Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Slip (balance) and Turn indicator
Old March 28th 13, 08:13 PM
mikeaaron353 mikeaaron353 is offline
Junior Member
First recorded activity by AviationBanter: Mar 2013
Default Slip (balance) and Turn indicator
I am not an aviator, but I have what hopefully is not a stupid question.
I am a restoring a '80 Triumph Spitfire roadster and would like to add a Supermarine Spitfire gauge to the dash. I found a Slip (balance) and Turn indicator in ebay, but not knowing enough about them I was wondering if it would indicate anything about my turning in a car rather than a plane that is operating at an order of magnitude faster. The indicator has graduations from 1 to 4.
Thanks for you time.
Mike M.
Old March 30th 13, 02:16 AM posted to rec.aviation.misc
Ron Wanttaja[_2_]
question.
It indicates whether a turn is coordinated (slip) and the relative rate
of turn. In reality, your Triumph will probably turn a lot faster than
the aircraft.
The slip indicator is basically showing how much the driver being pushed
left or right as the car turns. A perfectly banked turn will show
zero...whether you're in an aircraft or on a banked track. The slip
indicator is nothing more than a carpenter's level; no power or anything
needed.
Looking a picture of the gauge, it looks like the turn indicator is
vacuum driven. If you apply vacuum, the needle will indicate how fast
you're turning. A modern "Standard Rate" turn means it takes two
minutes to do a complete 360-degree circle...as you can anticipate, your
car will turn a lot faster. Be neat to look at, assuming you can get
some vacuum to the gauge.
Wanted Smal PZL Turn and Slip Indicator Nick Stone[_2_] Soaring 0 May 16th 12 11:19 PM
PZL EZS-3 Turn and slip UncleMart Soaring 7 April 12th 11 04:42 PM
From where is a turn indicator powered? Jim Stewart Owning 12 December 13th 07 11:02 PM
64 M20C Turn/Slip replacement BellSouth.net News Owning 3 September 1st 04 03:07 PM
solid-state turn indicator Jim Hendrix Soaring 0 April 14th 04 04:17 AM
