#11
On Wednesday, April 3, 2013 1:03:13 PM UTC-4, Liam wrote:
Looks like the Ka7 might become the new Blanik. I wonder how many are still flying in the US? There are only 3 registered in the USA and none in Texas, so 2 still flying |
On Wednesday, April 3, 2013 12:10:07 PM UTC-5, son_of_flubber wrote:
On Wednesday, April 3, 2013 1:03:13 PM UTC-4, Liam wrote: Looks like the Ka7 might become the new Blanik. I wonder how many are still flying in the US? There are only 3 registered in the USA and none in Texas, so 2 still flying There are 3 Schleicher K 7, 23 Schleicher Ka 7 and one Alexander Schleicher GMBH K 7. I believe the Ka7 has a similar wing construction to the Ka2 and ASK-13; probably same wood and glue used in Ka6, Ka10, ASK14, and ASK18. There is some debate about what glue was used where in which gliders. It seems the factory was not consistent. Of course this isn't necessarily a glue failure accident either. Time will tell. |
There are actually 27 that I could find in the N-number registry. I did my training in one of them. This would be another enormous loss to our training community if in fact they are grounded.
http://registry.faa.gov/aircraftinqu...Val=0&PageNo=1 http://registry.faa.gov/aircraftinqu...Val=0&PageNo=1 http://registry.faa.gov/aircraftinqu...Numbertxt=9156 On Wednesday, April 3, 2013 1:10:07 PM UTC-4, son_of_flubber wrote: On Wednesday, April 3, 2013 1:03:13 PM UTC-4, Liam wrote: Looks like the Ka7 might become the new Blanik. I wonder how many are still flying in the US? There are only 3 registered in the USA and none in Texas, so 2 still flying |
![]() Looks like the Ka7 might become the new Blanik. http://www.myplainview.com/news/arti...9bb2963f4.html According to the accident report for the 2004 accident referred to in this article, glue failure in the wing was dismissed as a reason for the wing failure. There was, however, an small glue failure in the left elevator that could have led to loss of control in pitch. The wing failure happened where the lower spar boom suffered first compression damage, then failed in tension, initiating the failure of the upper spar boom by bending. This compression damage could have occured in flight, by flying outside the flight envelope of the glider. It could not be established if this happened through loss of control due to elevator problems, or by voluntary maneuvres. The pilots had been discussing planned aerobatics before the flight, but the failure occured at the very beginning of the flight, during rolling maneuvres. Another possibility was that the compression damage occured during a heavy landing or the aircraft's recent excursion over rough ground that necessitated repairs to the steel tubing in the fuselage. The complete report is available on the BGA website, but it is password protected. However, the Air Accidents Investigation Branch give the link, username and password on their links page: http://www.aaib.gov.uk/links/index.cfm Look for report date: 25-11-2005 |
On Apr 3, 1:09*pm, wrote:
The wing failure happened where the lower spar boom suffered first compression damage, then failed in tension, initiating the failure of the upper spar boom by bending... This is a very common failure mode for wooden aircraft structures. Often the event that caused the original compression damage precedes the final failure by weeks or months or even years. Thanks, Bob K. |
![]() Quote:
FYI Details of BGA inspections on K7 and others http://www.gliding.co.uk/bgainfo/tec...04-issue-3.pdf |
Argh!!! Another fatality which may have been avoided if we had better accident information sharing globally!
Ramy |
I guess its too early to know what happened. But as a comment, I did
personally witness an inflight structural failure in a wooden glider back in the UK. It turned out to be caused by an effect called a 'compression shake' which is when a compression overload leaves the wood with a fine defect that is very weak in tension, so it can fail in tension at a later time, maybe years later. These shakes can apparently be detected by a careful visual examination, by someone who knows what to look for, eg after an unusually heavy landing or shock. Also there is a BGA note about glue joint inspections in gliders like K7s. I don't know if the FAA pass these on to US owners. http://www.gliding.co.uk/bgainfo/tec...07-2004-issue- 3.pdf |
On Thursday, April 4, 2013 12:23:23 AM UTC-4, Ramy wrote:
Argh!!! Another fatality which may have been avoided if we had better accident information sharing globally! Ramy The accident that triggered the UK action was no secret and the findings were made available, even if not widely published on RAS. No new findings resulted. It did trigger the requirement for more rigorous inspection. One sad reality is that the few people who really know how to inspect and maintain old wood structure gliders are fading away. The new A&P's and IA's are very well versed in documentation, but not so well trained in some of these less used skills. Sadly UH |
On Wednesday, April 3, 2013 11:23:23 PM UTC-5, Ramy wrote:
Argh!!! Another fatality which may have been avoided if we had better accident information sharing globally! Ramy Maybe and maybe not, Ramy. If you have not yet, I would encourage you to go read the report on the one in the UK. The wing failed about one meter outboard of the fuselage. Roughly where the drag spar attaches to the main spar. On this recent accident in Texas, the eyewitnesses say the wing failed at roughly half span. It could well be that it was the same basic cause (compression fracture in the lower cap that reduced its tension load carrying capability), but as Hank noted, there are fewer and fewer good "wood people" out there. However, I know we have a couple of them assisting the NTSB with information, and how to access proper information for this investigation. Steve |
FATALITY IN SO. CAL. | Vorsanger1 | Soaring | 5 | September 18th 09 03:32 PM |
Yet another fatality.... | Bob | Soaring | 2 | October 5th 06 06:09 AM |
Airman always recalls hour of tragic military crash | Otis Willie | Military Aviation | 0 | March 23rd 04 08:05 PM |
Veteran revists site of tragic crash | Otis Willie | Military Aviation | 0 | February 20th 04 11:14 PM |
RAF sq 26 . Need help so find log for a tragic day 2nd July 1944 | Vidar Holum | Military Aviation | 1 | November 26th 03 11:09 AM |
