Question about spoilers and pitch stability
Old February 3rd 13, 07:37 PM posted to rec.aviation.soaring
Bill D
Default Question about spoilers and pitch stability
On Sunday, February 3, 2013 10:50:16 AM UTC-7, waremark wrote:
In Europe standard practice is to teach fully held off landings, touching down just a fraction over stall speed in a 2 point attitude. Do the incidents referred to result from teaching a 'flown on' landing?
The fully held off approach results in far less energy to do damage if you hit a bump in an off field landing, or to generate a bounce. My flight manuals recommend it. I think there is debate about which technique involves greater risk of a PIO.
You are absolutely correct. A 'held off' landing with a two point contact is the way to do it. Even contact with the tail wheel a few cm lower than the main wheel won't hurt anything.
Where I've seen the too-fast landings become a habit is where a well intentioned instructor rants on endlessly about keeping a high airspeed in the pattern without defining "pattern" and without ever explaining the meaning of the yellow triangle on the ASI. Students and others may take this to mean the ideal airspeed on final approach is in Mach numbers. This has resulted in many overshoot accidents in addition to the Grob "PIO/PIB".
Final approach is where a pilot transitions from the pattern and sets up the touchdown. Short-final "over-the-fence" airspeed should be just above the yellow triangle which guarantees the correct touchdown attitude.
For those who haven't read their manuals, the yellow triangle marks the manufactures recommended minimum approach airspeed at maximum flying weight but without water ballast. That means you'll have just enough energy for a flare and hold-off.
Old February 3rd 13, 08:00 PM posted to rec.aviation.soaring
son_of_flubber
I have a question. Assume strong turbulence such that a 70 knot speed in the pattern is needed to obtain control authority. Once the flair is correctly executed and the glider is flying level in ground effect 6-12" off the ground, does the glider become less vulnerable to turbulence because it is in ground effect, and therefore would control authority be maintained as the glider slows to stall speed?
I understand that once the pilot is flying level 6-12" above the runway at 70 knots (at that point the plane has zero vertical velocity) that he can very gradually lower the center wheel to the runway without 'bouncing". The advantage of lowering the wheel to the runway is two-fold. 1)The turbulence can no longer slam the wheel down onto the runway (it is already there). 2)The pilot can use the wheel brake and full spoilers to stop the glider as quickly as possible, thus minimizing runout and minimizing the time exposed to turbulence near the ground.
If the pilot chooses to reduce speed from 70 knots to stall speed with the wheel off the ground, he has a longer runout, the possibility of being slammed to the pavement by a downdraft, and a longer period of time vulnerable to unpredictable turbulence.
In short, I understand that there are advantages to "landing hot". I also understand that if a pilot touches down with too much vertical velocity, that he will 'bounce'. If the vertical velocity is low enough, you will not 'bounce' not matter how high the horizontal velocity.
(I understand that the 'bounce' is caused by an increase in AOA, caused by rotation around the center wheel, caused by a CG behind the center wheel, too much vertical velocity, and therefore too much momentum pressing the rear wheel down and increasing the AOA. And of course enough horizontal speed such that the increased AOA causes the wheel to leave the ground.)
I want to reinterate that I'm asking a question and just stating my very possilbly fractured understanding. This topic is of great interest to me because I'm in the process of transitioning to a glass ship and I have a lot of training time in SGS (There seems to be some vague correlation between transitioning from SGS to glass and landing related PIOs.)
Old February 3rd 13, 08:54 PM posted to rec.aviation.soaring
Bill D
I hope our European friends jump in too. The following is based on years of experience at Boulder in wildly turbulent west wind rotors.
I don't think a "hot" landing has any value. It just means you'll float down the runway in ground effect while you are vulnerable to those gusts and with enough energy to seriously damage the glider. Better to get it down and stopped and that can't happen until the glider slows.
With a little practice, you'll find a glider can be slowed sharply with a few seconds of full airbrake while raising the nose to maintain the glide path just before entering ground effect. This can be done on short final to hit the recommended approach speed allowing the pattern itself to be flown at any speed the pilot deems safe for the gustiness.
This discussion is about nose wheel gliders where "hot" landings put the glider on the nose wheel first.
Old February 3rd 13, 09:12 PM posted to rec.aviation.soaring
Roel Baardman
As far as I know the ASK-21 has such geometry that it will not take off with the two front wheels on the ground. This would imply that it produces no lift upwards, and that only making the
nosewheel touch the ground is very hard.
I question the existence of downdrafts during flaring... Where would the air in the downdraft go when you are already so low?
Old February 3rd 13, 09:24 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
I think the topology of the field has a bearing on it: if the ground
under the base and final leg are likely to cause turbulence then you need
a higher airspeed to punch through it, but airfields generally have flat
surfaces so there shouldn't be nearly so much turbulence a couple of feet
above the runway.
I've never been taught to do anything other than a fully held-off landing.
On my home field, in the very flat Cambridgeshire countryside I don't
think I've ever used or needed more than 60 kts on finals. Its at 52
11.052N, 0 6.655W in case you're interested and the field is set up for
an easterly in the picture.
OTOH at The Mynd where, when the wind is W to SW, the approach is down
the side of a fairly steep hill with a 50-60 foot gully to land on a
slight grassy upslope, you're told to plan for an approach at at least 60
kts. When I last flew there there was enough westerly for the ridge in
front of the club house to be working nicely, so I'd guess 20 +/- 5 kts.
That day I flew finals in my Libelle at 70kts, made a fully held-off
landing and was stopped no more than 500 ft from the threshhold. The hold-
off was no more turbulent than I'd expect at home.
If you have access to Google Earth, you'll find the Mynd at 52 31.153N, 2
52.501W. That should put your pointer pretty much where the launchpoint
that day. We were touching down pretty much N of the launchpoint on a
bearing of roughly 200 degrees and stopping somewhere between launch
point and clubhouse.
You can see the north edge of the mown field about 400 ft NE of there.
The bottom of the gully is the wavery white line another 400 feet further
to the NE and the club house is 1250 feet west of the launch point. The
curving, thin white line immediately west of the clubhouse is a walking
track along the top of the ridge. You can see the winch where it was that
day at the south end of the airfield, 3750 feet away and 70 feet higher.
If you dial GE back to oldest photo (31Dec1998) the low lighting gives a
much better idea of the shape of the gully and hill under the approach we
were using.
'bouncing".
I believe so, though as I said, I've never been taught that sort of
landing.
I'd dispute that. You land slower and can still use full air and wheel
brakes so the ground run has to be shorter.
Is that significant if you're only 1 2 feet up? You're well inside ground
effect and there's almost no distance to be accelerated downward, but
what do I know? I don't normally fly where there's rotor.
However, I expect to be at the Mynd toward the end of April so I may
learn more then.
leave the ground.)
That applies to most single seaters but isn't true for the G.103, ASK-21
or Puchacz, which all have the CG in front of the main wheel with one or
two pilots in them. They would not rest on the nose wheel otherwise.
PIOs.)
Could that be related to reactions during roll-out after landing when you
want to use the brakes? In a 2-33 or anything with a nose skid you push
the stick forward to rub the skid on the ground for braking while in
gliders without a skid, i.e. all common glass, you tend to pull the stick
hard back when using the brakes to keep the nose off the floor and the
tail wheel on the ground for better directional stability. Of course, you
have to be slow enough to know you won't take off again when you pull on
the stick!
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 4th 13, 12:59 AM posted to rec.aviation.soaring
BobW
the pattern is needed to obtain control authority. Once the flare is
My experience in the intermountain west of the US - based out of Boulder
(KBDU) 3 miles from the Rocky Mountain foothills - is (for discussional
purposes, ignore crosswinds for the moment) once in "the final float" with the
main wheel within inches of the ground, turbulence ceases to be a factor.
That's not to suggest I haven't been seriously concerned about it beCOMing a
factor, but the concern has never materialized. My experience includes 3
microbursts in the pattern, one of which was a crap shoot in terms of success
vs. life-endangering-crash. (I still get the shakes thinking about that
[2-pointed] one, years later.)
See below for brief discussion of round-out thoughts given the presence of
"beer-worthy" crosswinds...
"What Martin Gregorie said" regarding your "longer runout" positing. In any
event, in the absence of a persistent, strong crosswind my vote favors getting
rid of the energy where the plane is generally safest, i.e. in the air.
You seem to have a decent grasp of the dynamic issues (aero and CG-positional)
judging from the preceding brief summation. Strictly by way of FYI feedback...
I want to reiterate that I'm asking a question and just stating my very
possibly fractured understanding. This topic is of great interest to me
lot of training time in SGS. (There seems to be some vague correlation
Knowing very little about "typical pattern conditions" at your home field, but
having most of my time in the intermountain west - which tends to be prone to
"enthusiastic pattern conditions" year 'round - maybe an observation about
landing in the presence of persistently strong crosswinds isn't unwarranted.
Next to microbursts in the pattern, howling crosswinds are my next least
favorite pattern condition to have to deal with. While they (generally) tend
to "significantly decrease" in the vertical distance descended through during
the transition from final approach attitude to hold-off attitude, they don't
always, and the thought of landing on a narrow runway with little tolerance
for being off-center, while drifting sideways due to a crosswind overpowering
the pilot's/ship's abilities to compensate for drift has always left me cold.
Under such conditions, I've tended to favor - and had my best results from so
doing - run-on landings at the lowest speed conditions permit in the absence
of "significant drift". Working from memory, my highest-ever touchdown speed
was probably around 70 knots indicated in the presence of an estimated 25-30
knot direct crosswind. I aimed for the near end of the runway, flew in ground
effect until I was essentially out of rudder, briefly used into-wind aileron
to halt developing drift, and planted the main wheel. Then - because I could -
I went to negative flap to plant the tailwheel, and used full downwind rudder
and heavy braking to minimize the into-wind arc of the main wheel. Another
pilot in an unflapped St'd Cirrus landing minutes ahead of me
independently-opted/used essentially the same technique with very similar
(also successful) results.
We both subsequently concluded held-off landing attempts would likely have
ended anywhere from "considerably less gracefully" to "genuinely ugly-ly".
Bob W.
Old February 4th 13, 04:43 AM posted to rec.aviation.soaring
Terence Wilson[_2_]
Opening the spoilers reduces the coefficient of lift. After the first 'bounce', which results in an increase in the angle of attack, the reduced CL dampens the lift vector and amplitude of the PIO.
  #28
Old February 4th 13, 06:44 PM posted to rec.aviation.soaring
son_of_flubber
In short, I understand that there are advantages to "landing hot"....
Right, you want to dissipate the energy before entering ground effect.
I do this when high speed is called for in the pattern, but not needed for the final 20 feet of descent. For example, when there is the possibility of strong sink on downwind, and you need the extra energy to use if you hit the sink to avoid landing short.
On Sunday, February 3, 2013 3:24:02 PM UTC-5, Martin Gregorie wrote:
OTOH at The Mynd ...
landing and was stopped no more than 500 ft from the threshold.
My home field is known for strong sink on final, strong crosswinds (one narrow runway), erratic surrounding topography (not flat), and in wave season, rotor in the pattern. (We like it because the wave and the ridges are very close to the airport!)
The hold-off was no more turbulent than I'd expect at home.
Granted, it can be very turbulent on downwind, but relatively calm on the ground. (After reading all the great responses) I can see that even if you have plenty of runway in front of you, you should anticipate calm and slow down before you enter ground effect. Even if there turns out to be turbulence at ground, you might hit it farther down the runway after you have necessarily slowed down. Best bet is to minimize the time spent rolling on the runway when you are exposed to possible turbulence, and also minimize the energy that you carry close to the ground should something go awry.
son_of_flubber wrote: If the pilot chooses to reduce speed from 70 knots to stall speed with the wheel off the ground, he has a longer runout,
But you've floated to the far end of the runway before you can apply the wheel brake and full spoiler. When I put the wheel on the ground at 70kts, I can sooner open full spoilers and sooner apply wheel brake (balanced with the elevator to maintain appropriate AOA). From a given point on the runway and given speed, the pilot who applies full spoiler and wheelbrake sooner will stop shorter. If you try to lose speed from 70kts to stall, before let your wheel touch, you will be far down the runway before you stop. Granted, I've screwed up if I have 70kts in ground effect (unless there is a hellish crosswind or wind gradient). The question is only how to best bring the glider to a stop once that mistake has been made.
son_of_flubber wrote: There seems to be some vague correlation between transitioning from SGS to glass and landing related PIOs.
Could that be related to (ed. pilot) reactions during roll-out after landing(ed. ?)...
The SGS 2-33 has relatively low control authority and high stability. That makes it "easy to fly" in easy conditions. Early in my training, I transitioned from 2-33 to Blanik L-23. At the time I found the L-23 "extremely responsive and unstable" compared to the 2-33 (novice perspective . After flying the L-23 for a season, I transitioned to ASK-21 and found it another (albeit smaller) step up in responsiveness. I'm glad that I transitioned to the L-23 early before my stick and rudder habits became deeply ingrained. I'd expect that some pilots who had only flown SGS, might have PIO in a glass ship in a stressful situation, should they revert to their 2-33 formed habits and overdo control inputs. That's a possibility for me too, though I've not yet instinctively pushed the stick forward to put the skid down on a glider that does not have a skid! It could happen. I love the 2-33 for early confidence building before habits are formed, but I'm glad that I moved to the Blanik sooner rather than later. The 2-33 is just too easy to fly if you ever want to fly glass.
On Sunday, February 3, 2013 6:59:17 PM UTC-5, BobW wrote:
...(ed.ignoring) crosswinds for the moment, once in "the final float" with the
main wheel within inches of the ground, turbulence ceases to be a factor (ed.in my experience).
It's possible to have a turbulence related incident close to the ground, but not probable. And the extra speed would only help you if the nasty gust happened to hit you before you (inevitably) slow down at the far end of the runway. The high energy will hurt you if something goes wrong. I can see that in lieu of a crosswind, and once you are sure of not landing short, that it is best to lose any excess energy before entering ground effect.
My experience includes 3 microbursts in the pattern
This might give you the willies...
http://en.wikipedia.org/wiki/File:Microburstnasa.JPG
Hopefully, there are no runway lights, cliffs, trees or parked vehicles.
doing - run-on landings at the lowest speed conditions permit ...
...my highest-ever touchdown speed was probably around 70 knots indicated in the presence of an estimated 25-30 knot direct crosswind. I aimed for the near end of the runway, flew in ground
So you needed the speed and consequent control authority to quickly and precisely dip and undip the upwind wing to arrest the drift, and the energy gave you the needed rudder effectiveness (before it ran out). Did the speed do anything else for you?
So you planted the wheels well above stall speed, because you were forced to level the wing (to avoid ground loop) and you used the "tracking" of the wheels to arrest the drift? The tailwheel helped prevent weathervaning into the wind (a little).
Okay, I see the (only?) justified and correct use of 70kts IAS in ground effect. In lieu of a hellish crosswind, I was incorrect to enter ground effect at 70kts. Once I had made the runway in the turbulent and strong sink conditions, I should have shed the excess energy before I entered ground effect. However, once I had made the mistake of entering ground effect at 70kts, I was justified in putting the wheel down and applying full spoiler and wheel brake because that allowed me to stop with a comfortable margin of runway still in front of me; more runway than I would have had if I had floated in ground effect at 70kts until reaching stall speed. If (at 70kts) I had touched the wheel down with too much vertical speed, I might have executed the dreaded landing PIO. At best, I would have relaunched into stable ground effect and tried again.
Back to the original thread... Shedding excess speed before entering ground effect reduces the chance of landing PIO. Reducing vertical speed at touchdown reduces the chance of landing PIO. Holding off until reaching stall speed rules out the possibility of landing PIO. Should you screw up and "bounce"(once), your first goal is to return the glider to level flight, then land by correctly "holding off" (in lieu of a devilish crosswind). If you are running out of runway at that point, you might gradually put the wheel down before you reach stall speed, then open full spoilers and wheelbrake to stop, hopefully soon enough.
Thank you for your responses. It's very helpful to think this through sitting by the fire on a stormy day in winter. Plus it's fun to re-imagine those hairy landings from last summer.
  #29
Old February 4th 13, 09:07 PM posted to rec.aviation.soaring
BobW
On 2/4/2013 10:44 AM, son_of_flubber wrote:
Major snip
Snip
the thought of landing on a narrow runway with little tolerance for being
off-center, while drifting sideways due to a crosswind overpowering the
cold.
from so doing - run-on landings at the lowest speed conditions permit
the near end of the runway, flew in ground effect until I was essentially
out of rudder, briefly used into-wind aileron to halt developing drift,
We're likely talking nuance here, but the ways I think speed assists Joe Pilot
in the presence of a strong/steady crosswind a a) reducing vector angles (&
hence fuselage to runway angle at touchdown); b) enhancing control authority
prior to touchdown.
and planted the main wheel. Then - because I could - I went to negative
flap to plant the tailwheel, and used full downwind rudder and heavy
Yep to all. It was a 15 meter bird, and the thought of wingtip-to-ground
contact above stalling speed terrifies me. Plant the main wheel before
drift/wingtip-to-ground contact become issues, establish the best total
plane-to-ground contact(s) possible ASAP, use controls as much as you
dare/must, brake enthusiastically.
Yup.
Yup.
Yup...insufficient energy to do anything but bounce - not "flying bounce".
Should you screw up
crosswind).
(Presuming a "flying bounce"...) Yup. Stay away from trying to "fine tune"
rapid stick inputs in some new-to-you way in the event of a "flying bounce"
(which likely WILL alarm you first time it happens). Lots have tried the "fine
tuned/rapid stick motions" approach...with scant success. Locking the stick in
pitch during the arc of your flying bounce and waiting for ground arrival is
pretty much guaranteed to be a better choice.
Yup...but if this intentional "fine tuned" forward stick motion is botched
(easy to do in the absence of thought beforehand), the next arrival will
generally be even harder in the vertical velocity sense. A plan beforehand is
good!
Back to botched flare/drifting touchdowns in the presence of strong/persistent
crosswinds briefly...
One of my worst arrivals happened when I ballooned a flare (too high a
speed...the X-wind made me nervous), began drifting "way beyond my comfort
level", ballooned the 2nd flare (all the while downwind drift velocity
increasing), and dropped in from about 3 feet. It was UGLY. Amazingly it (same
15 meter ship) survived without damage, thanks largely to this happening on an
empty WW-II ramp (nothing to hit...well, other than the ramp, I mean [wry
chuckle]), but both main and tail tires squealed throughout most of the
resultant ground loop into the wind. Can't remember if squealing rubber or the
downwind wingtip skid dragging was louder. The lack of ship damage had zero to
do with pilot skill. I'd well over 1,000 hours in the ship at the time. The
worst of it was I attempted the 2-point landing (rather than a run-on one,
which is easy to do in that ship) only because it was a large, empty ramp.
What WAS I thinking?!?
At least I had the sense to do it with no peanut gallery...
Never again attempted a 2-point landing in the presence of a strong X-wind.
Bob W.
  #30
Old February 4th 13, 10:16 PM posted to rec.aviation.soaring
To clarify: I meant 500ft into the field, not 500 ft from the far end.
The headwind component combined with landing uphill stopped me quite a
lot shorter than I expected considering the Libelle's famously weak
airbrakes. I don't recall using the wheelbrakes much if at all.
If I saw that I was running out of space ahead and the end of the field
looked unpleasant I'd want the wheel on the floor as a preliminary to an
intentional ground-loop - the fastest way to stop. That involves putting
the upwind tip on the ground as a pivot and using forward stick to get
the tail off the ground so the glider swings round easier. It also
minimizes the chances of snapping the tailboom due to side loads from the
tail wheel hitting grass clumps etc. I haven't had to do that yet but a
friend did, landing in a very small field with a stone wall at the far
end.
org |
Stability variation WingFlaps Piloting 2 April 28th 08 04:45 AM
Towing stability studies Dan G Soaring 27 February 21st 08 09:38 PM
Tow vehicle -- electronic stability control Greg Arnold Soaring 4 June 8th 06 01:31 PM
Atmospheric stability and lapse rate Andrew Sarangan Piloting 39 February 11th 05 06:34 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 04:22 AM
