Rental glider flight logging...
Old March 26th 13, 12:22 AM posted to rec.aviation.soaring
Scott Alexander[_2_]
Default Rental glider flight logging...
Do any commercial gliderports use an .igc trace to log flight times?
Of the commercial gliderports you have been to, how were they keeping
track of flight times when they rented a glider to you?
I am looking for an electronic way to automatically log rental glider
flight times.
Old March 26th 13, 12:45 AM posted to rec.aviation.soaring
Dave Nadler
flight times.
http://dittolog.com/learn-about-dittolog/
Old March 26th 13, 10:20 AM posted to rec.aviation.soaring
Thanks Dave for that suggestion. Has anyone on this forum used this before?
Looking to help upgrade the local commercial gliderport from an archaic method to an up to date automated electronic method.
Old March 26th 13, 03:30 PM posted to rec.aviation.soaring
JS
Believe you can also use FLARM and a PDA (etc) to automatically log the release from tow (when the distance between towplane and glider starts to change). Devices can upload the information to the office computer when the towplane is in WiFi range.
Contact Mark Fisher at Swift Avionics.
swiftavionics DOT com DOT au
Old March 26th 13, 05:35 PM posted to rec.aviation.soaring
RS
Doesn't meet the need of what you're looking for, but I have to give
credit them for being original and I certainly can't speak for how
well it worked.
A few years ago I saw a rental Blanik with a Hobbs meter installed.
It was powered by a solar panel and connected to a switch, I believe a
repurposed stall warning switch mounted on the exterior of the
fuselage. When the glider was flying, the the circut was closed and
the meter logged time.
Don't know if this actually worked as designed, but found it amusing.
Old March 26th 13, 08:27 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Winter also makes 2 versions of a flight hours meter. You can see details
he
http://www.cumulus-soaring.com/winte...Hours_Counters
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_________________________________
"RS" wrote in message
well it worked.
Old March 27th 13, 07:04 PM posted to rec.aviation.soaring
Terry Pitts
When I flew at the Wasserkuppe last summer, they had just started using a system that required the pilot to snap an electronic key into place before flight. At the end of the day all the billing info was rolled up and printed out. I was intrigued by the system.
When I went back in mid-fall hoping for some typical-for-that-time-of-year wave experience, they had quit using the system for some reason. I suspect they'd be glad to share their experience/thoughts if emailed. http://fliegerschule-wasserkuppe.de/
Terry
Old March 29th 13, 11:59 AM posted to rec.aviation.soaring
Thanks guys,
Tim Mara has steered us in the direction of a Fly with CE recorder.
It has a logbook program that comes with it and is relatively
inexpensive. The hobbs meters is a nice idea, but the added benefit
of a igc file produced worthy of badges makes this more attractive.
Old March 30th 13, 06:39 AM posted to rec.aviation.soaring
bill palmer
Warner Springs, CA tracks the times.
They note the time that you pass by the office window under tow, and again on landing. So far it's always within a minute of the time hack I make from takeoff to landing.
flight times.
Logging Glider Flight Time RN Soaring 9 August 7th 12 04:31 PM
Rules for Logging Glider PIC Time Markus Graeber Soaring 7 January 8th 12 12:30 AM
Glider Rental Insurance: Tony V Soaring 1 August 18th 10 05:06 PM
Glider Rental Insurance: BTiz Soaring 0 August 18th 10 04:53 AM
Glider Rental Insurance: Walt Connelly Soaring 5 August 18th 10 02:03 AM
