Pirker Final Glide Theory
Old February 11th 13, 10:40 AM posted to rec.aviation.soaring
pcool
Default Pirker Final Glide Theory
In short, the Pirker "theory" says that in a final glide to the determine
the best speed you do:
1) calculate the glide ratio needed to get over the final turnpoint
2) for that glide ratio you calculate the corrispondent MC value for your
polar
3) for that MC value you get the speed to fly
I did not know pirker wrote these things in 1999, for me they are just
obvious.
paolo
"Paul Remde" wrote in message ...
Hi,
I think we'd all love to have access to the document. I'd be glad to post
it on my web site if that would help.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
________________________
On Monday, January 14, 2013 10:19:27 AM UTC-5, wrote:
Does anyone have a link to, or a copy of, an English language paper or
explanation about Dr Herbert Pirker's final glide theory? I can't even
locate one in German via Google.
I can find snippets about it relating to implementation on StrePla in
2006vand I understand that a couple of the NavBoxes on LX 8000/9000 relate
to this.
http://www.strepla.de/StrePla4/engli...t_Winter05.htm
Thanks,
John Galloway
John: I've been looking through my stacks and finally found an english
translation as well as the artilcle from aerokurier. I'll get around to
scanning in PDF formats and email these articles to you.
Old February 11th 13, 02:00 PM posted to rec.aviation.soaring
Richard Brisbourne[_2_]
Isn't this the principle behind the Stocker final glide
calculator, as described in Reichmann's
"Streckensegelflug", mid 1970s?
to the determine
final turnpoint
polar
me they are just
obvious.
paolo
Hi,
Best Regards,
Paul Remde
news:4b8c77f1-1a6e-489e-a98c-
relate
to this.
http://www.strepla.de/StrePla4/english/News/News_in
_pocket_Winter05.htm
Thanks,
John Galloway
I'll get around to
you.
Old February 11th 13, 04:06 PM posted to rec.aviation.soaring
pcool
I remember I had implemente the Stocker final glide circles time ago in the
software, basically they represent glide ratio ranges.
Since these concept are just obvious nowadays, I assume that years ago -
before gps - everything had to be done using approximated distances and
airspeed only, so the final glide was relative to the airmass, in principle,
and not to the ground.
Apart from that, if I am not wrong the Pirker analysis does not consider the
wind in final glide according to the document I read.
Nor does it consider total energy, apparently.
paolo
"Richard Brisbourne" wrote in message
to the determine
final turnpoint
polar
me they are just
obvious.
paolo
Hi,
Best Regards,
Paul Remde
relate
to this.
Thanks,
John Galloway
I'll get around to
you.
Old February 11th 13, 05:56 PM posted to rec.aviation.soaring
The Stocker calculator as described by Reichmann
(with instructions on how to make one) was
substantially more complex.
From memory you had a transparent disc with
altitude spirals in one hemisphere and in the other
hemisphere one set of curves corresponding to wind
components and an intersecting set of curves
corresponding to McReady readings. The latter set of
curves depended on the polar of the glider.
This disc was mounted on a map with the centre at
the goal point and it could be rotated about that point.
Above the disc was a linear cursor, also transparent
marked with distances, rotated about the disc centre.
To read the calculator, you rotated the disc so that
the spiral corresponding to your altitude lay over your
current position on the map. You then rotated the
cursor so that the line also lay over that point; the
other end of the cursor intersected the wind and
McReady spirals; the correct setting for the wind
could then be read off.
ranges.
airmass, in
principle,
paolo
glide
to the determine
final turnpoint
polar
for
me they are just
obvious.
paolo
Hi,
Best Regards,
Paul Remde
relate
to this.
in
Thanks,
John Galloway
I'll get around to
to
you.
Old February 11th 13, 10:57 PM posted to rec.aviation.soaring
Tobias Bieniek
actually, as far as I remember, that is incomplete. it also said that once the calculated MC reaches the current average of your thermal it is time for starting the final glide. that way you will not waste time climbing any higher and you have the most efficient final glide compared to others who decided to stop climbing earlier but have to fly slower due to that.
this is pretty much also how the Final Glide AutoMC feature in XCSoar (and I think also LK8000?) works. I've used that feature for years now, and I think it is quite simple to use and understand, and also works quite well from my experience.
Old February 12th 13, 01:39 AM posted to rec.aviation.soaring
Dave Nadler
Yep - First commercial gliding product I did was a
version of this calculator, sold by Cambridge Aero
in the early 80s (maybe late 70s). Still have a few
in the basement I think ! Worked well but it was too
large for USA sectionals and LDs of modern gliders.
Anybody out there still have one ?
I think Chip Bearden needs one.
See ya, Dave "YO electric"
Old February 12th 13, 10:14 AM posted to rec.aviation.soaring
Naviter Info
When you're doing Auto MC please mind the MC theory:
If you hit sink on the final glide the required MC value will go down. According to AutoMC you would be advised to fly slower. **Slower through sink**??
You should always fly your Speed to fly director from the Vario. Even if you fall below final that's the only way to get to the other side as high as possible. "Auto MC" is just a value which is "nice to know" but certainly not the optimal way to get home.
Having said that I too always make my final glides (since before GPS and SeeYou Mobile) comparing required L/D with Current L/D (which is just another way to represent the required MC value)
The original Pirker final glide calculator deals with wind and final glide around the corner iirc which is not as trivial as doing it in a straight line.
Regards,
Andrej Kolar
glider pilots use
http://www.Naviter.com
Old February 12th 13, 10:29 AM posted to rec.aviation.soaring
theory:
value will go down.
Acco=
**Slower through
sink**=
I don't quite follow this.
Surely the required McCready (McReady?) setting is a
function of height, wind and distance to run.
So if you hit sink and lose altitude of course your
required McCready setting will go down. But your
speed at that setting will still be what is appropriate
for that setting in that amount of sink.
You could of course keep your nerve and leave the
McCready setting where it is- if you expect to go
through lift later this is usually OK- it's a judgement
call. If you do this and don't go through any lift later
you're in a field.
The only way to avoid having to slow down at all is
not to fly through sink.
Old February 12th 13, 10:52 AM posted to rec.aviation.soaring
Roel Baardman
Imagine flying "not slower" in the extreme case: flying at Vne through the sink.
The influence of the sink itself will be minimal, since the time you spend in the sink is minimal.
However, your glider's polar is also important, and it will probably not be enough to compensate. It is the sum
of these two that determines your total vertical speed (assuming linear flight).
Thus, you should minimize the sum of these two. You appear to want to minimize only the effect of the sink.
Old February 12th 13, 12:09 PM posted to rec.aviation.soaring
Naviter Info
True. But while you're in sink you need to speed up. At least until you are flying the optimal speed for MC=0 for that sink. The AutoMC suggests you to slow down which is not ok any way you look at it.
Andrej Kolar
glider pilots use
theory:
value will go down.
Acco=
**Slower through
sink**=
you're in a field.
Final glide ppp1 Soaring 8 January 6th 11 02:21 PM
Final Glide - Udo Rumpf jsbrake[_2_] Soaring 23 December 28th 10 03:40 AM
Final Glide Roy Clark, \B6\ Soaring 1 December 23rd 10 04:45 PM
Final Glide - JD (US) Roy Clark, B6 Soaring 1 September 19th 07 07:17 AM
AC Williams -Final Glide [email protected] Soaring 4 January 23rd 06 04:52 AM
