Power FLARM as logger
Old December 4th 12, 01:58 PM
Lucky812 Lucky812 is offline
Junior Member
First recorded activity by AviationBanter: Jul 2012
Marc
Thank you for your response I am just starting out and appreciate the information.
My question came from the realization that I will have 3 GPS units (Power FLARM, Nano, and Nexus 7) in my glider and thought that it might just be a bit of over-kill as I remember the old days flying in Papua New Guinea with a wet compass and an incomplete map that said something like "maximum elevation not believed to be over 14,000".
Old December 4th 12, 02:31 PM posted to rec.aviation.soaring
Default Power FLARM as logger
On Tuesday, December 4, 2012 8:54:49 AM UTC-5, wrote:
Are you at liberty to tell us what the status of the PowerFLARM approval is?
Has it been submitted, is it being evaluated?
This question still begs an answer. Going "all in" with my doughnuts, I'll bet the PowerFLARM logger has not been submitted for approval.
I think my donuts go on it having been submitted. A beta version of the
firmware came out last month adding the logging feature.
-- Matt
Old December 4th 12, 03:43 PM posted to rec.aviation.soaring
Richard[_9_]
On Tuesday, December 4, 2012 6:31:57 AM UTC-8, wrote:
On Tuesday, December 4, 2012 8:54:49 AM UTC-5, wrote: Are you at liberty to tell us what the status of the PowerFLARM approval is? Has it been submitted, is it being evaluated? This question still begs an answer. Going "all in" with my doughnuts, I'll bet the PowerFLARM logger has not been submitted for approval. I think my donuts go on it having been submitted. A beta version of the firmware came out last month adding the logging feature. -- Matt
From Flarm
The process has been started, but we have not yet submitted a device as we first need to implement and test the ENL function.
Flarm and Flarm assessories, antennas etc. available at:
http://www.craggyaero.com/powerflarm.htm
Thanks,
Richard
www.craggyaero.com
Old December 4th 12, 04:10 PM posted to rec.aviation.soaring
On Tuesday, December 4, 2012 1:38:16 AM UTC-8, Ramy wrote:
But in case it wasn't clear, my proposal is not to get rid of flight recorders all together, but to just get rid of the approval requirements for badges and diplomas which are just personal achievements.
They may be just personal achievements, but there still needs to be a little something there that keeps mostly honest people, like myself, from "forgetting" the little things that sometimes make flights not quite valid. Like, managing to complete a 1000K flight except for the tiny little detail of still being 20 or 30 miles out on final glide at official sunset in a glider with no lights. Or, making a flight and somehow forgetting that Class A airspace begins at 18000 ft in our corner of the world. Or my personal almost, but not quite, achievement, the one time I managed to declare my perfect 1000K triangle out of TPH, climbing out with full water at 9:15 am, zipping out to Utah in no time, making it all the way back past Mt Grant to 10 miles out from my last turnpoint with essentially no turns, which should have been followed by an easy ride back to TPH. Except, the turnpoint was smack underneath a shelf of over-developed clouds, which were already dumping water. Since I wanted the "personal achievement", I had to try, with the pretty much inevitable result that I didn't make it back to TPH until the next day. Or, I could have just declared a moral victory, turned 10 miles out, and made it back for the BBQ, but somehow, it wouldn't have been the same.
I think the rules are there for valid reasons, and part of any achievement is managing to comply with the rules while making the flight. Without some independent means of demonstrating compliance with the declaration and rules, all you have is the pilots word. There is still a significant difference between "making" a 1000K flight, and actually getting the FAI diploma. So, yes, I still think we need flight recorders...
Old December 4th 12, 06:24 PM posted to rec.aviation.soaring
Ramy
Marc, I completely agree with everything you say (including starting final glide after sunset...). My grip is only on the requirement for the flight computer to be "certified". What's wrong with using SeeYou/XCSoar etc IGC files for badges and diplomas? I imagine much more pilots will be motivated to get their badges and diplomas if they could simply submit the IGC files from their flight computer, certified or not, just like OLC.
Ramy
Old December 4th 12, 07:05 PM posted to rec.aviation.soaring
FLARM
Ramy,
IGC 'Position Recorders' have been created for exactly this purpose; no certification required.
http://www.fai.org/gnss-recording-de...tion-recorders
Nobody seems to care enough to make it happen, except for some more or less random approvals (e.g. of non-IGC certified FLARM devices).
Urs
FLARM
Old December 4th 12, 08:58 PM posted to rec.aviation.soaring
FLARM
The approval process has been initiated, but we need to finish and test ENL and a 'good' encryption for the certified G records.
As communicated from the start, are applying for a 'up to and including diamonds' approval (same as for 'Classic FLARM'), not 'all flights' as that would have serious implications on cost, both for manufacturing and maintenance.
Current US PowerFLARM hardware will be upgradeable for free and with no change in hardware if (if !) everything goes as planned.
No firm date on completion, obviously, but it is our #1 focus at this time.
If you have missed the news, IGC format recording, including G record, is available since over a month and seems to work very well.
And yes, someone should buy Marc, Tim and other GFAC members flowers and chocolate, but it shouldn't be us, obviously...
You could ask them for their mailing address, then use http://www.ftd.com/, worldwide.
Old December 4th 12, 09:01 PM posted to rec.aviation.soaring
Ramy, the approval process is only intended to provide some sort of reasonable baseline for the quality, integrity, and reliability of the evidence used to document flights that result in various kinds of FAI awards. We can argue about where the baseline should be, but if you eliminate the baseline altogether, in my mind, it starts to affect the value of the awards. GPS receivers are not all equal in quality, not all recording capable consumer GPS units produce usable position evidence, and code running on on readily reprogrammable devices isn't necessarily what it looks to be. We need some standards, which is not to say that existing standards are cast in stone.
Perhaps the IGC will eventually decide that SeeYou, XCSoar, or whatever, provide acceptable evidence on some specific kinds of hardware, but that is not the same thing as saying they will provide acceptable evidence on any and all possible hardware on which they run, which implies that there would still be a need for some sort of approval/certification process...
Marc
Old December 4th 12, 11:05 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
like OLC.
The problem is that some pilots have, both in the past and currently,
continued to cheat and fake logs. Even for 500 km flights. I don't
understand that mentality at all, let alone how they can live with
themselves knowing they are liars whenever they say they've earned the
badge.
But, as long as that sort is around, we need secure loggers and the whole
business of Official Observers and paperwork to stop them from devaluing
the badge and diploma system for the rest of us.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 4th 12, 11:48 PM posted to rec.aviation.soaring
ursus
I just did a test on PowerFLARM as a logger:
Set it outside, powered up and waited. Nothing happened for hours. All surrounding trees are still standing.
Those darn FLARM folks have really overpromised! Or maybe I need to change configuration settings? Or handicraft my own antenna? Or read the manual?
I suspect it will need a hard- and software update; maybe if someone can point FLARM to an autonomous chainsaw with serial interface (ideally IGC specification) they could finally deliver what has been promised:
FLARM as a logger.
Timber!
http://www.youtube.com/watch?v=mL7n5mEmXJo
Now, if it could only make coffee...
US Power FLARM Antennas Andy[_1_] Soaring 13 June 21st 12 07:34 AM
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 01:33 PM
Flarm data logger TMA Soaring 1 June 3rd 12 10:03 PM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 04:28 AM
Power FLARM portable reports? Andy[_1_] Soaring 2 December 9th 11 03:58 PM
