Canopy gas spring for DG600
Old March 4th 13, 05:50 PM posted to rec.aviation.soaring
Default Canopy gas spring for DG600
Hello all,
Does anyone have the specifications for the Canopy Gas cylinder in a DG600 (pressure, compressed/extended length)?
Thanks in advance,
Lars Peder
Old March 5th 13, 04:48 PM posted to rec.aviation.soaring
Dan Marotta
Look closely at the body of the cylinder and you should find the force
specification (probably in Newtons) printed on it. Measure the length
carefully, closed and extended, and the diameters of the mounting holes. I
did this for the front door struts on my LAK trailer and bought them at
McMaster-Carr.
Good luck!
Hello all,
Thanks in advance,
Lars Peder
Old March 6th 13, 01:32 AM posted to rec.aviation.soaring
Bill T
Contact Chris Klix at Pacific Coast Aero. He is the DG Rep in the western US and may have the data available.
I've been able to read the part numbers on older LS gliders. Did the make/model information get worn off the strut?
Bill
Old March 6th 13, 07:31 AM posted to rec.aviation.soaring
Bill
Thanks Bill,
Yes the label is worn down to a bright silvery look over the years. Looks nice but it's low on information value ;-)
Lars Peder
Old March 6th 13, 04:01 PM posted to rec.aviation.soaring
Once you have the specs, try Suspa.com. Nice small friendly company many of us have used already. They can make custom length and force gas springs. If you're lucky the eyelets can be re-used by simply unscrewing the existing ones and screwing onto the new spring. Having the diameter of the shiny rod helps here for thread size. The only compromise I had to make was the width of the eyelets on my new spring were narrower, so I had to add additional spacers to the two existing ones. Mine was around $100 being custom made.
Old March 7th 13, 12:46 AM posted to rec.aviation.soaring
4Q
On Monday, 4 March 2013 09:50:34 UTC-8, wrote:
Hello all, Does anyone have the specifications for the Canopy Gas cylinder in a DG600 (pressure, compressed/extended length)? Thanks in advance, Lars Peder
try strutwise.com
Canopy gas spring LS4, USA [email protected] Soaring 3 October 30th 12 12:01 PM
TOST Tow Spring Pad for Cub [email protected] Soaring 0 January 21st 08 04:08 AM
Ten tips for ASW20 canopy gas spring replacement. [email protected] Soaring 0 April 10th 07 05:15 PM
DG600 - any advice from owners?? Martyn Johnson Soaring 5 January 7th 06 02:00 PM
DG600 - any advice from owners?? Martyn Johnson Soaring 1 January 1st 06 02:34 AM
