Sheriff Responds to AOPA
Old January 21st 13, 06:13 PM posted to rec.aviation.soaring
Mike the Strike
Default Sheriff Responds to AOPA
On Monday, January 21, 2013 4:15:54 AM UTC-7, Peter Higgs wrote:
At 05:38 21 January 2013, GC wrote:
On 21/01/2013 11:46, Bill Palmer wrote:
The reality is that the nuclear containment domes are virtually
impenetrable by aircraft. I recall seeing a video study wherein they
ran an F-4 (or something similar) into a section of one and the
airplane was vaporized while the cement structure was unscathed. The
public doesn't quite understand the fragile nature of an airframe,
and that ramming a nuclear facility with one is about a worrisome as
pelting it with eggs.
Can't blame people really. Everybody knows now how fragile skyscrapers
can be when rammed by a 767 and, to most people, large tower buildings
look to be at least as solid as a nuclear dome. That's the reality to
be dealt with.
GC
I think two facts remain...
Even a 66% efficient power station produces 33% waste heat. So if it is a
100 MW station, there is a nice 33 MW Thermal continuously rising on the
lee side.
In the UK (world leaders in democracy?) ALL Nuclear Facilities have a 2
mile and 2000ft Restricted Safety Zone around them.
You can't have your cake and eat it.... Please decide.
phiggs
A typical power plant these days is between 1,500 and 5,000 MW. Those powered by fossil-fuel are less than 40% efficient, so you may have 1,000 to 3,000 MW of heat available for your thermal.
Our local nuke here in Arizona is 3,000 MW and probably has 1,000 MW going up the cooling towers. I've never been low enough over it to really check it out, however.
Mike
Mike
Old January 21st 13, 11:17 PM posted to rec.aviation.soaring
"soartech" wrote in message
Darlington County, S.C., Sheriff J. Wayne Byrd
Interesting.
News of the Weird has an entire section devoted to people with the
middle name of Wayne.
I'm one of them!!!
H Wayne Paul
http://www.soaridaho.com/
Old January 22nd 13, 10:45 AM posted to rec.aviation.soaring
folken
We have two nuclear power plants within gliding distance of each other. One has as cooling tower. I regularly use it as a thermal.
The thermal is extremely narrow.. so banks of 90 Degrees are not uncommon. Additionaly you need a lot of speed around a 130 KM/h since the thing is so rough. An additional difficulty is that the downdraft around the outside is around the same as in the updraft.. so if you stick the tail out, expect to see just blue sky. Done right it takes you up a km in under a minute.
What is interesting is that it isn't always the same. Sometimes it doesn't work at all.. sometimes its narrow as described, sometimes you get moderate climb values from several Km away.
The thermal source is well known.. and its not uncommon to find the fields of entire competitions circling over that powerplant.
- Folken
Old January 22nd 13, 02:35 PM posted to rec.aviation.soaring
son_of_flubber
Anyone have a report on the quality of thermals coming off of solar panel arrays? The panels are black and tilted to the sun.
Old January 22nd 13, 05:26 PM posted to rec.aviation.soaring
Bart[_4_]
On Jan 22, 6:35*am, son_of_flubber wrote:
Anyone have a report on the quality of thermals coming off of solar panel arrays? * The panels are black and tilted to the sun.
I had high hopes when they installed solar panels approximately a mile
away from the Avenal airport. Sadly, they do not seem to generate any
more thermals than the fields that used to be there did; possibly
less.
Bart
Old January 22nd 13, 05:55 PM posted to rec.aviation.soaring
Tony[_5_]
Just dont try to land there with the gapa
Old January 22nd 13, 08:47 PM posted to rec.aviation.soaring
sisu1a
False.
http://www.rainierflightservice.com/...ctor-chart.gif
Old January 22nd 13, 11:06 PM posted to rec.aviation.soaring
folken
False.
Thermaling is not a coordinated turn.
Old January 23rd 13, 01:40 AM posted to rec.aviation.soaring
kirk.stant
90 degree bank is a lot steeper than most pilots imagine. Unless you are current in acro anything over 60 degrees will feel like 90. And unless its a transient condition caused by turbulence any intentional 90 degree bank for more than a few seconds would result in an impressive sink rate regardless of the strength of the thermal. But it makes for a good hangar story: "There I was at 300 ft over the nuke cooling tower, banked to 90 degrees and barely climbing..."
Kirk
66
Old January 23rd 13, 04:30 PM posted to rec.aviation.soaring
Bart[_4_]
Which part of "approximately a mile away" is confusing you? ;-) The
mighty Geezer might be capable of such an epic cross-country flight
(except the landing, of course). I am just a sidekick.
Bart
USS Liberty Survivor Phil Tourney responds to Cindy McCain NOMOREWARS_FORISRAEL Naval Aviation 0 September 24th 11 11:22 AM
A Fine Day at BFI - part 2 - Bell 407 N407KS King County Sheriff BFI 6-20-09 29.jpg Bob (not my real pseudonym) Aviation Photos 0 June 28th 09 09:32 AM
A Fine Day at BFI - part 2 - Bell 407 N407KS King County Sheriff BFI 6-20-09 23.jpg Bob (not my real pseudonym) Aviation Photos 0 June 28th 09 09:32 AM
AS responds to the latest Ventus 2cxa KevinFinke Soaring 3 March 18th 09 03:45 AM
County Sheriff Arrests Pilot After Botched Landing Larry Dighera Piloting 16 May 16th 08 09:58 PM
