Al-Qaida Leader Says They Have Briefcase Nukes
Old March 23rd 04, 04:47 AM
Chad Irby
In article
Orval Fairbairn wrote:
One factor overlooked in all this discussion is that nuclear weapons, in
addition to generating lots of detectable radiation, get HOT! In FBM
tests we installed heaters to simulate the heat generated by a snoutful
of physics packages.
A good terrorist would have to wrap the whole thing in a lead vessel,
adding a lot of weight and then have to try to keep it cool. I know that
DC has radiation detectors spread all over the city; I assume that NYC
and Boston would, also,
It ain't as simple as it seems!
But it also ain't hard. Once you have one, you just need to get it into
the city for a minute or so, especially since we can assume a
hand-carried and detonated device.
I wouldn't bet that someone could get one into NYC at ground level, but
there are other ways.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #42
Old March 23rd 04, 05:36 AM
Kevin Brooks
"Chad Irby" wrote in message
. com...
m...
The SADM had a much tougher casing and was designed to be
tamper-resistant. Kicked the weight up a *lot*.
Pardon me for saying so, but have you ever been exposed to the SADM in
any
fashion?
Yep. At least, I've seen the casing and such. It's not a backpack and
an alarm clock. Think military-designed and hard to break.
Suffice it to say that an exposed physics package is not realistic
in this thread--the supposition is that AQ allegedly got its hands on a
product of some ex-Soviet device, and it will be a cased device, one
that to
the best of my knowledge will include a PAL, too (say what you will
about
the Soviets, but they reportedly took their nuclear weapons control as
seriously as we did). SADM added about a hundred pounds to the warhead
weight for a reason.
Yeah, they wanted a bomb they could stash under a bridge, set a timer,
and not have to worry about until it went off. They could also
(supposedly) leave it under water.
Actually, you are only looking at one rather minor use of the device. The
major use was in denial and barrier operations--our corps level combat
engineer battalions were tasked with supporting their emplacement by the ADM
company troops, which is why we all had to attend that "what every engineer
lieutenant needs to know about ADM's" short course program as part of our
OBC. The special operators could emplace them, but that was the exception,
not the rule.
Brooks
cirby at cfl.rr.com
  #43
Old March 23rd 04, 05:42 AM
Kevin Brooks
. com...
m...
Take the mechanism out of the steel artillery round, and there you go.
About four inches in diameter, and a couple of feet long. Remember
that
the W-82 weight and size were ready to fire, inside a heavy steel
shell.
I don't know WHAT that shell was made out of, or how thick it was---for
all
I know they used a more exotic material, like titanium. Nor do we know
actual cross sectional dimensions of the warhead itself. We do know that
a
particularly thick outerwall was not *required*, and that the actual
physics
package diameter could have been as high as maybe six inches, with
quarter
inch thick shell walls (the need for extreme thickness is not really
evident).
They were firing it out of a *cannon*. You don't do that with very thin
shell walls, and it also suggests a large amount of ruggedization for
the warhead itself (something not needed for a hand-carried bomb).
Yes, you can--witness the use of various cargo rounds, to include RAAM/ADAM.
Thin walled structures can be very strong, especially since the force it was
designed to sustain was pretty much a pure axial kick in the seat of the
pants with the rotational force being a nonplayer. And what were the charge
restrictions on its use?
At *worst*, you have a package that will easily fit in a golf bag. How
many ways can you think of to sneak something that size into the US?
Doesn't matter--the claim by Lebed, which these folks have apparently
latched onto, was that we were talking "suitcase bombs", not arty rounds.
Sorry, but I still find it less than believable. Maybe it si the complete
and utter lack of evidence to support Lebed's claims...
Your device still needs its batteries, its HE component, its
high-speed detonators and associated fuzing, its initial neutron
booster--all of the components minus the actual screw in fuze and the
external casing. The apparent limit to the package itself, minus the
unnecessary accoutrements, is going to be in the 50-60 pound range. If
you
have found a smaller device, by weight, that has actually been proven to
work (i.e., either tested or fielded), please explain what it is.
Why? Fifty pounds and small enough to fit in a hand-carried case is
certainly small enough. It's not like you need to fit the thing under a
coach airline seat.
But you have been saying they could be even smaller--where's the beef?
Brooks
cirby at cfl.rr.com
  #44
Old March 23rd 04, 06:36 AM
Chad Irby
. com...
not the rule.
....and they didn't design and deploy two separate kinds of devices.
They made one weapon they could use in a number of cases.
So they had a relatively small, somewhat rugged and weatherproof bomb
that could be deployed in some very rough conditions.
cirby at cfl.rr.com
  #45
Old March 23rd 04, 06:41 AM
Chad Irby
And we've solidly established that the smaller weapons would easily fit
into a moderately large suitcase. It would be a bit too heavy to put on
a plane without a "heavy luggage" sticker, but it would, most certainly,
go into something that a rational person would call a "suitcase."
My favorite piece of luggage, which has flown all over the place, is
three feet long, a foot thick, and two feet wide. *Two* of your
artillery rounds would fit into it... it would be heavy, but still quite
compact.
cirby at cfl.rr.com
  #46
Old March 23rd 04, 03:54 PM
Kevin Brooks
. com...
rounds.
compact.
Well, you can climb into bed with the Lebed fans if you want. IMO, the story
has about as much reliability associated with it as the old "red mercury"
crap.
Brooks
cirby at cfl.rr.com
  #48
Old March 23rd 04, 05:36 PM
Chad Irby
crap.
I never said I believed they had sold nukes, but it's bloody obvious
that a nuclear warhead will fit into a suitcase.
From a technical standpoint, it's not that hard.
cirby at cfl.rr.com
  #49
Old March 23rd 04, 11:46 PM
Peter Stickney
"Kevin Brooks" writes:
What's the range of a 105 RR ?
Well, the Davey Crockett wasn't a 105 RCL. It came in 2 flavors - a
120mm bore tube with a range band of between 300m and 200m, and a
155mm tube with a range band of between 200m and 4000m.
Warhead yield was dialable in a range of 20t to 250t. (.02 KT - ,25
KT). (It was a muzzleloader, btw)
Of course it was an artist's sketch.
The same artists are now working on sketches of nuc bunker busters.
Another bad idea IMHO.
And a very old idea. The first nuclear penetrating bomb was the Navy's
Mk 8, from teh very early 1950s.
You are referring to the Davey Crockett, which was indeed fielded. It used
the W-54 warhead, the smallest spherical implosion device ever fielded by
the US, mounted on what was basically a "spigot" which was inserted into the
tube, with the warhead being that bulbous bomb-like contraption sticking out
of the end. The same warhead was the basis for the SADM.
Yeah, Basically, it was an Atomic Bottle Rocket. It was technically
feasible, but when you consider that it was still a Nuke, with all the
security, accountability, and authorization requirements that a Great
Big Nuke has, I don't think any of the very few Infantry units that
got them really liked teh idea. After all, what's the point of a
Jeep-portable Atomic Gun when you need another Jeep and trailer to
hold all the paperwork?
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
  #50
Old March 23rd 04, 11:52 PM
Peter Stickney
Chad Irby writes:
. com...
not the rule.
Actually, they did. Partnered with the SADM was the MADM (Medium
Atomic Demolition Munition), with a yeild of 1-15 KT, and a wight of
around 450#. All in all, the US deployed 5 different types of ADM.
(Never more than 2 types at any given time).
Pete Stickney
Briefcase and Me Bob McKellar Military Aviation 11 December 24th 03 11:57 PM
