25% of the price of the "official"
Anderson crimper. Works great.
See:
http://www.hamcq.com/powerpoles/powe.../prod_485.html
http://www.qsradio.com/Powerpoles.htm
Tony "6N" W1DYS
Old November 28th 12, 09:21 AM posted to rec.aviation.soaring
noel.wade
I'm another PowerPole fan.
Here's a pic of how I protect my batteries:
https://picasaweb.google.com/lh/phot...t=d irectlink
I make a "hat" with 3 pieces of acrylic (acrylic cement melts them
together quickly and easily), then use some double-sided tape (VHB) to
attach them to the battery with a ~1 inch air gap.
In the air gap I mount an insulated fuse to protect the battery/wiring
(in addition to fuses or CBs for each instrument). I drill a couple of
small holes in the acrylic and zip-tie the fuse in place so the wires
aren't under tension.
Then I drill another small hole in the acrylic and use a screw, lock-
washer, and nut to hold the PowerPole in place with no tension on the
battery wires (the PowerPole housing insulates everything from the
screw). Being screwed into the acrylic means I can push and pull on
the connection if I need to, and it won't put strain on the wires.
Lastly, I make sure this connector is recessed a bit so I can make the
connection - but anything dropping onto the connection will be
shielded by the acrylic.
Enjoy,
--Noel
Battery plugs, etc. Don[_4_] Soaring 33 December 1st 12 05:20 AM
Spark plugs Don Pyeatt Aviation Photos 4 April 9th 07 04:25 AM
RFQ Igniter plugs Juan*Jimenez Aviation Marketplace 0 April 23rd 04 11:13 PM
GPS ext power plugs Dave Martindale Piloting 0 September 16th 03 09:26 PM
GPS ext power plugs Dave Martindale Products 0 September 16th 03 09:26 PM
