Best performing Vario?
Old February 13th 13, 05:16 PM posted to rec.aviation.soaring
Roel Baardman
Default Best performing Vario?
Seriously - 20 samples per second? Engineers put men on the moon with slide rules. You just don't need the kind of accuracy being touted these days.
The sensors used are not that well-behaved. Not very linear, noisy, etc. So you might actually need that 20Hz to produce a proper value at 1Hz. Many noisy measurements average
out as one pretty good measurement. This has even been proven, by letting 1000 people guess the number of balls in a fish bowl. The average was spot-on.
Also, fast sampling allows one to do all kinds of filtering in software which required analogue filters in the past.
  #132
Old February 13th 13, 05:34 PM posted to rec.aviation.soaring
waremark
What I have read on this forum has led me to think that the Butterfly is currently a decent vario in operation but nothing special. Can anyone with practical experience say different?
I surmise that the software engineers have not yet discovered what to do with all the data available to them.
Since my LX 9000 has the optional giro box what data would it not have that would potentially make the Butterfly better?
  #133
Old February 13th 13, 09:33 PM posted to rec.aviation.soaring
John Galloway[_1_]
Butterfly is
anyone with
what to do
not have that
The very alluring Butterfly vario is using the sensor data but the
concern that has stopped me choosing it so far is the
importance for its performance of getting an accurate reading
from the magnetometer. It is inside the main sensor box which
has all the electrical and pneumatic connections and that makes
it awkward to mount in a way that meets the installation
manual's specifications for distance from electromagnetic field
interference - especially in a retractable motor glider. Two
friends have returned them because theye were unable to
achieve this.
I have the same worry about getting the similarly configured CN
vario for the same reason - although it doesn't matter at
present while the magnetometer is not used (AFAIK).
The LX 9000 AHRS unit has "3 axis Gyros with MEMS technology
and 3 axis digital +-6g accelerometer" according to the
website. If the separate LX 9000 compass module is 3-axis(??)
then including that along with the GPS in the 9000 and the
pneumatic sensors from the V5 vario would appear to make it
match the sensor mix of the Butterfly. Whether they could all
be integrated to work as a full intertial sensor unit I have no
idea - nor whether LX Nav have any plan to try to make it do
so. The fact that the magnetometer is a separate box should
make it easier to locate away from interference.
John Galloway
  #134
Old February 13th 13, 10:04 PM posted to rec.aviation.soaring
rk
Butterfly is
anyone with
what to do
not have that
achieve this.
John Galloway
I thought exactly same about placement of Butterfly IMU. Separate magnetometer would be more convenient, as you have to route GPS antenna, three pneumatic tubes and CAN-bus to the box. AFAIK succesful installation requires quite a distance from *everything*. BTW common radio speakers don't have any magnetic shielding around speaker magnet, for some reason. Strong magnets can disturb compass as far as 1,5 metres away...
  #135
Old February 13th 13, 10:58 PM posted to rec.aviation.soaring
If the butterfly -- or clearnav, with future software -- did read out 3 d wind 20 times a second, this would be a big advantage. Not only could you detect lift long before F = MA gets the glider moving upward, you could tell upward gusts from forward gusts and sideways gusts. Dynamic soaring might even become possible, or at least better energy extraction from gusts. Even the 302 has the necessary sensors, my impression is that we're all waiting on the software development.
John Cochrane
  #136
Old February 14th 13, 06:32 AM posted to rec.aviation.soaring
rk
John Cochrane
I believe the inertial system needs to sort out the F=MA part before solving 3D-wind. Gyros and acceleration sensors don't measure vertical wind, they measure glider vertical movement.
  #138
Old February 14th 13, 10:15 PM posted to rec.aviation.soaring
Andrzej Kobus
On Feb 14, 4:49*pm, John Galloway wrote:
out 3 d
w=
only could you
de=
tect lift long before F =3D MA gets the glider moving upward,
you could
tel=
Dynamic soaring
might=
from gusts.
Eve=
we're all
waitin=
g on the software development.=20
John Cochrane
Regarding gusts, the Butterfly website (in FAQ) *already claims:
"A conventional variometer uses changes in air pressure (TE-
pressure, static- and total-pressure) to determine energy
changes the aircraft experiences. Butterfly Vario does the same.
Additionally it uses an inertial sensing platform that allows for
real-time determination of airmass-movement and realtime
determination of wind. With this technology a pilot can judge
the difference between gust induced energy changes and
thermal induced energy changes."
John Galloway
The Butterfly vario does not filter out gusts. The other sensors are
used only to drive the blue ball that shows air mass movement. The
pilot responsibility is to put the two together and decide what is a
gust and what is lift based on the two sources of information. It is
not a bad solution as one can learn the vario behavior. If algorithms
are used to filter out gusts a pilot might have a difficult time to
learn the vario behavior or understand what it is showing as an
algorithm may have many paths covering many different scenarios
behaving differently in different situations. Of course if algorithm
is perfect that would not be a problem, but this is not an easy
problem to solve. I assume it will be years before this happen mainly
to extensive testing/feedback process that is required to develop and
test these kinds of algorithms what works in theory might not be good
in practice. So for the near future approach that Butterfly took is a
good one, we need to see in practice how workable it will be.
  #139
Old February 14th 13, 10:19 PM posted to rec.aviation.soaring
Kimmo Hytoenen
After Argentina some competition pilots were quite disappointed
with the new variometers using acceleration to calculate lift. I
have not tested myself, just telling their opinion.
read
out 3 d
w=
only could you
de=
you could
tel=
Dynamic soaring
might=
from gusts.
Eve=
we're all
waitin=
John Cochrane
Regarding gusts, the Butterfly website (in FAQ) already claims:
same.
John Galloway
  #140
Old February 15th 13, 12:24 AM posted to rec.aviation.soaring
Bill D
read
out 3 d
w=
only could you
de=
you could
tel=
Dynamic soaring
might=
from gusts.
Eve=
we're all
waitin=
John Cochrane
same.
John Galloway
Not sure, but I suspect they are mixing frames of reference. In theory, the way to do this is solve the TE equations in the inertial and air-data domains separately then compare them. A gust will show up strongly in the air-data but less so in the inertial data so a computer - or a pilot - can tell the difference.
A purely inertial vario will require a full IMU with GPS updating. These things are probably still too expensive for sailplanes but only just.
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Aviation Photos 3 January 20th 08 03:10 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Naval Aviation 2 January 11th 08 06:10 PM
Navy Performing Well, Keeps Eye on Future Force Otis Willie Naval Aviation 0 February 14th 05 10:06 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 08:18 PM
