Red V on OLC from CA302?
Old March 9th 13, 10:20 PM posted to rec.aviation.soaring
SF
Default Red V on OLC from CA302?
I recently downloaded a flight to the OLC and got a red V for validation does anyone know how to fix this or what the problem is? all this stuff worked last year.
SF
Old March 9th 13, 10:36 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
SF
There was a bit of a hassle about this last year, but with a small amount of additional effort you can make it work. Please follow the instructions provided here
http://clearnav.net/main/cn-CAI-OLC.html
with best regards from ClearNav Instruments,
Evan Ludeman for CNi
Old March 9th 13, 10:55 PM posted to rec.aviation.soaring
Paul Remde
Hi Evan,
That utility is for Cambridge GPS-NAV units, not 302 units. 302 units
validate on the OLC web site just fine without any modifications.
Paul Remde
_________________
"Evan Ludeman" wrote in message
worked last year.
SF
provided here
Old March 9th 13, 11:01 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
On Saturday, March 9, 2013 5:55:57 PM UTC-5, Paul Remde wrote:
Hi Evan,
Paul Remde
_________________
worked last year.
SF
provided here
Yeah, I know, which is why I deleted the post from google groups.
T8
Paul Remde
Hi,
Cambridge 302 flight logs are accepted by the OLC without any need to modify
them.
The issue could be:
- Check the filename of the file you uploaded. It should include the serial
number of your 302. If it doesn't then you probably accidentally uploaded a
flight log that was generated by the "PDA logger" in your soaring flight
software.
- When you downloaded the file - did you use the Cambridge 300 utility? If
so, did it stated that the file passed all 3 security tests? If you didn't
use the Cambridge 300 utility, that is fine - but you may want to check the
security of the file using the Cambridge 300 Utility on your PC.
- Does the 302 show "good seal" on one of the screens? If not, then the
unit needs to be re-sealed at Cambridge or by a dealer like myself.
- There is a bug in 302 units that seems to cause rare flight log security
issues. I suspect it happens when the memory gets full. You can read more
about that an how to clear the memory he
http://www.cumulus-soaring.com/newsl...LETTER.BLOCK15
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
__________________________________
"SF" wrote in message
worked last year.
SF
