Has anyone running ver 2.6 on a Power FLARM Portable seen a PCAS target at greater than +/- 49 (4,900ft)altitude difference.
In recent tests I set PCAS Vert range to values greater than 5,000 ft and never saw a return on aircraft as they flew over on the PHX arrival route. They only showed up after passing by and then only at +49 or lower. The aircraft descend after passing my house. I don't much care if PCAS altitude is limited to 5,000 ft max but I like to know about that limitation and have the user selections be compatible. FLARM - Is 5,000 ft the PCAS altitude limit in ver 2.6? thanks Andy |
| Thread Tools | |
| Display Modes | |
| PowerFlarm PCAS performance | Ramy | Soaring | 9 | September 17th 12 07:05 PM |
| Fs Zaon Pcas Xrx | cessna150 | Aviation Marketplace | 0 | January 26th 12 07:02 AM |
| MRX PCAS displays wrong code and altitude for my transponder | 5Z | Soaring | 5 | April 5th 11 06:04 PM |
| Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 08:41 PM |
| Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 11:48 AM |
