Aircraft takes off with no pilot...because of wind.
Old March 18th 13, 04:44 AM posted to rec.aviation.soaring
Morgan[_2_]
Default Aircraft takes off with no pilot...because of wind.
There was the wind event at Mojave in CA last year that had a 747 giving flight another go. Only enough wind to get the nosewheel off the ground thanks to the engines not being on the airframe any longer. I guess tying down that heavy of a ship doesn't seem necessary.
http://www.youtube.com/watch?v=cHhZwvdRR5c
Old March 19th 13, 12:02 AM posted to rec.aviation.soaring
Nah, this looks like the real thing to me. Most every model will not have the protrusions like pitot and antenna you see here underneath unless they are the very top end scale ($$$) jobs which are rare. ARF manufacturers wont supply these details since they'll break off right away when you remove the wings for transport.
Old March 19th 13, 11:22 AM posted to rec.aviation.soaring
waremark
On Sunday, 17 March 2013 18:17:17 UTC, Eric Greenwell wrote:
On 3/16/2013 11:42 PM, Chris Rollings wrote:
At 02:25 17 March 2013, Jeremy Keeling wrote:
I don't think the aircraft is a model haha, look at the relative size of
everything around it.
It seems to me that the CCTV camera would be looking towards an aircraft
parking area maybe? Or perhaps the other aircraft that were there had
already been tossed over and the person fetched his camera to catch the
last one...I dunno.
Up elevator only matters on a nose-wheel aircraft. Most empty gliders sit
with the tail-wheel or skid on the ground so elevator position is almost
irrelevant.
The comparable glider errors I see are leaving the tail dolly attached
to an unattended, unsecured glider; not putting the flaps into full
negative; and not turning the glider perpendicular to the wind.
email me)
Re parking with the flaps in full negative - the ASH 26 manual tells you to put the flaps in neutral if leaving for a while. I wonder what the reason is - protecting the seals? I always do what I am told!
Mark Burton
Old March 19th 13, 03:50 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
gliders sit
almost
irrelevant.
attached
full
Mark Burton
If wind isn't a factor, then flap 3 (neutral) is a good choice to
preserve the camber of the Mylar fairings. Still, I keep my glider in
it's trailer most of the time, using a bungey to hold the flaps and
ailerons in full negative so they don't flop around when towing the
trailer. The top Mylar lasted about 10 years before it needed replacement.
I don't think leaving it in negative (flap 1 or 2) during the occasions
it's sitting outside will significantly affect the lifespan of the
Mylar. If you put covers on it while it's outside, flap position
probably doesn't make any difference in the wind, so flap 3 could be
safely used.
email me)
Old March 19th 13, 04:16 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
irrelevant.
Oh, how not true, Chris! Elevator position ALWAYS matters. And in fact, nose down is where the elevator should be when the glider is unattended. Why? Wind comes up from the nose, the elevator will raise the tail if the wind is high enough, reducing the angle of attack and making it less likely that the plane will blow away. Wind comes up from behind, it will keep the tail pinned to the ground. Same applies to both nose dragger and tail dragger planes. How many have seen single engine Cessnas blown over by a wind from behind because the tail was not secured and the control wheel was held back? I have seen quite a number.
And depending on the tail wheel, nose up elevator can help compress a tailwheel leaf spring increasing the angle of attack and make the plane more likely to blow away. Think 2-33s and the long, slender single leaf springs.
Steve Leonard
Old March 20th 13, 01:34 AM posted to rec.aviation.soaring
Tony V
Ah, but on a 2-33 the elevator drain holes are near the hinge. Tie the
stick "nose up", and any water that collects won't drain.
Tony V.
Old March 20th 13, 01:36 AM posted to rec.aviation.soaring
Tony V
I meant "nose down" elevator.
Tony V.
Win Pilot Wind readout RDC Soaring 0 June 9th 09 03:47 AM
Another great olde aircraft takes to the air Marine Airdale Naval Aviation 0 April 16th 09 11:33 PM
X-48B Blended Wing Body Research Aircraft Takes First Flight [1 attachment] §qu@re Wheels[_4_] Aviation Photos 5 July 30th 07 06:17 AM
Wind limits - small single engine aircraft [email protected] Piloting 30 February 7th 07 07:36 AM
See if you have what it takes to be a pilot !!! Dave Kearton Aviation Photos 24 January 7th 07 09:59 AM
