FAA Plans to Change to Radios with 8.33 MHz spacing?
Old April 14th 13, 01:05 AM posted to rec.aviation.soaring
Dan Marotta
Default FAA Plans to Change to Radios with 8.33 MHz spacing?
The satellite ain't goin' 17,000 mph with respect to the ground station.
Doppler will be small with short transmissions.
"Bill D" wrote in message
On Saturday, April 13, 2013 12:26:36 PM UTC-6, Bear wrote:
Bob,
I don't believe that we switch to GSM or whatever.
1. For none of the digital communication techniques it was possible to
find a global frequency range.
2. The relative speed is too high. To my knowledge the highest speed to
which a digital communication system is certified is 500 km/h (310 mph).
This is GSM-R, Global System for Mobile Communications - Railway or
GSM-Railway, for details see Wikipedia.
500km/h would be good enough for us but not for others. We can forget it
in aviation thanks to Doppler effect.
Bear
So, how is digital communication with 17,000 mph satellites possible with
Doppler effects?
Nobody suggested GSM as an alternative to a global aviation-specific
digital communications protocol.
Old April 14th 13, 06:35 AM posted to rec.aviation.soaring
Alan[_6_]
In article Bear writes:
Bob,
Seems unlikely. Are you saying that there is no VHF or UHF band available
worldwide?
Bear
Hmmm. The prime communications channels with the space station are digital.
DirecTV and Dish Network are digital. The network feeds to your TV stations
are digital via satellite. The "cable channels" are fed digitally to your
cable companies.
GPS is digital. It seems to be popular in aircraft.
Alan
Old April 14th 13, 05:08 PM posted to rec.aviation.soaring
Bill D
The present 2-meter AM air-band "Party line" originated as a military system in the biplane era. Today's military has many highly secure digital communication nets used for airborne operations from close air support to drone attacks.
The DOD likes the idea of using COTS products so wherever possible, they push military technology into the commercial domain to spread R&D costs and reduce the price they pay per unit. That's where the air-band replacement will come from.
Why would the FAA and ICAO want to do this? Bandwidth. Digital communication uses spectrum far more efficiently and it eliminates channel clutter so pilots hear just what they need to hear.
On Saturday, April 13, 2013 2:13:33 PM UTC-6, Bear wrote:
What is your proposal?
So, how is digital communication with 17,000 mph satellites possible with Doppler effects?
Nobody suggested GSM as an alternative to a global aviation-specific digital communications protocol.
Old April 14th 13, 05:45 PM posted to rec.aviation.soaring
Kent Leyde
http://en.wikipedia.org/wiki/Orthogo...n_multiplexing
From wikipedia:
Summary of advantages
*High spectral efficiency as compared to other double sideband modulation schemes, spread spectrum, etc.
*Can easily adapt to severe channel conditions without complex time-domain equalization.
*Robust against narrow-band co-channel interference.
*Robust against intersymbol interference (ISI) and fading caused by multipath propagation.
*Efficient implementation using Fast Fourier Transform (FFT).
*Low sensitivity to time synchronization errors.
*Tuned sub-channel receiver filters are not required (unlike conventional FDM).
*Facilitates single frequency networks (SFNs); i.e., transmitter macrodiversity.
Old April 23rd 13, 02:41 AM posted to rec.aviation.soaring
Darryl Ramm
On Thursday, April 11, 2013 2:33:51 PM UTC-7, Paul Remde wrote:
Hi,
I imagine someone on this newsgroup can point me in the right direction on a
technical/FAA question.
Becker offers 2 versions of their AR6201 radio. The original version has
frequency spacing that can be set to either 25 mHz or 8.33 mHz. The new,
slightly lower cost option has frequency spacing fixed at 25 MHz It is my
understanding that the 8.33 MHz spacing is required in Europe, but not
currently in the USA. Customers are asking me whether the FAA has any plans
to go to the 8.33 MHz spacing in the near future - so they can be better
equipped to select the radio version that makes sense. At a recent soaring
seminar someone stated that they thought the FAA was going to require radios
with the 8.33 MHz spacing starting in 2020.
Can anyone help me?
Thank you in advance.
Paul Remde
Cumulus Soaring, Inc.
Yes Google would answer all your questions. 8.3 kHz ain't happening in the USA anytime soon. And one issue there is the FAA in their "wisdom" have been playing with Nextcom, a VDL based future digital voice system. (VDL is one of the existing digital link technologies that was also a potential ADS-B carrier, but is effectively not used for ADS-B).
http://www.aviationtoday.com/av/comm...XCOM_1201.html
and see
http://www.roger-wilco.net/8-33-khz-...-what-is-this/
Presumably would be introduced in transport category and other high-flying aircraft. Yes the same folks that thought going dual-link ADS-B was a good idea... your tax dollars at work, sigh. It would not surprise me to eventually see 8.3 kHz spacing in the USA, and that would actually be a good think IMNSHO vs. trying to go digital.
Any mentions of cellular communication standard here are irrelevant, terrestrial type cellular systems don't work well with aircraft in the air and "spamming" multiple cells. For digital links there are technology (like VDL) that are already fairly well understood. FM based systems (like FRS, which is low-power and also irrelevant here) are also non-starters, being FM does not inherently solve bandwidth issues and FM suffers from capture effect/overtalk issues (why we use AM to start with).
Darryl
Old April 24th 13, 05:43 PM posted to rec.aviation.soaring
soartech[_2_]
Darryl
Darryl,
Please explain these terms. I always thought aviation used the
outdated AM because that's what they started with many years ago.
After having used 2 meter FM radios for many years I find them to be
vastly superior to aircraft band AM radios.
Old April 24th 13, 06:21 PM posted to rec.aviation.soaring
Sean F (F2)
This would be a great solution then to the team flying dilemma. Simply purchase a modern radio and fly on channels entirely unused on the USA.
Im ordering one today.
Sean
F2
  #28
Old April 24th 13, 08:53 PM posted to rec.aviation.soaring
Mike the Strike
Unfortunately those "unused" 8.3kHz channels don't actually exist - they are already occupied by the existing 25kHz channels. Also any radio you use to transmit here in the USA has to be type approved and current approval doesn't include the 8.3kHz units.
Sorry!
  #29
Old April 25th 13, 12:31 AM posted to rec.aviation.soaring
Tony V
Darryl
Darryl,
The advantage of AM is that when two people talk at once you hear them
both. With FM, you get the strongest signal or, when both signals are
nearly equal in strength, you hear neither. I'll take AM for aviation
radio. For ham VHF/UHF, it's FM/SSB/digital. :-)
Tony "6N", W1DYS
  #30
Old April 25th 13, 03:10 AM posted to rec.aviation.soaring
Darryl Ramm
Darryl
Darryl,
Tony "6N", W1DYS
What he said...
Darryl
Contest Grid Spacing? ContestID67[_2_] Soaring 3 June 1st 11 03:29 AM
Long EZ plans, Mini IMP plans, F4U Corsair plans, materials, instruments for sale reader Home Built 1 January 26th 11 01:40 AM
Duster Plans For Sale - BJ-1b fullsize sailplane plans WoodHawk Soaring 0 April 25th 05 04:37 AM
[igc-discuss] To change or not to change... rules ? Denis Soaring 0 February 16th 05 07:24 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
