New LXNAV V3 variometers in stock now
Old December 24th 12, 07:12 PM posted to rec.aviation.soaring
Paul Remde
Default New LXNAV V3 variometers in stock now
Hi,
The exciting new LXNAV V3 variometers arrived in my stock today. You can
see details and order he
http://www.cumulus-soaring.com/lxnav.htm#LXNAV-V3
Happy Holidays,
Paul Remde
Cumulus Soaring, Inc.
Old December 27th 12, 03:01 AM posted to rec.aviation.soaring
Wings and wheels has them for $695.00
Old December 27th 12, 04:12 PM posted to rec.aviation.soaring
Richard[_9_]
Craggy Aero
Even Less
Richard
www.craggyaero.com
Old December 27th 12, 08:13 PM posted to rec.aviation.soaring
Kimmo Hytoenen
LXNAV V3 looks like an interesting device. It seems to have RS232
communication - what data does it send out? Can flight computer
application like XCSoar communicate with it?
Old December 27th 12, 09:19 PM posted to rec.aviation.soaring
Richard[_9_]
On Thursday, December 27, 2012 12:13:14 PM UTC-8, Kimmo Hytoenen wrote:
LXNAV V3 looks like an interesting device. It seems to have RS232 communication - what data does it send out? Can flight computer application like XCSoar communicate with it?
Kimmo,
The V3 serial interface is used only for firmware update. It cannot output to navigation software, for that you need the V7.
Happy New Year
Richard
www.craggyaero.com
Old December 28th 12, 01:29 AM posted to rec.aviation.soaring
Kimmo,
Happy New Year
Richard
www.craggyaero.com
The V3/V7 price difference is interesting. It must be mainly justified by marketing rather than the different electronics?
Old December 28th 12, 02:02 PM posted to rec.aviation.soaring
Paul Remde
Hi,
There is a big hardware difference between the V7 and V3. The V7 has pitot
an static inputs and can therefore display push/pull (speed-up/slow-down)
commands. The V3 does not have pitot or static inputs. It can tell you how
fast to fly, but it doesn't know how fast you are flying, so it can't tell
you to speed-up/slow-down. The V3 is a great new idea. It is a Total
Energy vario with audio, with the ability to display the recommended
speed-to-fly based on your glider's polar and the current MacCready setting
and the current lift/sink. It is a lot like having a smart MacCready ring
on a mechanical vario. You can see details he
Best Regards,
Paul Remde
Old December 30th 12, 08:18 AM posted to rec.aviation.soaring
Echo
Can the mechanical needle of the V3 function without electrical input? So, if a total power loss, any vario function left? Thanks,
Jordan
ASW20 E
Hi,
Best Regards,
Paul Remde
Old December 30th 12, 01:26 PM posted to rec.aviation.soaring
Paul Remde
Hi,
No. The needs is driven by an electrical stepper-motor, so it won't work if
there is no power. However, the V3 can be powered by an small backup
battery or battery pack. It operates on as little as 6V. A battery pack
from Radio Shack that holds 4 to 6 AA batteries would work great as a
backup. A panel mounted switch could be used to switch to the backup
battery pack if the main battery gets too low. Or, you could use 2 main
batteries and switch between them as necessary - that is very commonly done.
Best Regards,
Paul Remde
"Echo" wrote in message
Jordan
ASW20 E
by
Hi,
pitot
how
setting
Best Regards,
Paul Remde
LXNAV V7 - Reviews? David Reitter Soaring 10 October 21st 14 12:41 AM
Butterfly Variometers - In Stock Paul Remde Soaring 20 September 25th 12 09:47 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
Gizmo Variometers? Mike C 17 Soaring 1 August 19th 06 07:01 PM
S&V variometers? chris Soaring 7 January 5th 06 06:43 PM
